Trying to locate a capacitor for a Skytec Crossover filter
  • PennyLane
    • 6
    Hi
    I'm trying to locate what i believe to be Radial Electrolytic Capacitors 100v 82uf Non-polar for a Skytec Crossover filter.
  • truclacicr
    • Apr 2019
    • 352
    • australia
    Chenshen Capacitor Co.,Ltd.
    https://web.archive.org/web/20071121...cn/indexen.htm
    Our axial film capacitor and bipolar capacitors are widely used in Audio products with our logo-CYC. Also,we do OEM for Taiwan, European capacitor producers.
    • truclacicr
      • Apr 2019
      • 352
      • australia
      deleted
      • PennyLane
        • 6
        Thanks for that.
        Any idea where I could get replacements?
          • 31259
          diameter and height or the height you can get away with would help.
          • PennyLane
            • 6
            height 32mm but could get away with 36mm
            diameter 16.5mm but could get away with 18
            lead spacing is 8mm
              • 31259
              closest so far is this:
              https://cpc.farnell.com/visaton/5386...ic%20capacitor
              • PennyLane
                • 6
                Thanks for that I was thinking of using an Axial capacitor instead and making it fit somehow.
                  • 31259
                  axial / radial isnt the issue, finding 82uf @ 100v is the problem!
                  very few amps come even close to 100v output though.
                  you really need to be in the world of rack mounted beasts putting out 500w+ RMS to see more than 40v to the speakers
                  • redwire
                    • Dec 2010
                    • 3912
                    Whatever you stuff in there, make sure it doesn't rattle and buzz you have to glue it down. A few places in NA offering parts:
                    Solen Canada and Parts-Express
                    I'd probably look at low cost motor start/run caps but they are physically large.
                    • MORETTIGIAN
                      by MORETTIGIAN
                      Title:
                      Description:
                      Procedure performed:
                      - Removed backplate
                      - Reapplied thermal compound
                      - Reassembled card
                      09-18-2025, 12:14 PM
                    • Agent24
                      Dick Smith Q-1760 linear power supply filter capacitor question
                      by Agent24
                      I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                      It has at least one problem.
                      The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                      I have already ordered a replacement potentiometer, so that's not an issue.
                      Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                      All are CapXon...
                      10-21-2025, 05:39 PM
                    • grimacelord
                      Pioneer VXS-D902S Reciever - Filter Capacitor Question
                      by grimacelord
                      I have a Pioneer VSX-D902S receiver that I am trying to replace the 2 large 8200uF 80V filter capacitors on.
                      I have already removed the capacitors and ordered replacements, but I made a mistake in ordering. The original capacitors are Pioneer ACH1202 80v 8200uF and have 4 pins. The capacitor replacements I bought are Nichicon 80v 8200uF and only have 2 pins.
                      I was wondering if I could still use my replacements even though they only have 2 pins. Obviously I'd have to extend the pins of the capacitor to allow them to reach and fit through the...
                      01-12-2023, 02:40 PM
                    • Prolog
                      by Prolog
                      12-01-2024, 08:27 PM
                    • chth96
                      by chth96
                      12-22-2023, 04:34 AM
