How to Recondition (Reform) Electrolytic Capacitors and Why
This is a sticky topic.
    master hoarder
    • May 2008
    • 12190
    • Fixing stuff
    Okay, before I begin, let me note here that I am no expert on the matter. All of the info below is based on information that I found on the web, in capacitor datasheets, and some experiments I conducted myself.
    So what is electrolytic capacitor reconditioning (also known as reforming)?
    Basically, it is applying the maximum rated voltage on capacitor for a period of time. This is done in order to rejuvenate the electrolyte and/or aluminum oxide layer inside the capacitor.
    Which electrolytic capacitors should be reformed?
    - Ones that have been sitting in storage for a long time (regardless of whether they are new or used)
    - Used capacitors that came from a circuit, where the operating voltage was much lower than the rated voltage of the capacitor.
    Example: 6.3V electrolytic caps that were used on the CPU filter output of a motherboard (where the working voltage is often less than 1/3 to 1/4 of the rated voltage.)
    Why should electrolytic capacitors be reformed?
    According to Panasonic (information found in HFQ series datasheet):
    5. Long Term Storage
    Leakage current of a capacitor increases with long storage times. The aluminium oxide film deteriorates as a function of temperature and time. If used without reconditioning, an abnormally high current will be required to restore the oxide film. This current surge could cause the circuit or the capacitor to fail.
    Not only that, but a leaky cap (as in, capacitor with a high leakage current… not one that is physically leaking electrolyte) will usually trick your ESR meter to show lower ESR than what the capacitor may have. So if the cap has gone high ESR, your meter may not show it and you might end up putting a faulty cap back in service. To avoid this, check the capacitance of the cap. If it is higher than 20% of its specified capacitance, it is likely leaky and it is time to reform it. If you don't have an ESR or capacitance meter (like me ), then definitely reform it so there won't be any doubts.
    How to reform electrolytic capacitors:
    More from the same Panasonic datasheet:
    Capacitor should be reconditioned by applying rated voltage in series with a 1000 Ω, current limiting resistor for a time period of 30 minutes.
    I also saw some places online suggest to reform caps for 5 minutes (minimum) plus 1 minute for every month the cap was stored. Thus, as an example, a 4-year old stored cap would need to be reformed for 5 + (12 x 4) x 1 = 53 minutes. From my experiments, 2 hours seems to be good enough.
    Now, reforming only one capacitor at a time is slow. Therefore, building a “cap reformer” to recondition multiple caps at a time should definitely speed things up. And this is pretty much the goal of this thread – to show some simple working examples to build your own.
    There are more than a few ways to do this. In general, all you will need is a handful of resistors and something to let you connect and disconnect the electrolytic caps easily from the cap reformer circuit. I used a breadboard for this. And here is what my cap reformer looked like:
    (Note: I only have two caps in the above picture, but later I expanded my circuit to do up to 11 caps at a time.)
    You could also use a ZIF IC socket in place of the breadboard (thanks to Per Hansson for suggesting this idea to me). It will be both cheaper and easier to reform caps with short leads or leads that have excess solder (with a breadboard, the leads must be long enough to go down in the contacts and be clean enough to fit in the breadboard holes)
    So for the ZIF socket, something like this should do:
    http://www.ebay.com/itm/2PCS-NEW-Hot...cAAOxyjxlTKpxV
    Then, just wire your cap reformer circuit. Schematic below if you're not quite sure what to do here:
    In the circuit above, capacitors C1, C2, and C3 are the electrolytic capacitors that are to be reformed, while resistors R1, R2, and R3 are the series current-limiting resistors for each cap respectively. Of course, you can size your cap reformer to do as many caps at a time as you want. Just add a series resistor for every cap you add (i.e. continue the pattern to the right with the above circuit).
    As per the Panasonic datasheet again, the series resistors can all be 1 KOhm. However, according to some tests I did, it may be better to use higher resistances if the caps to be reformed are very old (as in, 10+ years in storage) or if they were used with a much lower voltage than their rated voltage (again, motherboard CPU caps should come to mind here), otherwise they may develop and internal short-circuit. For my reformer, I used mostly 10 KOhm resistors (but also tried a few 15 KOhm and 47 KOhm ones). Just about anything between 1 KOhms and 100 KOhms will work, since this is nowhere near exact science. From my experiments, however, the further you go above 10 KOhms, the longer it takes for the caps to charge (especially for ones over 1000 uF), and this will slow down the reform process or won't reform the capacitors to the maximum voltage you selected with the source.
