Voltage issues SY-5SSM, where's the problem? Help needed
  • rattlesnake
    • Dec 2017
    • 78
    • Argentina
    I'm trying to fix this SY-5SSM motherboard (Socket 7).
ID:	3557374 Click image for larger version
    When the PSU is connected it powers on by itself but there's nothing on the POST card, no beeps.
    The BIOS EEPROM is ok (latest BIOS was flashed).
    All the jumpers are set ok.
    All the 1000µF 6.3v (14) and 1500µF 16v (2) caps are in spec.
    There are two 76129D MOSFETs (datasheet). I took them out and tested them and they are ok (no continuity from drain to source) in off state.
    But the voltage in the gate of the second 76129D fluctuates between 1.468-1.649, and it should be 2.2v (with a K6-2 installed, properly configured).
    The voltages are:
    76129D (closer to IDE interface)
    G 0.033v
    D 5.08v
    S 0.033v
    76129D (closer to the edge of the motherboard)
    G 1.468-1.649v
    D 0.033v
    S 0v
    What should I check next? What could be the problem?
    Any suggestions would be appreciated.​
  • FriedFred
    • May 2024
    • 140
    So the main power supply switch on by itself?? This is not normal, I think. Usually, you have just the "Always on" voltages, like 3.3V and/or 5V. Nothing else. Then the power supply is waiting for the power-button to press.
    Do you have any coils shorted to GND? Do you have any coils with a reasonable voltage? Do you have a "Always on" voltage on the board anywhere?
    • rattlesnake
      • Dec 2017
      • 78
      • Argentina
      Hello Fred...
      I already fixed it.
      Coils were fine. I checked every electrolytic capacitor. I checked the VRM transistors, the buck converter IC (HIP6004). I couldn't detect any failure. I even replaced the transistors just in case. Then close to the edge of the board I noticed a missing SMD cap "C718". It can be seen in the pictures I attached. So I started figuring out how the circuit works as far as I could. I removed and measured some capacitors that were already in circuit and added one of a similar value (0.1µF).
      And violà, like magic, the motherboard posted! It was very rewarding. The voltages are now fine.
      I'm disappointed that I only get an answer after almost a month, but I appreciate you trying to help, that's why I'm posting this answer to let you know that it's already fixed.
      I don't know what happened but this forum is not what it used to be...
      • FriedFred
        • May 2024
        • 140
        Nice you fixed it! Usually, The replies for older boards are less, I think. I usually answer the questions with really less or not any answer at all. To give a helping hand. I did not recognise this request was a month old! But I know the feeling, if you don't get any answer at all...
        • Fernon@Repair
          Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
          by Fernon@Repair
          i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
          VCCIO voltage ok
          VCCSA Voltage OK
          VCCPLL Voltage OK
          Ram Voltage ok
          RamVTT OK
          VPP 2.5 OK
          But No Core Voltage
          and i want to this vrm ic datasheet or pinout (ISL69269)
          anyone have this ic pinout voltages?...
          06-25-2025, 07:19 AM
        • pb1911nt
          MacBook Pro A2251 - 820-01949 Voltage Drop and unkown issues.
          by pb1911nt
          Hello forum,
          I'm still relatively new to the world of electrical repairs.
          I have a Macbook here that I can't figure out
          When the battery is gone, the USB input consumption goes up to 20 V and 0.06A. But it breaks down after about 2-3 seconds and you can also hear a small ticking on the logic board. But I can't pinpoint it exactly.
          I removed the logic board and took a few measurements.
          But I can't really figure it out.
          At first I thought the infamous CD chip was defective - but then of course you read more on the internet...
          09-07-2025, 11:35 AM
        • electron_jj
          Panasonic TH-L42D25A checking the PSU output voltage
          by electron_jj
          Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
          I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
          08-29-2021, 08:13 AM
          ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
          3+1 Voltage Regulator for IMVP-7/VR12 CPUs
          Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
          core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
          configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
          serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
          Based on Intersil's Robust Ripple Regulator...
          11-05-2024, 03:24 PM
        • ruletero
          Acer a515-43 low battery charge voltage
          by ruletero
          Hi
          Acer A515-43
          LA-H801P
          Fail: Does not charge battery, has low voltaje on connector.
          Laptop didn't want to turn on, only charge led blinked.
          I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
          I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
          Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
          10-24-2022, 02:31 PM
