Dell XPS 600 Mobo Capacitors
  • ratlhead
    • Nov 2011
    • 5
    So I think I'm going to send this board into the guys at badcaps.net, but just thought I'd post some info and get some thoughts on it.
    It's an old Dell XPS 600 that stopped working last year (I've replaced the computer since). However, I'd like to try to get this machine up and running again, as it wasn't a bad machine when actually working.
    When it stopped working, it would turn on with the fans blaring, but that's it. No POST, no nothing. Upon further investigation, I spotted a couple bad caps on the board, along with some other attachment next to these two. On the underside of that small other attachment, I see some slight burn marks on the board.
    Anyway, here's a couple pics...just thought I'd try to get some input/thoughts on this. Unfortunately, the damn Dell cases are so specialized that you can't just put in a new board, and of course, Dell doesn't have any more of these boards available (and because of this, these 5 year old boards still go for $400+ on eBay, which is crazy).
    http://ratlhead.com/mobo1.jpg (bad capacitors)
    http://ratlhead.com/mobo2.jpg (board info)
    http://ratlhead.com/mobo3.jpg (small attachment next to capacitors)
    Thanks guys!
    -Mike
  • c_hegge
    • Sep 2009
    • 5219
    Re: Dell XPS 600 Mobo Capacitors
    Well, well, well, it looks like you have busted rubycons, which is very unusual, since they are usually a vrey reliable brand. I think that coil must have cooked them.
    I had a similar issue on a gigabyte board at https://www.badcaps.net/forum/showth...ied+GA-8IPE775.
    It turned out that one of the MOSFETS had shorted, which is probably what caused the coil to burn up. I'd be checking the two parts I circled in yellow. If one is shorted, then that might explain why the coil burned up. Of course, you will also have to replace the coil and all 8 of the caps in that picture.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      That's a good place to start.
      Also trace the circuit the coil is in back to the ATX PSU connector looking for bad components or PCB traces that burned out due to excessive current.
      - The MOSFET is the more likely the -cause- of the problem, what I'm suggesting you check is more for collateral damages.
      Mann-Made Global Warming.
      - Dr Seuss
      • ratlhead
        • Nov 2011
        • 5
        Thanks for the replies guys. So I'm not much of a techy when it comes to mobo components/parts, but it sounds to me like you guys are suggesting this board may take more effort to repair than it's worth?
        I've seen a couple other threads on here now with the same board and same issue. From what I read, the 'inductor' next to the two blown capacitors will also need to be replaced. Is this something the guys at badcaps can do as well? MOSFETS too? I certainly am not skilled enough with a solder iron to do this repair work myself.
        I'm scared to think other components could have fried. Safe to assume the processor could be a victim? I know my hard drives survived...hope the RAM/video card as well, but won't know until I repair/replace this mobo.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          I've replaced the MOSFET's, caps, and the coil on a lot of these.....it revives maybe 25% of them. Not worth messing with, I won't even take them in for repair anymore. They were just a crap board.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • ratlhead
            • Nov 2011
            • 5
            Ha! I submitted a request earlier today...I guess we can cancel that then.
            Can I possibly place an order for the parts I would need to give it a shot myself? I assume I'd need the inductor, capacitors and MOSFET's. I have a soldering iron...but I'll need to look into getting the right solder and such.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              The parts affected are more likely for RAM or possibly PCI-E.
              Power comes from the large power connector.
              CPU power comes from the other power connector on the other side of the chipset from there and uses the MOSFETs located close to the CPU.
              - CPU isn't likely to be affected at all.
              This board is unusual because Dell went with an nVidia chipset.
              Many nVidia chipsets are defective and break. [It's complicated, covered elsewhere.]
              I avoid them in general so I dunno which are okay and which are junk. [I have to look it up every time.]
              You will learn a lot about mobos giving it a shot even if you don't fix it.
              "Worth it or not" is of course something you have to decide.
              Given it's an nVidia chipset I'd probably scrap it.
              - Dr Seuss
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                I scavenged the coils off other junk boards, the FET's came from digikey (forgot the P/N, havent ordered any in a couple years), and the caps I have. I measured the inductance off a good coil with a Sencore LC102 (measures coils quite nicely), and then scavenged one off a crap board of similar size and within 20% of the original. They're easy to find.
                The ones that went deeper than the fets, coil, and caps, I have no idea what's wrong with them beyond that. I never dug deeper. Beyond that, they went in the trash or back to their owners.
                It's worth repairing, but the odds of actually making it work again are very slim....but certainly give it a shot if you want, you have nothing to lose and some interesting experience to gain (even if you fail).
                Team : 49813
                Join in!!
                Team Stats
                • ratlhead
                  • Nov 2011
                  • 5
                  Thanks for all the info guys...great forums and alot more response than I expected! Glad to see there's still good forums out there...
                  Unless I can just buy a set of the parts, I think I'd be way in over my head trying to do this myself. I don't want to spend alot on tools or bug the forums too much trying to figure everything out.
                  Such a shame that Dell did this to their customers...no replacements, crappy parts, etc. So done with them.
                  • c_hegge
                    • Sep 2009
                    • 5219
                    Dell stands for Doesn't Ever Last Long
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16958
                      Never be afraid to bother us or ask questions, that's what the site is for.
                      Trust us on this one....the first time you take a motherboard, monitor, TV,PSU or whatever that's good for nothing but landfill and bring it back to life by recapping it, you'll be hooked! Next thing you know, you're rooting through people's trash, asking mom and pop computer stores if they have any boards with bad caps, and so on....
                      Team : 49813
                      Join in!!
                      Team Stats
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Speaks truth. - Recapping is addictive.
                        Even basic questions aren't a problem here.
                        You'll probably learn more that you ever wanted to know!