    With that being said, if you find that some of your caps have not reached 90% of the source voltage after 30 minutes of reforming, then one of the following could be happening:
    (1) The series resistor has too large of a resistance for the capacitor it is reforming
    (2) The cap is possibly excessively leaky
    (3) A combination of the two above
    The best solution for this would be to lower the resistance of the series resistor. However, do NOT use less than 1 KOhms (except possibly for very large caps, like 400V, 500 uF… or 25V, 4700 uF). If the cap still does not reach 90% of the source voltage after this, you should test the cap's leakage current and compare to datasheet maximum (see Leakage Current thread). And if the cap shows only a few mV to 1V across its terminals after a minute or so of reforming – STOP! The capacitor has likely become short-circuited internally. Depending on your multimeter, you *may* be able to verify this by measuring the resistance. But don't count on it. I had a few caps short-circuit, and while some read as low as just several Ohms, one read 1.8 KOhms (which is far from a short-circuit… but if you put this cap in a device and apply power, it will likely short almost immediately. Some of mine did when I used a lower series resistor.)
    To be continued... (10000 characters limit)
    master hoarder
    • May 2008
    • 12190
    • Fixing stuff
    Re: How to Recondition (Reform) Electrolytic Capacitors and Why
    Part 2... continued from above.
    Anyways, the last part in the above schematic is the source, V1. It should provide a voltage as close as possible to the capacitors' rated voltage (but not higher than that.) Because of the series resistors, the caps won't draw much current, even when they are fully discharged. So a few milliamperes (mA) should be more than enough in most cases. If you are using a standard power adapter, you need not worry about the current, as even the smallest adapters are usually capable of at least 100 mA.
    Which brings me to my next point: what to use as the source.
    If you tend to hoard junk like me, you probably have a stash of spare power adapters rated for various voltages. For reforming 6.3 V, 10 V, and 16 V caps, for example, I used power adapters rated for 5 V, 9 V, and 15 V respectively – not ideal, but still fairly close to what the caps are rated for. Of course, keep in mind that the output voltage of many adapters varies with the load. On that note, be especially careful with linear adapters, because they output a much higher voltage when unloaded (for example, I have a linear power adapter also rated for 9 V DC, but it actually outputs 16.5V when unloaded). This matters, because the capacitors (that are to be reformed) won't draw much current once they charge up. So the power adapter may supply higher voltage that what is called for. Therefore, always measure the actual unloaded output voltage of the power adapter before using it.
    An alternative to using many different power adapters is to use a single laptop power adapter and build some kind of circuit to regulate the voltage output (but keep in mind that most laptop adapters output 16 to 20 Volts, so reforming will be possible for only 6.3 V, 10 V, 16 V, and maybe 25V caps.)
    The simplest way to scale down the output voltage of the laptop adapter is do build a voltage divider circuit with a few resistors. The three voltage divider circuits below show how to get 6.23 V, 9.75 V, and 15.35 V with some common resistor values from a 19.5 V adapter.
    Simply hook the output of these voltage dividers in place of V1 in the first diagram.
    Note: the 1 KOhm resistors used in the above diagrams should be rated for at least ¼ Watts and preferably ½ Watts if you don't want them to run too hot.
    Another thing to mention: if you feel that the above voltages are too close to the capacitors' maximums, you can always add a loading resistor across the voltage divider's output to lower the voltage. The circuit schematic below shows this:
    Here, the loading resistor is R_load and it is chosen as 10 KOhms. With this resistor, the output voltage of the above voltage dividers will drop to 6.04 V, 9.28 V, and 15.03 V respectively. However, it is very likely that you won't need to do this, because the current draw by the caps (due to their leakage current) should already make those output voltages above to drop lower. Also, the series resistors should prevent damage to the caps, even if the voltage does go slightly above their maximum rated. On that note, it should be mentioned that many electrolytic capacitors can withstand (for a short period of time) a surge voltage up to 20% higher than their rated maximum voltage. Therefore, if you run a 6.3 V-rated cap at, say, 6.4 Volts, it is unlikely that it will pop.
