Samxon is a OEM of Panasonics?
  • trodas
    • Jan 2006
    • 770
    • Czech republic
    I just get this pic:
    And I bet any recapper find it interesting. All Samxons I get in my hands (and that is over 100 of them) had the "X" on top. Now as anyone can see, there is the very typical "T" for Panasonics
    WTF?
    "It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
    "I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway my config - my caps
  • MD Willington
    • Sep 2004
    • 702
    Re: Samxon is a OEM of Panasonics?
    Either that, or the buy the same cans??
    Ya'll think us folk from the country's real funny-like, dontcha?
    The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      or they resleeved panasonic parts?
      scary that panasonic would farm out production to an iffy mfr.
      and let them use something trademarked like the vent design on other brands.gonna swipe that pic and send it to matsushita!
      • trodas
        • Jan 2006
        • 770
        • Czech republic
        Well, Bib Pope is lean toward the OEM idea, tought it is not entierly sure. And yep, the explaination that Samxon just buy the same cans have a slight fault. This can top is Panasonic patented stuff, so, he is the only one who can use it...
        There is only one question remaining. Why Panasonic has not in production caps that match the GC/GS specs, is Samxon is OEM of Panasonic?
        I mean - the GC specs are clearly better (higher ripple current as well, as lower ESL) that Panasonic FM, yet their size is smaller. Now that just don't make any sense, leaving OEM producer making better caps, do it?
        The Samxons are also smaller - eg. same size as Rubycons/Nichicons top-end ones. This also won't suit Panasonic. Tought the bigger size of the Pannyes aren't always disadvantage (for example for my passive coolied machines is bigger size preferable since it dissipiate the heat better that smaller one), the size simply won't fit.
        And when the GA line start production (demn, we need to convince some company to use them since all is need is 20k order to start the line - and if they can sometimes use Teapos, why not Samxons GA ) it will be even more weird, as these clearly kick ass of the FM line of Pannyes.
        Maybe Panasonic only bought them and let them continue their line, yet they start getting the Panasonic cans to be cost-effective and don't need to buy two different can's versions?
        We are, I'm affraid, a bit in the dark there.
        But it clearly cast a little bit different light on the China caps Samxons. How could they still be labeled as China ones, or we have to start call them Japansee caps now with these can's?
        • arneson
          • Sep 2005
          • 1267
          Hm, 20,000 items at what total cost? and how much more to print "BADCAP" on the label for us?
          I'd chip in to have our own caps.
          Jim
          • gonzo0815
            • Feb 2006
            • 1600
            T?
            To reach those kind os spec, i think you fore shure need a aqueouse solution. And even Rubycon don`t use this (at least in my opinion from the spe) in the long life series.
            And may be is this the answer on those question. So they can produce the good (=non aqueouse and long lasting) caps under their own brand, while supplying the SOHO IT industry with cheap, small and perforamnt caps too.
            Then they cann have both, high priced, reliable top performer for seriouse applikations, and top spec products for cost efektive and short therm duration.
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              samxon does do business with matsushita as per their balance sheet so it is likely that the china made panasonic caps are at least some of them are made by samxon factory. panasonic fm for instance is made in Japan, Malaysia and China. The balance sheet though does not indicate what of the Panasonic range Samxon is producing. Samxon does slightly more business with Taiwan Ostor Corp. otherwise known as Ost caps. They also own a company called Dongguan Ostor-Samxon Electronics.
              Samxon caps obviously differ is specification to Panasonic because they are their own design. Panasonic would not be using Samxon for R&D, just as a production factory, if that is what they are doing. Hopefully shipping in the cap materials from Japan.
              Dont forget though that there is a difference between making caps for one company to their specs that are a high value product and making your own caps to your specs to sell at a cheap price. To be fair to Samxon though, that is only my speculation.
              As regards Samxon caps being similar to Nichicon specs, I do not see any mention of Nichicon or indeed Chemicon in their accounts. It would be more likely for Nichicon to use Taicon to produce caps.
