Recapped mobo effecting RAM?
  • BigAlNZ
    • Mar 2008
    • 65
    Hi guys,
    Hoping someone here can help.
    I had a computer with visibly bulging caps around the CPU. This was on a VIA P4PB 400.
    The Caps I replaced were 8 x GSC 2200uf 6.3v. After replacing these I tested the PC, the computer ran for two days without any problem. (Before it was rebooting every 60 minutes).
    I then was asked to upgrade the RAM from 512Mb to 2gig. I ordered the correct Kingston Memory for the PC in 2 x 1Gig sticks, and with ESD precautions put it in.
    Now heres where it got interesting - with the new RAM in it reboots just before the win xp welcome screen. Memtest showed the RAM was bad so i RMA'd it and got new RAM - but got the same fault!
    Given the chances of bad RAM twice in a row are very low, I am wondering if some of the other caps are bad?
    There are some other electrolytic ones around the CPU that visually look ok (GSC 1000uf 6.3v, GSC 1000uf 10v and GSC 1000uf 16v).
    Can anyone comment on wether I am frying this RAM? If so why is it happening to the 2x1Gig sticks but not the 2x512 sticks?
    Cheers
    -Al
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Recapped mobo effecting RAM?
    replace all gsc.
    what is happening is the caps on vdimm are marginal.
    1 stick it gets by.
    2 the extra load causes unacceptable noise/ripple.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      You are probably not actually damaging the RAM, it is just getting bad, dirty, noisy power because of the GSC craps.
      Mann-Made Global Warming.
      - Dr Seuss
      • BigAlNZ
        • Mar 2008
        • 65
        I think you are quite right about that! I put the RAM into my computer and it passed memtest, so the RAM itself it not damaged!
        • BigAlNZ
          • Mar 2008
          • 65
          Originally posted by kc8adu
          replace all gsc.
          1 stick it gets by.
          Yeah, that would sound about right. I am slowly but surely replacing all the electrolytic caps on the whole motherboard!
          I will post a photo, can you ID which caps are effecting the RAM?
          The green ones i have replaced. The red ones I have not replaced because I ran out of 1000uf 16v caps.
          I replaced the 3 1000uf 16v next to the RAM module first because I thought it might be enough to get it to load windows - but alas no!!
          FWIW the 512Mb is two sticks of 256, so its not a increase in sticks per se.
          -Al
          • shadow
            • Feb 2007
            • 732
            Hmmm. I don't think all the red caps run off a 12V line. The only thing that gets 12V on a motherboard is the AGP slot (that is as far as I know). It would probably be safer to replace them with 16V caps, however most likely you can get away with 6.3V caps for at least most of them.
            • gdement
              • Jan 2007
              • 690
              At the risk of sounding too cynical, I'd be concerned about the VIA chipset handling 2x 1GB memory modules. I don't think VIA leaves much margin in their specs, and you're right on the edge of them here. If the PSU/board aren't in optimal condition you've got a good chance of finding stability problems. Hopefully a more complete recap will fix it, but you might also be looking at a PSU limitation. Are your voltages looking okay in the BIOS? Adding heavier ram can drag the voltages down.
              Does a single 1GB work okay? Maybe you'll have better luck with 1.25-1.5GB total (using the old 256's).
              It's too bad VIA chipsets don't support registered memory, because that can be a good fix for load issues like this.
              Whatever you work out, to validate the fix make sure you run memtest86 for a few laps. Otherwise it might seem to work but you'll get occasional BSODs in the future.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                12v -> ISA, AGP, PCI, PCI-X, Fan headers, On a P4 board the processor.
                (I don't know which AMD made the switch to the 12v power rail.)
                - Dr Seuss
                • BigAlNZ
                  • Mar 2008
                  • 65
                  I recapped the whole mobo. Stable as now!
                  • BigAlNZ
                    • Mar 2008
                    • 65
                    Arrrrgh. I spoke too soon.