    And finally, if you want to avoid playing around with voltage dividers and different power adapters, you can always just use a potentiometer in place of the two resistors in the voltage divider circuit. This would allow the voltage to be adjusted anywhere between 0 and your adapter's maximum voltage. However, the only thing I will mention here is to pay attention to the potentiometer's power handling capacity. If you want to use a 1 KOhm potentiometer with a 19.5 Volt laptop adapter, then the potentiometer should be rated to handle at least ½ Watt. Note that this will be a rather big pot. If you use a 2 KOhm pot or higher resistance, then that rating can be ¼ Watts. And for 4.7 KOhms and above, 1/8 Watt will do. But as you go higher in the potentiometer resistance, this will also decrease the current that will get to your cap reformer circuit. So you shouldn't really go too high or too low on the potentiometer resistance. 2.2 to 4.7 KOhms is probably a good middle ground.
    For how long can I store my reformed capacitors?
    I can't say for sure. It likely varies for different capacitor brands and series. Many datasheets will specify a Shelf Life where the capacitor is guaranteed to meet specs after X number of hours in storage at Y °C. This is typically 500, 1000, and 2000 hours at 85 or 105 °C. (However, a few datasheets note this to be true only after capacitor "pre-treatment" [i.e. reforming] to the full DC working voltage for 30 minutes.)
    The above statement then probably brings the question: what about storing capacitors at a lower temperature and will that help?
    - That, unfortunately, is another item that is not specifically mentioned in any datasheet I have seen so far. Therefore, I cannot answer. Panasonic does state the following, though:
    5.1 Environmental Conditions (Storage)
    Capacitors should not be stored in the following environments.
    (1) Temperature exposure above 35°C or below 15°C.
    (2) …
    So my only *guess* would be that the shelf life works similar to the capacitor's expected lifetime – i.e. it doubles for every 10 °C drop in temperature. If that is the case (and that is a really big IF there), then a cap rated for a shelf life of 500 hours at 105 °C should be guaranteed to be “like new” for *at least* 8000 hours (which is roughly 11 months) in storage at 25 °C (after 30 minutes of reforming, of course).
    I don't know, but this does seems to make sense to me. A few years back, I was able to borrow an ESR meter (ESR Micro v4) from a friend, and I tested caps in my “good” stash. Many were at least a few years old, but they all tested okay for both ESR and capacitance. So I think there is some merit to my assumptions above. Moreover, when I was experimenting with the cap reformer, I noticed that I was able to “restore” back some caps that wouldn't want to hold a voltage higher than the circuit I pulled them from (notably some CPU caps that had 1.5 Volts across them their entire life in circuit). After reforming, now I can charge them to any voltage and they will stay there for a good few days before discharging.
    So I think the bottom line is: it is okay to keep caps in storage for a year or two. But if you want to make sure that the caps' specs don't deteriorate at all from the factory, then consider reforming them every year or two (again, that depends on what the datasheet for your caps recommends.)
    That is all from me (really, only a tiny four and half pages in MS Word ). Again, I am no expert on this matter, so if anyone finds any mistakes or has any suggestions, please feel free to share them here.
    • linuxguru
      • Apr 2005
      • 1564
      Great write-up and cool stuff - the idea of using a laptop 19.5V supply as a single supply for a number of different voltages is clever and practical. You may also want to recap the adapter with good caps if possible.
      • mockingbird
        • Dec 2008
        • 5489
        momaka -
        Thank you very much. I have to go and pay my credit card bill now, but when I come back I intend to read this in depth and start ordering parts to construct the jig.
        • mockingbird
          • Dec 2008
          • 5489
          So I measured my variable wall-wart:
          Here are the unloaded voltages I got:
          1.5V setting - 3.3V
          3V setting - 5.11V
          4.5V setting - 7.25V
          6V setting - 9.28V
          7.5V setting - 11.47V
          9V setting - 13.70V
          12V setting - 18V
          I'm going the 1/2 watt potentiometer route for now. In the future I hope to build something more permanent with voltage dividers specifically for my wall-wart (ideally I'd like to run a macro in LTSpice which calculates voltages based on different resistor values, but I can't find a way to introduce an AC voltage source into the program).