              Regarding the T vents on Samxon caps, hmm i dont think panasonic would be amused. That is one of the least copied vent designs.
              • trodas
                • Jan 2006
                • 770
                • Czech republic
                arneson - no idea
                gonzo0815 - yep, something like that I have in mind. And no, Rubycons aren't caps with the best specs - nowhere near is their best MCZ ones to Nichicon HZ/Samxons GA. Don't even talk about common MBZ ones, witch have worser specs that cheap and awailable from Digi-Key.com Pannyes FM, so...
                willawake - could be the other way around too. Joe claim that his friend drive for Samxon factory the electrolyte from airport to it and the country of origin is Japan... Make your own conclusions.
                The "T" question could be interesting to solve, tough. Look:
                Yet some others still the "X" vent ones, so...
                • yanz
                  • Nov 2004
                  • 910
                  I have just received a packet from Big pope (mailto: email removed for obvious reasons) full of samxon caps with X vent. They are already been installed on my systems for examination purpose.
                  trodas, are those caps yours? slibe.com seems like some kind of image hosting.
                  • trodas
                    • Jan 2006
                    • 770
                    • Czech republic
                    Mine are all with "X" ones vents. We see, if in the next package I got something with "T" vents or not
                    Certainly it is interesting this Panasonic - Samxon relationship
                    I update the infos, but now I just waiting for the very special tall ones for my Antec PSU - Big Pope say that they are custom made for him
                    PS. yep, slibe.com is image hosting free service - unfortunately they changed the code recently somehow and the images aren't being cached anymore, witch force then reload all the time, witch is EXTREMLY bad
                    • chth96
                      Can I replace KME cap with Samxon GF cap?
                      by chth96
                      Hello.
                      I have 29inch LG CRT TV,And Yesterday,Whenever I connect AC power cord to power outlet without switch on, I heard a sound like white noise, And When I switched on this CRT TV, It sometime displayed correctly But usually It won't last more than 20 minute and The screen begin to dark and It finally did not display at all for hours..
                      Today,I dismantled its plastic case and discharged the biggest capacitor(400wv 470uf) which still holds 250 voltage,and I finally detached PCB from cathode-ray tube.
                      I measured ESR value of most of caps in PCB with MESR-100 and I found that KME(25v...
                      04-17-2024, 07:11 AM
                    • GEARELECTRONICS
                      Samxon capacitor esr
                      by GEARELECTRONICS
                      I need your advice.
                      -SAMXON 2200uf 50V tested 0.00 esr on Dick Smith Blue Esr meter and 2027 ohm on FLUKE 179 multimeter.
                      -Is this esr reading realistic?
                      Thank you
                      05-29-2023, 07:26 AM
                    • Eh546
                      Polk PSW125 capacitors choices for a beginner.
                      by Eh546
                      I was looking to repair my Polk PSW125 subwoofer plate amplifier, i've checked around the web and it seems to be a capacitors problem.
                      Took apart the amp, and made a visual inspection, everything's seems fine, fuse ect no burn marks, but i noticed 3 caps that were a little bit bulged. One 400v 150uf, one 50v 47uf, and two 63v 47uf.
                      I noted each caps voltages and uf anyways, and made a list on digikey. Some recommended Nichicon and Panasonics ones (FR and FM) serie. So I tried to stay with the Panasonics FM-A serie.
                      I would like to know if the caps i selected...
                      12-21-2023, 07:28 PM
                    • goodpsusearch
                      LG L1715s with failed Samxon GF
                      by goodpsusearch
                      Found monitor on my way home sitting on the pavement.
                      This monitor stopped working due to Samxon GF failing.
                      One of the caps even changed color to black from overheating. Notice that even the rubber bangs deformed from venting/overheating
                      It is just stupid to put caps right above secondary rectifiers and heatsink that get very hot during monitor operation.
                      Those 17" monitors can be found in working condition for less than 10 euros or even for free!
                      So, I recapped it using terrible caps and tried to install extra...
                      01-15-2022, 04:45 PM
                      by momaka
                      03-15-2023, 10:17 PM
