Disaster of 400 V Caps
  • mikail13
    • Aug 2013
    • 93
    • Turkiye
    My Airties Air5440 Adsl Modem was working properly at 7/24 for three years .
    it is a quality device.
    Recently i often see
    "The service is unavailable." message at browser pages.
    at least 3 times a day. it needs restart the modem.
    and also modem is very hot. i suspect the adapter that is labelled DVE 9V.
    i replace it. " The service is unavailable." message disappered at site.
    I opened to the adapter and see red area at pcb. it frys.
    Caps looks like O.K.they must be 4,7 uF (400 v)
    But Multimeter says it's not.
    and i also controlls other corrupted bulb lamps, swich and modem adapters
    i measured and see 5200 uF ,4800 uF, 2200uF
    all of them exceed to thousands. i change these.
    everthing's O.K. now.
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    Re: Disaster of 400 V Caps
    what brand of caps was installed in the power supply?
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
    • mariushm
      • May 2011
      • 3799
      It's always plugged in the mains, so it's ALWAYS ON
      When loaded, heat is produced which has nowhere to go, because the adapters are usually sealed for safety
      So heat keeps the capacitors always warm which shortens their life span.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        and those cheap caps are in trouble even when not overheated 24/7.
        i see this type of failure often.
        i replace all with high quality parts and it outlasts the units usefulness.
        • ant3202
          • Jun 2006
          • 275
          • Singapore
          either i get a better design power adapter or recap with better specs on it.
            Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
            by momaka
            I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
            For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
            https://www.badcaps.net/filedata/fetch?id=3591771
            https://www.badcaps.net/filedata/fetch?id=3591772
            It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
            https://www.badcaps.net/filedata/fetch?id=359177...
            03-12-2025, 03:42 PM
          • eryjus
            Heathkit IO-4205 Power Supply Caps
            by eryjus
            First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
            I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
            I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
            05-10-2023, 11:21 AM
          • Paxman_Swede
            Identifying caps on an old Zoom 9000
            by Paxman_Swede
            Hello!
            I have two projects on my work bench. One is a friends dead JBL Xtreme speaker with a blown voltage regulator and corresponding bulged and shorted cap. That cap has clear markings so I know what replacement I need for it.
            The other project however is a whole different deal. It's a Zoom 9000 guitar effect from the 90th that has developed a devil hound howl when there is no input from the guitar. I'm guessing caps problem. So, since I don't really use this effect anymore I thought it would be a perfect project to learn on.
            I have studied the board and...
            01-14-2025, 09:51 AM
          • captain150
            Help with switching power supply caps
            by captain150
            I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
            I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...
            03-16-2025, 07:34 PM
          • Foetuss
            Gigabyte GA-6OXT :: caps question
            by Foetuss
            Good evening
            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
            But I was also suprised about the bigger boys, which are 330µF 25V.
            Could it be they used 25V caps because they were cheaper / available at that time?...
            02-11-2025, 12:22 PM
