I have a gigabyte GA-7VAXP motherboard which has bulging and leaking caps.
It has been running OK. When I examined the motherboard, I found the bad caps, and also saw that several of the MOSFETs in the VR circuit had overheated and melted the solder onto the motherboard on their flat side - none are scorched or melted. I presume (but don't know for sure) that this was caused by the bad caps.
I'm worried about a fire-hazard here. If I recap the motherboard, would the MOSFETs be OK and not further overheat?
Should I replace the MOSFETs as well ? - I'm not sure how I would desolder the flat side of them from the motherboard if I had to replace them.
If I should, and can replace them, can anyone recommend a source for the new MOSFETs ?
Is it OK to replace just the one MOSFET or should 'the set' be replaced so everything is balanced? The new part could have different specs just because it's new couldn't it?