          Here's my shopping list so far, am I missing anything?
          It occurs to me that the wall-wart isn't that great of an idea, and I'd be better off using a laptop adapter. I've got one that does 24V, so it would be good for 25V caps, and I'd be able to do more than 10 at a time - at most with the wall-wart which only has a max of 300mA.
          Now assuming I've got two of those ZIF sockets with 14 caps on each, that's 28 caps drawing let's say an average of 30mA each, still less than an amp.
          Would the 1/2 watt pot be sufficient for this kind of load?
          • goodpsusearch
            • Oct 2009
            • 2864
            • Greece
            To be honest I never bothered doing that. My rule would be that if a cap can't do its job without reforming then the cap is bad..
            • Sparkey55
              • Jan 2010
              • 1523
              • Hunting tRumpers.
              Keep thinking that when one or more caps blow up in your face some day!
              • mockingbird
                • Dec 2008
                • 5489
                It's not a question of "if it needs re-forming it's not good", but rather a question of extending the life of modern electrolytic capacitors to behave within spec for 20+ years after their expiration date.
                If you re-form your caps, they will last forever. If you don't you will be throwing them out and buying new ones every few years. As simple as that.
                  That wall wart transformer output is not regulated so the output will go up and down with the AC input variation, I would use regulate power supply, you can use LDO regulator and use the pot in the resistor network for setting the output Voltage to adjust for the needed output, and the pot does not have to be high Wattage.
                  Subscribe to support us and access our Bios, Boardview, schematic search. It only takes 1 minute:
                  https://www.badcaps.net/settings/subscriptions
                  • mockingbird
                    • Dec 2008
                    • 5489
                    I just ran this simulation in LTspice with 28 caps (two 14-pin ZIF sockets), and it's only showing a 79nA (read: nano) draw per cap. Is that right? Maybe 1kOhm is too much?
                    Attached is the LTSpice file if you care to take a look.
                      The current draw is dictated by the load resistance so if the spice model of the cap has infinite resistance then you will not see the current draw after the cap is charged up and the spice model of the cap no leakage resistance. Simulator is only as good as how the spice model is created.
                      it is not the 1K resistor.
                      • mockingbird
                        • Dec 2008
                        • 5489
                        You're right. I'm working on the model now. I've got to learn how to use the program properly, like specify polarity with caps. It's easy when you use from their list of parts, but when you input your own it can't be taken for granted.
                          Spice model is very complex: I.E.
                          http://www.nichicon.co.jp/english/pr...ice/index.html
                            master hoarder
                            • May 2008
                            • 12190
                            • Fixing stuff
                            If you get a 1 KOhm pot and are planning to that 24 V power adapter, then the pot should be rated for 1 Watts. Calculations:
                            power draw P = (V^2)/R = (24^2)/1000 = 24 • 24 / 1000 = 0.576 Watts
                            An alternative would be to use a 1.5 KOhm (or higher) 1/2 W potentiometer.
                            In the future I hope to build something more permanent with voltage dividers specifically for my wall-wart (ideally I'd like to run a macro in LTSpice which calculates voltages based on different resistor values...)
                            You don't need LTSpice or any other program to do those calculations for you. If you can add, subtract, multiply, and divide, then you can build simple voltage dividers like I did in post #2 above. The formula is simple:
                            V_out = V_in • (R2 /(R1 + R2))
                            where V_in is the input voltage of the power adapter (same as source V1 above), R1 and R2 are the voltage divider resistors, and V_out is the output voltage you get.
                            There are millions of combinations of resistors you can use to get a certain voltage. However, just watch out so that you don't overpower any of the resistors (i.e. force more than 1/2 W through a 1/4W resistor, or something like that). In general, if you are using an adapter of 18 V or above, then try to keep the sum of the resistance of R1 and R2 above in the 1-10 KOhm range.
                            Why would you need an AC voltage source? Reforming capacitors is done with a DC source only.
                            Looks fine.
                            Are you wire wrapping everything, by the way?