                    Initally it presented with 1 hourly reboots. Replacing the first set of caps fixed that, but when I went to upgrade the ram to 2gig I got the read/write memory errors.
                    So I replaced every electrolytic on the board.
                    It ran fine on the bench, memtest ok for 17 hours. I rebooted it several times and it was ok each time.
                    But when I started to put all the other cards in like modem and network it started either rebooting before windows screen or still comeing up with can not read / write to memory errors.
                    Initally it presented with 1 hourly reboots. Replacing the first set of caps fixed it, but now after repacing every electrolytic on the mobo the
                    Any other ideas? I am gonna try a new enermax PSU.
                    • Newbie2
                      • Sep 2005
                      • 885
                      Trying out a new PSU is what I would do, low-quality PSUs can cause reboots and other problems. There may be bad capacitors or other faults in the current power supply you're using.
                      My gaming PC:
                      AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                      ASUS M4A77TD AMD 770 AM3 Motherboard
                      PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                      G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                      TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                      WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                      ASUS Xonar DG 5.1 Channel PCI sound card
                      Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                      Antec Three Hundred Mid-Tower Case
                      Microsoft Windows 10 Pro 64-bit
                      Microsoft Windows 7 Ultimate SP1 64-bit
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        i would bet on a bad psu or a damaged card causing your problem.
                        open the psu and have a look.
                        better yet post pics.
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Vote 3 for change out the PSU.
                          And look at those cards too since they're out.
                          - Dr Seuss
                          • BigAlNZ
                            • Mar 2008
                            • 65
                            Enermax 420W or so be here tomorrow. Let ya know.
                            One more interesting thing is that the rear/write to memory errors happen when I go to shut it down. I let it get to the welcome screen where you click on a user, instead of logging on I click shutdown - thats when you get the read/write memory error.
                            Also it says instruction at <address> cannot reference memory at 0x00000000. Is 0x00000000 a valid address?
                            • BigAlNZ
                              • Mar 2008
                              • 65
                              Well I have tried the new PSU and something still "aint right".
                              It seems to boot ok, but while idle in windows it is regularly coming up with "Windows has recovered from a serious error".
                              And If I boot to the welcome screen but dont logon, and just click shutdown I get the memory cannot be read errors as above.
                              Tried two lots of RAM in varying slots too! No diff.
                              I give up!
                              • linuxguru
                                • Apr 2005
                                • 1564
                                For system/memory testing and/or burn-in, try using the Memtest option on the Ubuntu Linux Live CD. I wouldn't trust Windoze crashware/malware for a system test.
                                • BigAlNZ
                                  • Mar 2008
                                  • 65
                                  Well I just used one stick of 1Gig rather than 2x1Gig, and it seems stable....so far. Problems seem to occur when you use more than 1 stick?
                                  • Khron
                                    • Sep 2006
                                    • 1350
                                    • Finland
                                    Have you considered / tried a BIOS update? They usually fix CPU / RAM compatibility problems (if/when they get fixed). It just might work for you.
                                    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
                                    • gdement
                                      • Jan 2007
                                      • 690
                                      As far as I know that's valid - that's the beginning of memory. But I seriously doubt that the program was intended to read from address 0. Hardware might be to blame, but it could also just be a broken Windows install.
                                      When you get errors like
                                      "APP.EXE couldn't read from memory address 0xb1ab1ab1ab1ab1ab"
                                      it doesn't mean you have a hardware fault. It just means that Windows didn't allow the program to read/write to memory. A simple software bug can cause that - every program has a limited range of memory that it's allowed to use. If a program tries to access memory that it doesn't own, then Windows will block it, close the program, and display an error. Make a few mistakes while programming and you'll see that error a lot.
                                      This is partly a security feature, but it also keeps programs from crashing each other.
                                      The "couldn't read/write" message is reporting a software error - but glitchy hardware can (and does) indirectly cause it to happen.
                                      Sounds like you definitely have a load related issue. As you've seen, you should do your stress testing with everything installed. In fact, I prefer to jack up the frontside bus by 3-5% when testing, to ensure there's some stability margin.
