How do organic polymer caps compare to liquid electrolytic for reliability
  • Perry Babin
    • Apr 2024
    • 22
    • usa
    I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
    If not organic polymer, what would be the caps that could take the most abuse?
    • 31255
    you can try polymer but the source may not like the super-low esr.
    or you can use parallel low-esr electrolytics with a ceramic .1uf cap soldered across the legs to remove high frequency spikes.
    this is how early switching psu's where designed before we had low esr caps.
    • Perry Babin
      • Apr 2024
      • 22
      • usa
      The source is a 12v car battery/charging system that's driving one or more amplifiers that can draw more than 100 amps of current.
      Currently, there is a 0.1uf in parallel with the 330uF.
      Thanks for the input.
      Have you seen the organic polymers cause any problems like failing shorted, or anything else that you wouldn't see with standard electrolytic caps?
        • 31255
        polymer dont usually fail unless you go over-voltage or reverse the polarity - then they can go short-circuit.
        • silver60618
          How to clean Liquid Metal from under CPU?
          by silver60618
          Hi all, Im working on a board, that my customer brought to another shop, and smeared liquid metal all over the board.
          The laptop powers on, then shuts off. I noticed traces of Liquid Metal near the edge of the CPU, but I fear some maybe underneath.
          Has anyone ever tried Ultrasonic cleaning, or compressed air to remove or agitate the liquid metal?
          07-11-2025, 01:47 PM
        • Hondaman
          Liquid cooling?
          by Hondaman
          I hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
          (After previous generation hardware [Gigabyte] didn't...
          05-08-2025, 09:37 PM
        • kurland
          Strange liquid on damaged GTX1080 card
          by kurland
          I'm fixing a GPU card for a streamer, was sent to me by mail. A shorted cap on a power rail has severely burned the PCB.
          As you can see from the darkened PCB around the mosfets there are signs of liquid damage. But it's odd because the person says no water has entered the PC cabinet. If you spill something on a desktop you would know I guess...
          Funny thing is that the liquid is not only on the PCB but on top of many chips which are tightly covered by thermal padding under the heatsink, even on top of some of the RAM chips
          11-17-2020, 07:14 PM
        • av4x
          Fujitsu U7511 liquid damage, wont turn on anymore, does not respond to charger in any way.
          by av4x
          Good morning, everyone!
          I've gotten my hands on a few laptops with various defects because I want to get more involved in repairing electronics.
          First up is a Fujitsu Lifebook U7511.
          It won't turn on anymore and doesn't respond in any way when you plug in a power adapter.
          Model: Fujitsu Lifebook U7511
          CPU: Intel Core i5-1135G7
          GPU: Intel Iris Xe Graphics
          RAM: 16GB DDR4 - 3,200 MHz
          PCB manufacturer: ASKPCB?
          PCB serial numbers: CP801602, CP7984241-Z4, E239218, CP809978-01
          Damage: Liquid damage
          The liquid probably...
          Today, 03:09 AM
        • mitchw
          MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
          by mitchw
          Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
          It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
          I quickly took it apart and washed the liquid residue off the mainboard.
          The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
          The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
          Now the laptop...
          07-16-2025, 07:55 AM