                            Not sure where you are getting the 30 mA power draw from, but the leakage current of a *working* (i.e. not shorted) capacitor will be much less than that once the cap has charged up: usually 10-300 uA (0.01 to 0.3 mA) and occasionally up to 1 mA (for the really leaky caps). It all depends on how old the cap is and how much it has been abused. See this thread about leakage current:
                            https://www.badcaps.net/forum/showth...499#post609499
                            That said, a *fully discharged* capacitor will draw a *peak current* that is limited by the current-limiting series resistor.
                            Example: 25 V cap that is to be reformed with a 1 KOhm current-limiting series resistor and 24 V power adapter.
                            Peak current draw:
                            I_peak = adapter voltage / series resistor resistance
                            I_peak = 24 / 1000 = 24 mA
                            If you are reforming 10 caps at a time with the same as the above configuration, the power draw will be 24 • 10 = 240 mA.
                            *However*, as the caps charge up, the voltage across them will rise. The current draw for each cap after the initial I-peak current will then be:
                            I = adapter voltage - voltage across cap / series resistor resistance
                            Let's assume the voltage across the caps has gone up to 10V after a few moments. Then:
                            I = 24 - 10 / 1000 = 14 / 1000 = 14 mA
                            Depends on what you have as the series resistor resistance. The pot will likely burn out if you use 1 KOhm series resistors and do several caps at a time. If you use 10 KOhm series resistors, however, the pot might be able to handle up to 10 caps at a time. Note that I haven't done any "hard" calculations on this, though. But a 1/2 Watt pot will not be able to handle as much power as two separate 1/2 Watt resistors in a voltage divider.
                            Well, let's say you find some really old equipment (like an old amp, for example) and can't find replacement caps or the cost of new ones is too much, then reforming the old ones might be a good idea before plugging the device in and applying power.
                            I already shorted out a handful before I started experimenting with the cap reformer, so this is definitely something useful to have IMO. I am actually planning to eventually reform all of my caps I have in stock in stock.
                            Exactly.
                            This is why sometimes electrolytic caps are also referred to as "self-healing", meaning that their specs can be brought back simply by applying power to them.
                            Indeed. Generally, that's how I would do it too, but I only mentioned the simple resistor voltage dividers above to keep costs and complexity to a minimum so that even people with little electronics knowledge can build this.
                            ...you will not see the current draw after the cap is charged up and the spice model of the cap no leakage resistance. Simulator is only as good as how the spice model is created.
                            Yes.
                            Also, on that note, caps of various voltages, capacitances, and age will have different leakage currents. A program model, on the other hand, will likely assume new caps and some average leakage current value (if any at all!) So current draw in steady-state (i.e. after the caps have charged up) will likely not be accurate at all in the model.
                            • mockingbird
                              • Dec 2008
                              • 5489
                              Ok got it.
                              Yes, I ordered a bunch of 1/2 watt resistors ranging from 1K to around 60K I think.
                              I'm trying to create a graph of voltage drop on a rectified transformer based on current draw. I've got to refresh my knowledge on how to macro with LTSpice.
                              Looks fine.
                              No I'm soldering everything, but I'm using wire-wrapping wire because it's solid core. Also that's what I thought you were using on your breadboard, and I thought it would be a convenient way of placing/pulling jumpers on a breadboard I might purchase in the future other than using bona fide jumper wires.
                              I think I'll not do more than 10 caps at a time, because I don't want to have to use such a large potentiometer at the source. I think the best way I'll clear things up for myself is if I spend some good time sitting at a desk with all the parts in front of me and extrapolating everything you're saying for myself. That usually helps clear my fog.
                              Thanks again.
                              • ChaosLegionnaire
                                HC Overclocker
                                • Jul 2012
                                • 3298
                                • Singapore
                                thanks. very nice article. i have a hoard of sanyo wgs that were made in 2006 and also a breadboard from an electronics workshop i attended waaay back in middle school. havent used that breadboard in decades. hope that breadboard is still good and hasnt rusted, corroded or shorted. i'll wanna use it to reform those sanyos. don't want one of my favourite caps blowing up during actual use...
                                Exactly.
                                does that mean if i had caps that have gone bad due to abuse, they can be "repaired"? cuz i have some panny FJs that went bad due to a high ripple psu killing the caps. none of them showed signs of bloating. will reforming "repair" those ripple dmged caps? i assume failure without bloating is actually a good sign it can be repaired because the hydrogen gas discharge didnt get out of control for the gas inhibitors?
