ESR / LCR meter recommendations?
    • 31070
    The origins is = Chinese see nice open source design, Chinese copy design and release without source (because they are assholes)
    The original is made by Markus Frejek, then continued by Karl-Heinz Kübbeler to this day: https://www.mikrocontroller.net/arti...ansistortester
    There is also a fork done by another Markus (madires) and his version was linked by stj above, both of these two later designs are current with some different design goals, both are completely open source.
    Here is a current version with a confirmed genuine Atmel processor.
    If you choose the "new english" version you get a surface mount processor.
    If you choose the "english" version you get a DIP (through hole) processor.
    https://www.aliexpress.com/item/1005003678038543.html
    Source: https://www.eevblog.com/forum/testge...02/#msg5178402
    unfortunatly thats a 32pin package,
    best to find a seller using the 324 or 644, not the 328
    • Hlsqpy
      • Dec 2023
      • 3
      • 澳大利亚
      Learned a lot of useful little details.
      • slybunda
        • Feb 2012
        • 131
        its arrived, very slick looking device, tested 2 old caps i had and 3 new caps. shows esr which is what i was after. nice screen on this. iv taken some pics of the inside. main chip doesnt have any markings on it, a crystal oscillator is present. the battery is 300mah uses a jst xh connector and wires are silicone around 22awg. plenty of room inside for bigger battery or other mods but for my usage it should do fine as stock. came pre-charged so i didnt need to plug it in yet.
        the kit it came with had some hook leads and one led, one capacitor and 3 what s look like dupont pins on a rail.
        firmware is 3.12k
        for the price around £10 inc delivery from aliexpress i cant complain.
        check the pics attached.
        what are your thoughts?
        also to add, i dont see any sort of lithium charge controller on the board, does this thing just pump power into the battery and rely on the battery's protection board cutting off the power when full?
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          Originally posted by JohnCT
          I bought an LC75 brand new in the early 80s, then added a 102 later as I opened another location. When I started contracting, I got rid of the 102. Sometimes too much automation is not our friend - the 75 is much faster. It's like trying to change the temperature on my wife's car - I have to scroll through menus where on my older truck I reach over for the temp knob without even looking at it.
          John
          You can do the same with the 102/103, as the 75. You don't have to key in the parameters if you don't want to. Just connect the cap and hit the value button....instant reading. If the value is out of tolerance, you'll know without keying it all in...and if it's that out of whack, no need going any further, replace the cap. If you want to go further with all the in-depth testing (ESR & leakage), you are going to be keying in parameters..
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            It looks pretty nice, it probably is a LGT8F328 since the markings have been removed, hate that the Chinese muppets do that!
            Just now when writing this post I found your other thread on eevblog so I'll stop here and link that instead:
            https://www.eevblog.com/forum/testge...tester-410146/
            • slybunda
              • Feb 2012
              • 131
              #26
              yep joined that forum too since im now interested in electronics these days.
              i dont see any charge controller chip on the mainboard, i was expecting something like maybe a tp4056, i may have to disconnect the battery and then plug it in on charge and check voltage at the battery terminals on the board and see how high it gets.
              • noppa
                • 41
                #27
                firmware is 3.12k
                The protection board is integrated in the battery. Look at the picture.
                • slybunda
                  • Feb 2012
                  • 131
                  #28
                  Yep the battery has its own protection board, was asking if the device itself had some sort of charge controller or if it just relied on the battery protection board cutting charge once it's at its limit.
                    • 31070
                    rub the chip with IPA,
                    often they dont grind them - they paint them with ink
                    • slybunda
                      • Feb 2012
                      • 131
                      #30
                      Man thats some sly tactics painting over chips.
                      • chth96
                        Is it possible to test small ceramic disc capacitor with analogue meter?
                        by chth96
                        I read EBOOK of Testing Electronic Component and found that
                        "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                        Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                        It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                        Is it really possible to test small ceramic disc capacitor with analogue...
                        03-09-2024, 10:03 PM
                        Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                        by sam_sam_sam
                        I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                        I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                        12-31-2023, 06:04 AM
                      • jorpec
                        Changing the scale of an analog meter
                        by jorpec
                        Hi
                        I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                        I wonder how i can accomplish this so the meter would be precise at any temperature ?
                        Thnaks
                        01-23-2023, 10:37 AM
                        How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                        by sam_sam_sam
                        About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                        Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                        Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                        12-14-2023, 07:45 PM
                      • Stephan Mathers
                        EDMI ATLAS MK10 Electronic Meter Discussion
                        by Stephan Mathers
                        Greetings, new guy here but always interested in the crazy universe of modding
                        We just finished construction of around 25 vacation houses, all inside the same private area.
                        Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
                        The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
                        Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
                        05-20-2025, 09:09 AM
