Cap voltage without load
  • notallbad
    • Oct 2012
    • 1190
    Two Axial polarised electrolytic caps, 2700uf and 220uf 40v in parallel across a 12v DC supply (using a 12v car battery charger as supply voltage) with no load connected.
    What would be the expected P.D voltage across the terminals be?
    Trying to determine whether the caps are good or not.
    Re: Cap voltage without load
    Devices in parallel circuit will see the same applied Voltage, so the Voltage across the terminals of BOTH caps will be 12VDC. You should draw out the diagram so you will see how it works.
    http://www.bbc.co.uk/schools/gcsebit...uitsrev1.shtml
    https://learn.sparkfun.com/tutorials...allel-circuits
    • notallbad
      • Oct 2012
      • 1190
      Thanks, shall take a look at those links.
      DMM across terminals reads around 18v which does not make sense to me!
        What kind of 12VDC power supply? Linear unregulated power supply (Transformer, rectifiers, caps)? The no load Voltage of those type of power supply will be higher until fully load and the input Voltage applied is the same as printed on the unit.
        For example, the label on the power supply shows 12VDC 1A, 120VAC input, it will put out 12V when the load is drawing 1A, but if the load is <1A then the Voltage will not be 12V but will be higher.
        • R_J
          • 9628
          A car battery needs a min of 13.8 volts to start charging, and usually the charging voltage is around 14.2 volts. +18 unloaded sounds about right
          • notallbad
            • Oct 2012
            • 1190
            Thanks Budm, used an alternative 12v supply.
            • notallbad
              • Oct 2012
              • 1190
              Thanks R_J, that also helps.
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                I assume this was a mains-transformer powered supply, if you say alternative. Learn about the peak voltage of a sinewave, which is 1.414 times its RMS value (which is what's printed on your transformer). So 230v mains will have 325v peak, and a transformer outputting 12v RMS will have a peak voltage of 16.9v
                With no load, a rectifier will charge a capacitor to the peak voltage of the AC supply. Under load the voltage drops and some AC will make its way on the output, this is called ripple. Ripple depends on the current being drawn, the power capability of the transformer and the size of the capacitor bank. Bigger capacitor, less ripple, higher average voltage. With ideal transformer, rectifiers and capacitor bank you would always have a DC level of the peak AC input, this does not happen in real life, of course. But with zero load, the voltage is extremely close to the peak.
                12v times 1.414 is ~17v, but also, a transformer is rated for a certain voltage output at a certain load, with light or no load voltage will be higher. That explains your 18 volts.
                A working TV? How boring!
                • notallbad
                  • Oct 2012
                  • 1190
                  Thankyou for taking the time to explain, it is appreciated.
                  I am trying to repair an electronic (sensorless) power steering pump.
                  It was continuously running after ignition switched off and drained the car battery. Battery good-around 11.8v(now recharged, alternator good- outputting around 13.8v.
                  Replaced 2 of the 4 MOSFETs BUK7608-55A (one showed signs of 'blowing', the other shorted between gate,drain and source.
                  Now it just keeps stopping and starting, 3-4 sec intervals.
                  The sensorless i.c which drives the motor (Elmos 10203C 28-pin) is presumably the culprit for shutting down the motor but to be honest I am not really sure what to check now. other than a few smd caps and resistors there isn't anything to test.
                  The pump takes battery feed and grounds to chassis and alternator output which acts as an 'on/off switch', pump only runs when the car is running.
                  If anyone can help please let me know though I know this site isn't really for car repairs so understand if no replies of advice.
                  • notallbad
                    • Oct 2012
                    • 1190
                    Photo of the pcb (taken from the web).
                    • quickname
                      Cyberpower 1500AVR UPS repair
                      by quickname
                      I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                      Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                      I decided to verify that the batteries were...
                      11-12-2023, 09:57 AM
                    • Instafixx
                      Macbook A2179 820-01958
                      by Instafixx
                      Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
                      The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
                      I checked the Power Sequences below and found this -
                      Once a valid external power source (Charger or battery) is connected, the following rails will come online.
                      PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
                      PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
                      05-20-2023, 05:19 AM
                    • Fernon@Repair
                      Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                      by Fernon@Repair
                      i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                      VCCIO voltage ok
                      VCCSA Voltage OK
                      VCCPLL Voltage OK
                      Ram Voltage ok
                      RamVTT OK
                      VPP 2.5 OK
                      But No Core Voltage
                      and i want to this vrm ic datasheet or pinout (ISL69269)
                      anyone have this ic pinout voltages?...
                      06-25-2025, 07:19 AM
                    • AJ847.63e
                      Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                      by AJ847.63e
                      Hi Folks,
                      Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                      I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                      The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                      05-06-2025, 10:37 PM
                      Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                      by sam_sam_sam
                      I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                      The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                      Now...
                      06-09-2024, 10:57 AM
