dell e6540 boots to black screen (no dell logo)
    good morning all,
    i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other observations:
    1. power + f2/f12 no longer provide a break to the boot process. when the problem first started i did manage to run the f12 diagnostics (including extended memory diags) and everything checked out ok. i have that output.
    2. the dell power supply has a light ring at the end of the plug that goes into the laptop. it remains lighted when powering the laptop. based on research that indicates that there is not a short on the high side power. if there was a short on the high side power the ac power supply shuts off and the blue ring no longer illuminates.
    3. during the boot up processes there are no beeps, no errors or messages displayed.
    4. the keyboard lights up when you press a key but not the small dot on the caps lock key when its engaged
    i did some minimally invasive troubleshooting steps, the most relevant are listed below:
    1. i changed the cmos battery which should clear cmos memory. rebooted and the same result. machine does not ask for new date/time which it should.
    2. i removed the dvd player, hard drive, wifi card and there is nothing else connected to it. rebooted and the same result.
    3. holding the "fn" key + power on runs a set of dell diags. the result i get is the battery light flashes white. per the dell user manual that indicates a "Memory failed to initialize or memory is unsupported." condition. it does not specify which memory (ram, bios, etc.). no new memory has been installed.
    4. swapped memory with a known good e6540. the known good e6540 boots with the failed e6540's memory, and the failed machine still fails to boot.
    5. the memory sticks in the failed e6540 do not feel hot to the touch so if a power problem it isn't a power short from a higher voltage. i believe that condition can occur when the first of two mosfets in series shorts.
    6. i removed both sticks and holding the fn key + power on results in a different set of flashing led lights indicating no memory was found. so the machine can still determine the hardware attached to it.
    at this point i have disassembled the machine exposing the mobo. its an impressive pile of small screws and plastic parts.
    my asks:
    1. any thoughts on a possible diagnosis given the data above?
    2. i have a pdf schematic and a brd file for a similar mobo (the la-9411p). i couldn't find the exact schematic on www.badcaps.org or www.alisaler.com. i'm hoping the 9411-p is close enough. ditto the brd file. if you happen to know where i might locate the files corresponding to the la-9413p mobo or if you think the ones i have are close enough, please let me know.
    3. this is my first foray into troubleshooting individual mobo components. i've watched a number of vids but i'm at that 'you need to take the first step' point. suggestions on where to start or a structured methodology to follow?
    4. i haven't upgraded the bios on this machine. i have on the 2 other e6540's i have. if installing a clean bios is the next step i have a ch341a usb programmer that i could use to flash the same E6540A27 bios i flashed to the other machines but am not sure what element name that would be in the brd file (so i could locate the bios physically on the mobo). i'm still exploring the basic functionality of allegro and can do some basic searches but with my limited use of allegro so far i've been unable to identify where the bios chip is located.
    it would be cheaper to buy a replacement mobo on ebay but thought this might be a good opportunity to learn a little more about troubleshooting methodologies at the board component level.
    thanks!
    To begin with measure reistance to GND on all coils as well as voltage on them.
      good morning mcplslg123 and thank you for the feedback,
      based on the mobo's brd file there are 21 coils (elements starting with "pl") on the mobo and unfortunately i lack an lcr to measure inductance. however, i will measure each with my dmm and convert to henrys and report back my findings. it would be a rough estimate of inductance but do you think that would be a close enough measure for diagnostic purposes? or should i bite the bullet and buy an lcr? if so any recommendation that fit in a modest budget?
      my going-in premise was that the issue i am seeing is somehow power related. at least that is what i concluded after i researched similar issues. only 1 of ~25 turned out to be a cpu issue. in addition to the 25, many of the "boot to black screen" issues appear to go unresolved.
      i identified the power networks to the dimms based on the mobo's pdf schematic. thinking the least likely way to cause additional issues was to probe those power networks on any exposed jumpers they may have, i cross referenced each network to the brd file to identify any exposed jumpers. i left the dimms in their sockets and powered on the mobo. i then measured the voltage at the exposed jumpers with my dmm and the result is as follows:
      jumper tested network test result
      pjp201 +1.35V_MEM 1.359v
      pjp202 +0.675V_DDR_VTT 0.681v
      pjp64 +3.3V_RUN 3.310v
      the values appear in line with expectations. i powered off then restarted and took the measurements again. same results. i'll pull the specs on the dimms to see if there are any other points i should measure.
      thanks again for your input.
      jake
        laptop now completes post. root cause was a corrupt bios. next step is to assemble the pile of parts back into a laptop.
        thanks.
          Hi Jake-b,
          I have an E6540 with a very similar problem and I know the post is nearing a year old now, but I was wondering if you could let me know how you flashed the BIOS to correct the problem? I have searched and found nothing on how to do it from a blank screen (the usual flash drive and a certain key combo). Strangely enough, the D-key and power performs the LCD test which shows good and I found by luck that pressing a function key and power gets me into the BIOS! Everything looks good, but there is no way to update the BIOS (on A27 anyway) from that menu. Once I exit, it's back to the black screen. I can even run their diagnostics and everything passes, but once I exit, it boots to a black screen. Any help would be greatly appreciated since right now, I have my own pile of parts.
          Thanks in advance,
          gsharpe
