Samxon capacitor esr
  • GEARELECTRONICS
    • Apr 2019
    • 13
    • seychelles
    • Electronics, Fishing
    I need your advice.
    -SAMXON 2200uf 50V tested 0.00 esr on Dick Smith Blue Esr meter and 2027 ohm on FLUKE 179 multimeter.
    -Is this esr reading realistic?
    Thank you
    • 31563
    Re: Samxon capacitor esr
    no,
    the fluke cant read esr, esr is done using AC current.
    the fluke is telling you the cap has internal leakage
    if you read capacitance it will probably be well over what it should be.
    • redwire
      • Dec 2010
      • 3918
      Typical 2,200uF 50V cap has ESR from around 0.264Ω-0.030Ω for low ESR types.
      If the cap has 40V on it with 2,207 ohms leakage... that is 0.8W which is a problem.
      Check your Blue ESR meter is working using a resistor, like 1Ω or 0.5Ω
      It does not use AC, but instead a DC pulse of 0.5mA, 5.0mA or 50mA depending on range.
      I have trouble testing with these cheap Asian caps, the electrolyte acts like a lead-acid battery lol then you add corrosion.
      High leakage current and you need an AC test (dual slope) to measure capacitance. I'm not sure what the Fluke 179 is doing, the 87-V is single slope I thought.
      • joetristan
        Tantalum capacitor burning out
        by joetristan
        I’m using a 10 µF, 20 V tantalum capacitor as a decoupling capacitor across a 5 V supply. When I power the circuit, the capacitor burns out.
        At first, I assumed the tantalum capacitor was defective and replaced it, but the new one burned out as well when the circuit was powered.
        I then replaced the tantalum capacitor with a 10 µF, 63 V electrolytic capacitor. This time, the capacitor did not fail after powering the circuit.
        I do not understand why the tantalum capacitor burns up?
        02-11-2026, 03:43 AM
      • Prolog
        by Prolog
        12-01-2024, 08:27 PM
      • woodboy971
        Need help – Identifying missing capacitor (HP CM 6050A2892401 MB A01)
        by woodboy971
        I am a beginner in electronic board repair and I am looking for help with an HP motherboard: CM 6050A2892401 MB A01.
        Initially, the laptop would not power on. After troubleshooting and taking measurements, I found that a capacitor was shorted, which was preventing the system from starting. I removed this capacitor.
        After removing it, the PC now powers on for a few seconds and then shuts down. I believe this behavior is related to the missing capacitor, which is no longer performing its role in the circuit.
        My issue is that I cannot identify...
        12-27-2025, 10:31 PM
      • Quadro1000
        MXM Graphic card Nvidia Quadro K1000m /K2000M schematic or value of capacitor C55 capacitance and voltage from laptop HP8570w
        by Quadro1000
        I had a MXM graphic card type Nvidia K1000m from laptop HP8570w which had a broken capacitor.
        The ceramic capacitor seems was broken and makes a short circiut. The laptop goes off because of the short-circuit. But it seems currently that only the capacitor C55 was broken on the graphcic card.
        Because after I have desoldered it, the laptop runs with the card. But currently without this capacitor.
        So to have full functionality and no instabilities I want to replace it with a new one.
        So I need to know the value and voltage of C55 to replace...
        12-16-2025, 11:17 AM
      • devsigner
        identify capacitor for MacBook Pro with rare logic board 820-02037-06
        by devsigner
        Hi
        While messing around with my MacBook Pro, I stupidly pinged off a very small surface mounted component that I’m now trying to identify.
        resistance tests show a rising resistance value, indicating a capacitor.
        The laptop boots up and runs, however I'm choosing not to use it until I get it fixed.
        i can’t see any markings on the capacitor at 10x magnification using a professional jewler's loop.
        It seems like there's some damage to the capacitor - one side doesn't have "shiny bits" - can you tell I don't do this for a living!...
        11-28-2025, 01:39 PM