                                • mockingbird
                                  • Dec 2008
                                  • 5489
                                  From what I've gathered from Momaka's great info, it's touch and go.
                                  Start re-forming and keep an eye on the voltage. If the cap's voltage isn't rising along with your own incremental adjustments, then the cap is no good.
                                    master hoarder
                                    • May 2008
                                    • 12190
                                    • Fixing stuff
                                    Probably not.
                                    How did you conclude that they are bad? ESR+capacitance meter?
                                    Generally, if the caps read high ESR (or above normal ESR), they are done.
                                    However, if the capacitance isn't too out-of-tolerance on the high side, this usually indicated high leakage current, which might be reversed somewhat with reforming.
                                    Not really.
                                    Failure without bulging means the gas probably escaped slowly over time or the electrolyte dried up from heat. A lot of small 5x11 caps die this way. Can't revive them.
                                    The only *real* success I've had with reviving a completely blown cap was by adding water to a popped Sacon FZ. Don't ask why I did that... let's just say I was really bored on a rainy day .
                                    The leakage current was very high afterwards, but I guess capacitance (and possibly ESR too) must have come to spec. Worked fine for speaker DC decoupling, driving a 6 Ohm speaker.
                                    Couldn't believe it when I saw it and couldn't stop laughing for a good 5 minutes either .
                                    That's Sacon FZ for ya!
                                    • watchmaker
                                      • Aug 2011
                                      • 6
                                      • Ukraine
                                      It was true only for Russian 80s..90s electrolytic capacitors (but not always), not for modern ones. Many modern capacitors (especially not too good ones) simply die (sometimes even vent or pop) in storage.
                                      • mockingbird
                                        • Dec 2008
                                        • 5489
                                        Finally put an order in for my parts.
                                        Can't wait till it gets here.
                                        • madscientist750
                                          Replacing electrolytic caps by solid caps on old motherboards
                                          by madscientist750
                                          I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                                          I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                                          I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                                          10-19-2025, 06:10 AM
                                        • Perry Babin
                                          Electrolytic cap endurance
                                          by Perry Babin
                                          From what I've found, the endurance of a liquid electrolytic cap is determined by the loss of electrolyte. If a cap is rated for 1000 hours. That's typically for a straight run test. How would the life vary if the cap is intermittently heated to its rated temperature (105C). Maybe for an hour at a time then cooled back to 30-40C (just a random number). Would the life still be 1000 hours?
                                          Does it make a difference in the life expectancy if the cap is heating from ripple current (internal heating) instead of from the external ambient temperature?
                                          Why do polymer capacitors...
                                          10-18-2025, 05:21 PM
                                        • Perry Babin
                                          How do organic polymer caps compare to liquid electrolytic for reliability
                                          by Perry Babin
                                          I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
                                          If not organic polymer, what would be the caps that could take the most abuse?
                                          08-18-2025, 04:04 PM
                                        • ten-d
                                          Nippon Chemi-con 100uf 100v BP electrolytic cap
                                          by ten-d
                                          Hi all!
                                          I just bought a pair of ADS L810 speakers, which I've heard are some of the best speakers from that time (late 70's) into the early 80's. I was super excited to test them out and hooked them up and I was very underwhelmed by the treble. The treble was awfully muffled. I've been doing some restoration work on 70's stereos and a couple of speakers here and there so I am really just a beginner. I do know that capacitors in speaker crossovers filter out the lows to allow only the highs up to the tweeters and mids. Inductors filter out the highs to allow the lower frequencies to...
                                          01-30-2024, 05:18 PM
                                        • Adenitz
                                          Replace electrolytic cap with bipolar one
                                          by Adenitz
                                          can I use this cap:
                                          https://www.tme.eu/en/details/ues1h4...tors/nichicon/
                                          Capacitor: electrolytic; bipolar; THT; 47uF; 50V
                                          to replace this capacitor: Electrolytic Radial E 47uF/50V 6.3x11 RM2.5 105°C Jamicon
                                          What exactly I can expect to install bipolar electrolytic cap instead a regular one?
                                          Thanks.
                                          02-02-2022, 07:44 AM
