Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
Cap self-recharging
  • Marko7
    • Jun 2014
    • 8
    Cap self-recharging
    Hi folks,
    Ya know, for years I've always wanted to know just how an electrolytic capacitor, especially a Hi-V filter type, can seem to "recharge" itself after a full drain via a temporary short across it's leads...
    In other words, what kind of chemical action or re-action- or other electrical phenomena- accounts for, say, a 22uF/ 500 volt filter cap which is *removed* from any circuitry (isolated) developing up to several measurable volts across it's plates (leads) if it's been in service for some time?
    An E.E. assistant college professor said it was beyond the scope of the current material when I quized him 1 day during class. I never did follow up on it.
    Ah figgered this forum might be the best place to pose the riddle.
  • Per Hansson
    • Jul 2005
    • 5897
    • Sweden
    Re: Cap self-recharging
    Most likely case is that your meter charges the cap when you measure it.
    • SteveNielsen
      Retired Tech
      • Jun 2012
      • 2327
      My understanding is that momentarily discharging a cap does not completely zero-out the chemical imbalances inside the cap that create and maintain the ability to hold a charge.
        http://mysite.du.edu/~etuttle/electron/elect53.htm
        https://cdn.badcaps-static.com/pdfs/...f439032f62.pdf
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          I have noticed this on an online type UPS.
          • SteveNielsen
            Retired Tech
            • Jun 2012
            • 2327
            Might gain some insight in this thread:
            http://electronics.stackexchange.com...ergy-over-time
              • 31490
              it's probably charging up from the energy field around it.
              we are swimming in RF, i see no reason it cant collect on a suitable antenna such as the foil roll in a cap.
              if you can pull current from the air with a crystal radio - why not a cap.
              i bet nikola tesla could explain it!
              • Marko7
                • Jun 2014
                • 8
                Steve, You might be the closest so far.
                It certainly doesn't charge from the voltmeter, Per, as they "drain" the source- to varying degrees- due to the impedance of their input. (VTVMs or "vacuum tube voltmeters", were the highest input-Z meters out there for a LONG time and presented a load no more than a couple megohms, if that.)
                Nope, stj, i think any & all EMF fields "permeating" the cap would both charge & discharge the cap, as it is all essentially A.C., resulting in a cancellation of any added DC charge.
                The phenomena can be easily duplicated (viewed) by *carefully* charging up a *new* 450 or 500 volt filter cap, that starts out with a trace charge in the milliviolt range (after a quik discharge)... applying near full voltage (say 430 VDC- Be Careful!!) from a power supply, & let it sit hooked up & floating overnight.
                Then disconnect the cap in the morning, carefully DIScharging it to zero with an appropriate resistor, maybe a 470 ohm power Resistor.
                Leave the it connected for a few minutes, verify 0 volts, & then disconnect the resistor.
                I *guarantee* that you'll measure several volts, maybe even 10 or 20 volts, after letting it sit & "self-charge" for a few minutes. Not sure if non-electrolytic caps like large mylars will do this, but the electrolytics sure do!
                • Marko7
                  • Jun 2014
                  • 8
                  Steve, et al:
                  On the webpage you linked us to, Tony Stewart posted:
                  "On large electrolytic caps, like "main-frame" computer grade 100,000uF and TV HV 10uF 25KV doubler Caps, power supplies there is a phenomena like in batteries, known as memory. After you short it out the voltage creeps back. That's all you need to know. Short it long enough to discharge the memory effect."
                  Hmmm... All I need to know, huh? ("But wwhhyyyyy??", markie cried.)
                  P.S: I've discharged some old caps in gee-tar' amps for a couple minutes, dead-shorted, & gotten enough juice back across their plates after a half hour to light up a #47 lamp (briefly)!
                    • 31490
                    here's a test.
                    put a resistor across one for 24hours.
                    then leave it without the resistor for a day or 2.
                    then check it.
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      http://en.wikipedia.org/wiki/Dielectric_absorption
                      • joshnz
                        • Feb 2011
                        • 969
                        • New Zealand
                        This was mentioned on eevblog
                        My pc
                        CPU : AMD PHENOM II x4 @ 3.5Ghz
                        MB : ASUS M4A89TD PRO USB3
                        RAM : Kingston ValueRAM 16gb DDR3
                        PSU : Cooler Master 850W Silent Pro
                        GPU : ATI Radeon HD 6850
                        • Marko7
                          • Jun 2014
                          • 8
                          Thanx, kc8 ! didn't figger Wiki had an actual page on the phenomena.
                          • madan1
                            Modding HPF filter
                            by madan1
                            Hi everyone.
                            Recently scored a dead amp from a mackie srm1801 subwoofer and after fixing it, now I'm thinking about a home cinema/party subwoofer project.
                            Most likely I will use a 15" JBL woofer, which I already have and a diy box.
                            After reading the mackie user manual, I noticed that it has a 40hz HPF (labeled as "36Hz BUTTERWORTH HPF" in the SM) to protect the speaker from low frequencies. Indeed this seems to be good idea for the intended usage - professional music subwoofer, but bad for movies, where one would expect to "feel" the SUBwoofer....
                            09-24-2025, 02:06 PM
                          • bohaboha
                            PHILPS OUS 656521/12 Polarizing Filter ADVICE
                            by bohaboha
                            Hello everyone have this set with burnt points and some small cracks in the bottom edge of the Polarizing Filter it is almost glass transparent that I was going to try to fix with the car windshield repair agent so try does not mean succeed
                            my question, can i replace it with one that is not transparent the usual white ones
                            Maybe pictures explain better
                            IT IS TRANSPARENT i see it now so it will be a repair try att first
                            have anyone here sold Polarizing Filter? how to package a thing like that ? looks impossible without a very expensive Device
                            any idea are we...
                            12-14-2025, 08:01 AM
                          • Agent24
                            Dick Smith Q-1760 linear power supply filter capacitor question
                            by Agent24
                            I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                            It has at least one problem.
                            The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                            I have already ordered a replacement potentiometer, so that's not an issue.
                            Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                            All are CapXon...
                            10-21-2025, 05:39 PM
                          • cheese007
                            Input Filter Filling: How to Choose Components?
                            by cheese007
                            Recently acquired one of those silly Logisys acrylic power supplies and lucked into getting one of the "better" ones (most of an input filter, bridge rectifier instead of 4 diode treatment, OK-sized heatsinks, etc.) and wanted to fill out what I can on the board + get some decent caps on there (especially the primary side since I highly doubt the ones in there are actually 1000uf). My questions are:
                            1. How do I know what components to install re: the input filter? It seem to be missing an X cap, a resistor, and a Y cap.
                            2. Where can I find a good heatsink for the bridge...
                            12-06-2023, 09:59 AM
                          • PennyLane
                            Trying to locate a capacitor for a Skytec Crossover filter
                            by PennyLane
                            Hi
                            I'm trying to locate what i believe to be Radial Electrolytic Capacitors 100v 82uf Non-polar for a Skytec Crossover filter.
                            02-19-2025, 06:47 AM
