This is Why You NEVER Ignore Bad Capacitors!
This is a sticky topic.
  • chipper
    • Aug 2008
    • 95
    Re: This is Why You NEVER Ignore Bad Capacitors!
    When semiconductor thermal protection material gets hot , it looks for something to eat. Like good ribs , the wire was a microwave meal.
    • chipper
      • Aug 2008
      • 95
      So much for the stickers for UL Certification on the box. They didn't work. lol
      It's really surprising that we have all been fitted with $20 PSU's in the past , while the system was over a grand in total. Not that I am power hungry , but that is obsurd. I'd say the caps on that board were good , what brand were they???
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        I have a ps from a friend. its a bestec. inside, i found a cap that had burned itself and everything around it. i see burnt, ried electolyte dripping out of the fried remains. ash all over inside of box.
        YIKES!!!!!
        sigpic
        (Insert witty quote here)
        • everell
          • Jan 2009
          • 1514
          Is this Bestec the model number ATX-250 12E?
          Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            it was a 250 watt
            thats probably it, it came out of an emachines t5026
            explains all of the old owner's bsods (he thought he was infected )
            all bad caps jamicons (so was the fan, go figure)
            what makes it a shame was that it had thick wire, thick sheet metal box, nice, extruded heatsinks, good board material, and the big caps were nippon chemi-cons. a few apples ruined the barrel on this one... a bit too charred for me to recap it...
            sigpic
            • AudioCraZ
              • Sep 2009
              • 147
              #26
              Worst cap meltdown I ever saw was from an old cheap mobo when I used to work at PC Club. Had a computer come in that wouldn't post, pulled the panel, and on the side of the board (the side that sits at the bottom, a cap blew, and caught fire. Burnt up the motherboard, taking out the ram, and several of the IDE cables along the way. Was pretty impressive. Witch I took pictures.
              • JuniperSprouts
                Solder Soldier
                • Aug 2010
                • 119
                #27
                I hear you. I would not recommend Bestec ever.
                • zaphar
                  :-D
                  • Oct 2010
                  • 19
                  Originally posted by wetback
                  I got that beat... I had a cap pop on a Soyo board, they claimed I samaged the board because there were componates missing (they f'ing BURNED OFF!!)
                  Did they happen to be Sacon caps? My old Soyo motherboard only uses Sacon caps and it never functioned properly out of the box (apg x8 mode). I personally will never buy anything made by them again.
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    recap it... my friend has an old soyo (all wendell and sacon) that i am recapping for him right now. my dad had jetway issues and it was all evercon (sacon before the second name change)... before i fully fixed it, it ran fine after a partial recap, however, i was a tard and killed it during the full recap. i wish i had that board undamaged... nice form factor (7 slots, 2 rows of holes deep), VIA chipset for pIII, possibly tualie comaptible, max 1.5gb ram, and lots built in goodies.
                    sigpic
                    • backtrack
                      • Nov 2010
                      • 38
                      #30
                      I have received a Macintosh with a psu that had black stuff covering the transformer, capacitors, everything you name it! There was also black stuff on the outside. The voltage rail was toast and perhaps beyond repair. The psu did not stay around for long.
                      they call, they telnet, I hangup, I laugh, I get hiccups and digital breakups.
                      • Trinite
                        • Dec 2010
                        • 143
                        #31
                        I had an Abit AG8-V go out on me. One of the caps blew suddenly and took out the NB. Fortunately, nothing else was taken out. There was some system instability associated with it, but I thought it was just driver issues.
                        • cookieCAM
                          ICDEZ_CAM
                          • Feb 2011
                          • 26
                          #32
                          That Happend To My Video Card........Sadly
                          Thanks, cookieCAM (Cam)--Updated:March 2011
                          • cookieCAM
                            ICDEZ_CAM
                            • Feb 2011
                            • 26
                            #33
                            At least This Did Not Happen To My Arcade Games....
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              it was a 250 watt
                              I got two emachines that were beyond repair cause the "Bestec" brand power supply had a capacitor blow up in the 5v stand-by circuit, making too much voltage go to the motherboard, and SHORT both motherboards out...
                              they were bestec ATX-250 12E power supplies, and had good chemi-cons on the board EXCEPT for the 5volt-sub. the capacitor, a jamicon, was in a hot spot on the power supply too, next to big heatsink how could you design a power supply like that? unless you want it to fail in the future..
                              One of them I was able to fix by replacing the problematic jamicon, but the other had some other fault and was just dead...wouldn't turn on. I assume that a power mosfet failure might have happened but who knows...not worth fixing.
                              -Ben
                              Muh-soggy-knee
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                #35
                                Slap a 5v1 zener across the 5vsb rail to make sure it never ever shorts a motherboard again.
                                A working TV? How boring!
                                  A 5.1V zener won't be able to stop the might of a DC power supply when it's angry! It will melt! I've tried it.
                                  Use a 5.6V zener, a resistor, and SCR, to form a crowbar circuit, which will short the power supply on overvoltage.
                                  OR, use a better power supply.
                                  • lti
                                    • May 2011
                                    • 2548
                                    Zener diodes usually short when they fail. This either shuts the power supply down or blows it up.
                                    Also, a properly working power supply might supply slightly more than 5.1V. The highest voltage the power supply is allowed to produce is 5.25V.
                                    • Th3_uN1Qu3
                                      Believe in
                                      • Jul 2010
                                      • 6031
                                      #38
                                      Not if it's a 1W zener against a standby supply. It will short and take out the switching transistor.
                                      • RJARRRPCGP
                                        • Jul 2004
                                        • 6304
                                        Pre-2002 Soyo boards are more likely to have Wendell and "Rifeking" caps.
                                        Wendell is probably at least better than GSC and Sacon. Probably not better than Ost.
                                        ASRock B550 PG Velocita
                                        Ryzen 9 "Vermeer" 5900X
                                        Arc A770 16 GB
                                        eVGA Supernova G3 750W
                                        Alienware AW3423DWF OLED
                                        • seriousam
                                          • Dec 2013
                                          • Greece
                                          #40
                                          wow, is it even possible to start a fire due to a bad cap? that's serious...
                                            by momaka
                                            03-12-2025, 03:42 PM
                                          • eryjus
                                            by eryjus
                                            05-10-2023, 11:21 AM
                                          • Paxman_Swede
                                            by Paxman_Swede
                                            Hello!
                                            01-14-2025, 09:51 AM
                                          • captain150
                                            by captain150
                                            03-16-2025, 07:34 PM
                                          • Foetuss
                                            Gigabyte GA-6OXT :: caps question
                                            by Foetuss
                                            Good evening
                                            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                            But I was also suprised about the bigger boys, which are 330µF 25V.
                                            Could it be they used 25V caps because they were cheaper / available at that time?...
                                            02-11-2025, 12:22 PM
