Ceramic cap replacement on T-con board
  • BigPete
    • Jul 2012
    • 76
    • New Zealand
    Had a Samsung LED TV come in with a faulty T-con board(Sound but no picture). Traced it back to a blown 125v 3A fuse and a faulty ceramic cap. The fuse was easy to replace, the cap not so much. The faulty cap was in parallel with another. My meter reads 108.8uF on the good cap that's in parallel. What do you think the voltage would be on the ceramic cap? 16v?
    It blew with the 125v fuse as well so could it be higher?
    With the fuse replaced and the cap removed the tv displays picture.
    Should I measure the voltage on the good cap with the tv on to get an idea what the voltage might be?
    Is it worth worrying about at all?
    Regards
    Pete
    • 31303
    Re: Ceramic cap replacement on T-con board
    probably 12v or less.
    why not power it up & meter the voltage going into the fuse?
      16V rating cap will be good enough for 12V T-CON circuit if the caps are right after the fuse, other section will have higher voltage than 12V.
      • Hakuu
        by Hakuu
        Hi There,
        More Details
        TV Model - LG OLED77G1PUA
        07-12-2023, 02:37 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • maxim2511
        LG 55EC930V OLED - swich on swich of no screen
        by maxim2511
        My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
        Then I get an idea to take it apart and clean boards from dust.
        In side of Tv was not so bad, I take compressed air in can, and gently blow up.
        Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
        05-14-2021, 02:21 AM
      • tuner2000i
        Philips 65PUS8518/12 distorted image after main board replacement
        by tuner2000i
        hello everyone,
        I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
        The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
        07-15-2025, 01:15 PM
      • Cvrado
        Led TV Board Replacement, same part number and model, different size
        by Cvrado
        Hello my friends!
        I have a question that I think you can answer and help me with!
        I have a faulty main board from an led TV. And I found the same part number board and design but is from a 43" TV and I want to use it on a 65". On its stickers , all are the same except the wattage for the LEDs backlight, both state different watts and LED Voltages!
        So I presume that the backlight inverter section from the replacement board has lower wattage then the original one, am I right?
        My concern is that the board won't draw enough voltage to the bac...
        03-02-2024, 05:05 PM
