Cap self-recharging
  • Marko7
    • Jun 2014
    • 8
    Cap self-recharging
    Hi folks,
    Ya know, for years I've always wanted to know just how an electrolytic capacitor, especially a Hi-V filter type, can seem to "recharge" itself after a full drain via a temporary short across it's leads...
    In other words, what kind of chemical action or re-action- or other electrical phenomena- accounts for, say, a 22uF/ 500 volt filter cap which is *removed* from any circuitry (isolated) developing up to several measurable volts across it's plates (leads) if it's been in service for some time?
    An E.E. assistant college professor said it was beyond the scope of the current material when I quized him 1 day during class. I never did follow up on it.
    Ah figgered this forum might be the best place to pose the riddle.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Cap self-recharging
    Most likely case is that your meter charges the cap when you measure it.
    • SteveNielsen
      Retired Tech
      • 2327
      My understanding is that momentarily discharging a cap does not completely zero-out the chemical imbalances inside the cap that create and maintain the ability to hold a charge.
        http://mysite.du.edu/~etuttle/electron/elect53.htm
        https://cdn.badcaps-static.com/pdfs/...f439032f62.pdf
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          I have noticed this on an online type UPS.
          • SteveNielsen
            Retired Tech
            • 2327
            Might gain some insight in this thread:
            http://electronics.stackexchange.com...ergy-over-time
              • 31054
              it's probably charging up from the energy field around it.
              we are swimming in RF, i see no reason it cant collect on a suitable antenna such as the foil roll in a cap.
              if you can pull current from the air with a crystal radio - why not a cap.
              i bet nikola tesla could explain it!
              • Marko7
                • Jun 2014
                • 8
                Steve, You might be the closest so far.
                It certainly doesn't charge from the voltmeter, Per, as they "drain" the source- to varying degrees- due to the impedance of their input. (VTVMs or "vacuum tube voltmeters", were the highest input-Z meters out there for a LONG time and presented a load no more than a couple megohms, if that.)
                Nope, stj, i think any & all EMF fields "permeating" the cap would both charge & discharge the cap, as it is all essentially A.C., resulting in a cancellation of any added DC charge.
                The phenomena can be easily duplicated (viewed) by *carefully* charging up a *new* 450 or 500 volt filter cap, that starts out with a trace charge in the milliviolt range (after a quik discharge)... applying near full voltage (say 430 VDC- Be Careful!!) from a power supply, & let it sit hooked up & floating overnight.
                Then disconnect the cap in the morning, carefully DIScharging it to zero with an appropriate resistor, maybe a 470 ohm power Resistor.
                Leave the it connected for a few minutes, verify 0 volts, & then disconnect the resistor.
                I *guarantee* that you'll measure several volts, maybe even 10 or 20 volts, after letting it sit & "self-charge" for a few minutes. Not sure if non-electrolytic caps like large mylars will do this, but the electrolytics sure do!
                • Marko7
                  • Jun 2014
                  • 8
                  Steve, et al:
                  On the webpage you linked us to, Tony Stewart posted:
                  "On large electrolytic caps, like "main-frame" computer grade 100,000uF and TV HV 10uF 25KV doubler Caps, power supplies there is a phenomena like in batteries, known as memory. After you short it out the voltage creeps back. That's all you need to know. Short it long enough to discharge the memory effect."
                  Hmmm... All I need to know, huh? ("But wwhhyyyyy??", markie cried.)
                  P.S: I've discharged some old caps in gee-tar' amps for a couple minutes, dead-shorted, & gotten enough juice back across their plates after a half hour to light up a #47 lamp (briefly)!
                    • 31054
                    here's a test.
                    put a resistor across one for 24hours.
                    then leave it without the resistor for a day or 2.
                    then check it.
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      http://en.wikipedia.org/wiki/Dielectric_absorption
                      • joshnz
                        • Feb 2011
                        • 969
                        • New Zealand
                        This was mentioned on eevblog
                        My pc
                        CPU : AMD PHENOM II x4 @ 3.5Ghz
                        MB : ASUS M4A89TD PRO USB3
                        RAM : Kingston ValueRAM 16gb DDR3
                        PSU : Cooler Master 850W Silent Pro
                        GPU : ATI Radeon HD 6850
                        • Marko7
                          • Jun 2014
                          • 8
                          Thanx, kc8 ! didn't figger Wiki had an actual page on the phenomena.
                          • cheese007
                            Input Filter Filling: How to Choose Components?
                            by cheese007
                            Recently acquired one of those silly Logisys acrylic power supplies and lucked into getting one of the "better" ones (most of an input filter, bridge rectifier instead of 4 diode treatment, OK-sized heatsinks, etc.) and wanted to fill out what I can on the board + get some decent caps on there (especially the primary side since I highly doubt the ones in there are actually 1000uf). My questions are:
                            1. How do I know what components to install re: the input filter? It seem to be missing an X cap, a resistor, and a Y cap.
                            2. Where can I find a good heatsink for the bridge...
                            12-06-2023, 09:59 AM
                          • PennyLane
                            Trying to locate a capacitor for a Skytec Crossover filter
                            by PennyLane
                            Hi
                            I'm trying to locate what i believe to be Radial Electrolytic Capacitors 100v 82uf Non-polar for a Skytec Crossover filter.
                            02-19-2025, 06:47 AM
                          • J_T
                            Operating frequency for motherboard common mode inductor/filter
                            by J_T
                            I have a question - I have replaced the PSU on my own iMac Pro. However, when removing the motherboard I knocked of a 120 OHM 30% 0.3A small surface mount common mode inductor/filter (~0602 size) in the ethernet circuit near the female RJ45 port.
                            The closest match I can find on Mouser is 120 OHM common mode inductor at 100MHz - my question is this frequency correct for a motherboard? The schematic for the motherboard only provides '120 OHM 30% 0.3A' and the TDK part number does not return anything in google.
                            Sorry, I am not experienced hence a basic question.
                            01-04-2025, 05:54 AM
                          • acedogblast
                            Power supply for main amp blows fuses after replacing filter caps.
                            by acedogblast
                            Hello I have a Marantz sr5012 that I have been repairing. After I have replaced the 2 main filter caps the 2 fuses for the power amplifier blows. The original capacitors are ELNA LAO 10,000uF 71V and the replacements are Nichicon LKS 10,000uF 80V.
                            I assume a short circuit connection has occurred so I set my multimeter to measure ohms across the 2 fuse connections and both read 55 Kilo-ohms so I assume that is ok.
                            I am certain that I do not have any bridges on my soldering and after probing around I do find a temporary 0 ohm reading when probing across the positive and negative...
                            02-27-2023, 05:11 PM
                          • grimacelord
                            Pioneer VXS-D902S Reciever - Filter Capacitor Question
                            by grimacelord
                            I have a Pioneer VSX-D902S receiver that I am trying to replace the 2 large 8200uF 80V filter capacitors on.
                            I have already removed the capacitors and ordered replacements, but I made a mistake in ordering. The original capacitors are Pioneer ACH1202 80v 8200uF and have 4 pins. The capacitor replacements I bought are Nichicon 80v 8200uF and only have 2 pins.
                            I was wondering if I could still use my replacements even though they only have 2 pins. Obviously I'd have to extend the pins of the capacitor to allow them to reach and fit through the...
                            01-12-2023, 02:40 PM
