Mobo MSI B550-A PRO password popup
  • Cerberuska
    • Mar 2022
    • 21
    Hello guys,
    I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
    BIOS I updated to last one.
    any suggestions?
    And same thing for two different 5600G, and yes, MoBo supposed to support it.
    Thank you
    • 31122
    interesting issue.
    try setting a password with the 7 and then put the 5 in - if it asks for the password you can ener what you set - then remove it after and reboot.
    see if it fixes it - though i dont know why going between a 5 and a 7 would do that.
    • Cerberuska
      • Mar 2022
      • 21
      Thank you for suggestion. I went to MoBo. Set password with ryzen 7, reboot with 7, same password screen, enter password and it unlock boot. Then I put 5600G, same password screen, but invalid password. Downgrade bios… still no luck. Never seen that.
      • DynaxSC
        • Apr 2021
        • 468
        • Poland
        Did you try to depower the board completely i.e. disconnect power cables and remove RTC battery ?
        Setting date in Bios, maybe there is some bug related with some bios setting just an idea ?
        Programming a stock bios with HW programmer, sometimes bios might be corrupted in some special way, and upgrading/downgrading might not help as it not necassarilly writes the complete bios image.
        • Cerberuska
          • Mar 2022
          • 21
          depowering I did try. No success. Looks like glitch, I spoke to msi, they want me to send MoBo to them to remove password. They are saying it is unusual. But paying shipping to US from Canada, it is not worth. So next step , I can try to reprogram bios thru programmer, but there is also EC. I tried set password for Admin, non erasable, but when 5600G is in, ignoring my set password. Then I removed password with Ryzen 7, then put back 5600G and still wants password. Ryzen 7 not require password, but when I put 5600G it requires password. I tried all different versions of bios thru flash options, thru button on the back without processor, or thru BIOS . Still same issue.
          I can desolder and solder Bios chip and try thru programmer.
          or maybe use Ryzen 7 , install windows and try to use some utilities.
          • DynaxSC
            • Apr 2021
            • 468
            • Poland
            Only logical conclusion is the 5600G works differently then the R7, maybe you found a bug in the AMD processor or the 5600G has really some minor demage in the computing logic and makes some errors in data processing.
            • Cerberuska
              • Mar 2022
              • 21
              I have two different 5600G different batch. Both working great in ASRock fatality. Friday I will do more investigation. Will pull up bios flash, clear it, program it using programmer and we will see. I will keep posted. Thank you for all support
              • Cerberuska
                • Mar 2022
                • 21
                Update: I removed Bios chip, erased it, and programmed with online bios from msi. And no more asking for password. Thanks for all suggestions and advices.
                • Nopslide
                  HP Omen 15-dh0052nf power-on & bios password
                  by Nopslide
                  Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                  My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                  Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                  04-01-2024, 04:27 PM
                • outsider
                  Panasonic FZ-G1 MK5 - BIOS password returning
                  by outsider
                  Hello
                  I removed the BIOS password thanks to the help of one of the friends of this forum.
                  https://www.badcaps.net/forum/troubl...61#post3637661
                  The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                  06-17-2025, 12:51 AM
                • snpetit
                  Asus FA706IH Bios Password remove
                  by snpetit
                  i need some help :-/
                  i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
                  Could you please remove all password related stuff from this bios. A hate Asus....
                  Thanks in advance!...
                  01-10-2025, 09:17 AM
                • BlackVisor
                  How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                  by BlackVisor
                  RedmiBook Pro 1542022 6800H
                  SKU: TM2113-39463
                  Model Number: RMA2204-AB
                  CMIIT ID: 2022AP1835
                  SN: 39463/22WD01355
                  BIOS version: RMARB5B0P1010 20230628
                  1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                  2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                  3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                  01-14-2024, 06:35 AM
                • RMDUiFT
                  Should I buy a Lenovo Thinkpad E495 with bios password?
                  by RMDUiFT
                  Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
                  I have a few questions:
                  • If I would buy this laptop and have
                  08-25-2024, 09:00 AM