                        - Dr Seuss
                        • TCKTMB
                          • Jun 2011
                          • 56
                          Maybe I'm just lucky but I'm 2 for 2 with XPS600 boards. Didn't have any coils to scavenge so I removed the wire, cleaned the coil, rewrapped with magnet wire of the same diameter and replaced the caps. One of them is a file server for our techs and it has been up 24/7 for over a year with no issues.
                          • ratlhead
                            • Nov 2011
                            • 5
                            Anyone willing to let me ship my board to them and pay a fair flat rate for an attempted repair?
                            Being a software/web developer, I'm not sure I want to dive into capping...code keeps me busy enough
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              A good share of the members are capable [and the owner of this forum does that for a living] but honestly given the nVidia problem chipset you would be better off starting fresh with a board having an Intel chipset.
                              - Significant possibility a repair won't work or will be short lived.
                              - Good money after bad kind of thing.
                              To go cheap find one that uses the same CPU and RAM.
                              Although, you have a grand 'excuse' to upgrade - and it might be a good idea.
                              It -looks like- a Dell proprietary layout [foot-print/hole pattern] which is a hassle because to use the old chassis you are limited to Dell boards with the same bolt and hole patterns.
                              This one 'looks like' it would fit and would be a substantial upgrade.
                              [You would need a new CPU and RAM too, and it has no PCI slots if you need those.
                              http://www.ebay.com/itm/280689118038
                              The Dell i3/i5/i7 boards in general look to be less expensive than the XPS 600 boards.
                              Where it ME:
                              I would find a socket 771 board and either mod the case or replace it.
                              L5420 Xeon Quad cores have dropped to about $50 used
                              2.5GHz 12MB 133 3 50watts 4-cores
                              Their Passmark score [for a single] is about 3725.
                              The low volt XEON "L"s typically Passmark slightly higher than the standard volt XEON "E"s because they run cooler.
                              The "L" hasn't been tested as a single so I am showing the "E" in the link.
                              http://www.cpubenchmark.net/cpu_look...20+%40+2.50GHz
                              - And you could add another later if you ever felt wanting for performance:
                              http://www.cpubenchmark.net/cpu_lookup.php?cpu=[Dual+CPU]+Intel+Xeon+L5420+%40+2.50GHz
                              [Note the E5420 dual just under the L5420 dual, that's typical of the low vs standard volt XEONs.]
                              That's A LOT of punch for a $50 CPU!
                              ~or~
                              Xeon 5148's were running like $10-$15 last I looked.
                              Comparable to C2D E6550 - but only 40 watts - and you can use two.
                              And to the peanut gallery:
                              This is where paying a little bit more for socket 771 [or just server] boards pays off later.
                              When the server farms start upgrading certain kick-butt CPU's get REAL cheap due to market flooding.
                              Been happening since at least Pentium Pro. Just have to keep your eyes open for when it hits.
                              Pardon my enthusiasm.
                              Just picked up a L5420 for $42 shipped - and I'm jazzed..
                              - Dr Seuss
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16958
                                I'll take a crack at it if you like....just don't spread it around...
                                Team : 49813
                                Join in!!
                                Team Stats
                                • GRSHOPR
                                  • Feb 2012
                                  • 11
                                  OK, I guess am going to revive this old thread, as I can't find the answer elsewhere. Topcat, do you remember the ratings for the toroid coil? I have this exact problem, I've replaced the caps (many thanks again to bonez and others for there help on that one), and this is the last component. It's completely fried, no chance of rewrapping it.
                                  • Z28Rodeo
                                    • Jul 2011
                                    • 8
                                    OCL: 0.18
                                    TOL: 20%
                                    DCR: 0.00145
                                    I rating: 18.00
                                    Hope this can help get you jump-started. I have smoked four of these boards myself. Good Luck!
                                    - Cor
                                    • brethin
                                      • Dec 2008
                                      • 1907
                                      These are the pita of all boards to repair when they fail. They can be repaired but require so much time and effort finding the problems (most of the time its not the same problem per board) its not worth it.
                                      • kc8adu
                                        • Nov 2003
                                        • 8832
                                        • U.S.A!
                                        yes results are variable.
                                        i will get 6 that all live even though that area looks like hell.
                                        then i get a few that look decent but the nvidia is shot.
                                        the losers are the ones with nvidia plague.its hit and miss.some i fixed 4 years ago and still going 24/7 and some work awhile and the nvidia gives up.
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • piernov
                                          NVidia bumpgate
                                          by piernov
                                          Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
                                          Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
                                          May complete this post at a later date with more details.
                                          Basically issue is a combination of thermal dissipation of the chip with hotspot,...
                                          03-27-2021, 10:34 AM
                                        • mrsith
                                          Dell G3 17 3779 - no display after mobo replacement
                                          by mrsith
                                          Hi guys,
                                          I have a friend's Dell 3779 that came to me with severely shorted mobo. Did not manage to isolate the cause, most likely that was a bga shorted. Went for a replacement motherboard. Got one from China, apparently it's been tested prior to shipping. The mobo starts up normally but I am getting no display whatsoever.
                                          Tried using external monitor, but being blind I am not sure if laptops goes as far as booting to Windows, a d without it I cannot get hdmi to work. Can't see boot menu options to make sure it boots to Windows. Went ahead and did a blind bios update,...
                                          04-30-2023, 05:11 AM
                                        • master3112
                                          by master3112
                                          07-29-2025, 01:55 PM
                                        • F R 2568
                                          Dell Latitude 5420 does not start (no post) need help to find the reason why
                                          by F R 2568
                                          Hello all,
                                          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                          If the laptop is only connected to the AC adapter (battery removed):
                                          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                          The power/battery...
                                          01-08-2025, 05:45 AM