                                      As long as you're in doubt about stability, it's best to do your testing in a simple, nonvolatile environment like memtest86. If it passes that (with all your cards installed) then move on to an OS. It's safer to use a bootable CD like knoppix, so you aren't putting the Windows installation at risk. If you use Windows, try Prime95 torture test. Under a linux CD, you can use MPrime (if you know how to use the command line).
                                      One more test in Windows is to run one of those 3DMark tests in a continuous loop. This puts lots of stress on machines with 3D accelerators in them.
                                      I think the utility "Sandra" has a torture test as well.
                                      Windows can have problems for all sorts of reasons, and since it's on your hard drive it's corruptible. Once Windows is corrupted you could continue to have errors even with perfect hardware.
                                      • Wizard
                                        • Mar 2008
                                        • 2296
                                        I just dumped 2 VIA boards after stripping it of good capacitors. One was 775 with intermittent crashing/corrupting and other one was socket 462 (chipset got flaky when at running temp).
                                        Go with SiS or Intel. I am starting to find Nvidia works but their driver is jinked, once I have funds, I'll replace the nvidia 6150 motherboard with a intel and HD3650 (it is used to output 720 and 1080 to allow us to do complete convergence job on 3 CRT projectors (rear projection in one unit) at our TV shop.
                                        Reason I said this is that blasted software on 6150 have bad habit of inconsistently working or not doing anything or partially even I kept tapping the keyboard to switch, even rebooting etc. Even resorted to reload the driver again and another driver version. Not trusty and it refuses to output if the port is not plugged in as I tend to switch back and forth often and sometimes LCD monitor wont take the resolution even same set up worked before forcing a reboot or jumping through many loops. :P
                                        Even I had good relationship with VIA on other boards in past but that were all 462 but I did have some issues with stablity and one doesn't turn off every time I shut down. Even with PII or PIII intel chipset I have no problem with this which is odd so I think it is really the bios and chipset quality design than the windows itself.
                                        Cheers, Wizard
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • jake-b
                                          dell e6540 boots to black screen (no dell logo)
                                          by jake-b
                                          good morning all,
                                          i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
                                          01-08-2024, 10:29 AM
                                        • Aimbit
                                          Xbox One Controller - Phantom stick activity (sticks completely uninstalled)
                                          by Aimbit
                                          Hi All,
                                          I bought some used Xbox one controllers "as is/untested" and they both have the same issue. The joysticks go wild for no reason while plugged in.
                                          https://youtube.com/shorts/YTYtjUPkBX0?feature=share
                                          I removed both joysticks assuming it was an issue with the sticks, but the video posted here is the activity of the sticks with no sticks installed! My only guess is one of the tiny IC's that reads the inputs is broken. There are two small ones near either joystick, and then one larger one. I found a replacement on Aliexpress for the larger one...
                                          02-15-2024, 11:26 PM
                                        • Cerberuska
                                          Mobo MSI B550-A PRO password popup
                                          by Cerberuska
                                          Hello guys,
                                          I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
                                          BIOS I updated to last one.
                                          any suggestions?
                                          And same thing for two different 5600G, and yes, MoBo supposed to support it.
                                          Thank you...
                                          11-10-2024, 01:23 PM
                                        • mrsith
                                          Dell G3 17 3779 - no display after mobo replacement
                                          by mrsith
                                          Hi guys,
                                          I have a friend's Dell 3779 that came to me with severely shorted mobo. Did not manage to isolate the cause, most likely that was a bga shorted. Went for a replacement motherboard. Got one from China, apparently it's been tested prior to shipping. The mobo starts up normally but I am getting no display whatsoever.
                                          Tried using external monitor, but being blind I am not sure if laptops goes as far as booting to Windows, a d without it I cannot get hdmi to work. Can't see boot menu options to make sure it boots to Windows. Went ahead and did a blind bios update,...
                                          04-30-2023, 05:11 AM
