Rubycon fakes??? or just blown?
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    I ordered a mobo off ebay from hong kong, got it today, It works, but blown caps.
    Pictures below.
    I'm not sure if these blew due to heat or are fakes?
    I have rubycons from another matching board and the font doesn't seem to match, the bad ones are more bold then the good ones.
  • mockingbird
    • Dec 2008
    • 5488
    Re: Rubycon fakes??? or just blown?
    How fake cap sellers on eBay operate:
    There is a large network of "trinket" sellers on eBay. They sell anything from iPod silicon covers to LED gizmos.
    Usually they will have a section dedicated to counterfeit and usually low-quality but good looking fakes. They start to sell to unsuspecting individuals. When they start to receive enough negative feedback, they switch the entire capacitor section to another seller in their network. When the previous seller has built up sufficient positive feedback from selling their other trinkets, they will switch the capacitor inventory back.
    This way, they can stay ahead of the negative feedback that would otherwise ward off most people.
    An example:
    Seller is "goodbuy7888" from Hong Kong.
    You have to dig pretty far back in his feedback to find this.
    They're getting smarter and smarter and the fakes are getting better and better. I picked up a Panasonic FC from a relatively local electronics shop that is almost visually indistinguishable from the real thing. Avoid caps from eBay Hong Kong sellers.
    • c_hegge
      • Sep 2009
      • 5219
      The one (or one of very few) exception is http://stores.ebay.com.au/PC-MotherB...pacitors-Store
      He only sells caps AND there is no difference between caps I've bought from him, caps I've bought from topcat, and caps I've pulled from motherboards. I have several boards in service which I've used his caps on and no problems yet.
      • mockingbird
        • Dec 2008
        • 5488
        But he is not cheap.
        • c_hegge
          • Sep 2009
          • 5219
          I know. I used him untill I realised how much cheaper topcat was, although since he only charges $2 shipping, he can be cheaper for smaller orders.
          • yyonline
            • Jul 2009
            • 692
            If those are fakes, they're certainly very good fakes... The color is unusual, but I've seen black/white MCZ before on Dell boards, so it's not unheard of.
            You said they were on a board. Did the board show any signs of rework?
            I've seen blown MCZ before too. They're very reliable overall, but not indestructible.
            • Mad_Professor
              A Mech Warrior
              • Feb 2011
              • 1587
              Came off a HP board, looked at the back before I began work on it, no signs of rework.
              You never seen black/white ruby's? I have them on alot of boards, I only noticed this one when I compared it to 2 other boards that had ruby's and noticed the font is more bold on these bad ones.
              I got suspicious considering the origin of the board.
              Anyways I replaced the passive north-bridge cooler with an active one apparently it puts out alot of heat and the spot where the bad ruby's are sit next to this furnace.
              Thanks mocking bird for the heads up, I will be more cautious next time.
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                Mad_Professor; yyonline said that they are unusual but that he has seen them before
                I say they look genuine too, they where probably cooked.
                Remember they are only rated for 2000h @ 105°C
                For example if that chipset runs as hot as I've seen them do and heats the capacitor internal temp to 75°C
                Then it would only take 16000 hours for it to fail, that is ca 267 days...
                Bloating will take longer but at this stage in time it would be outside the tolerance of the manufacturers specifications...
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  I think they are from the Rubycon Malaysia where as the standard color are made in Japan.
                  Mann-Made Global Warming.
                  - Dr Seuss
                  • Digital Technophile
                    revrse engineer
                    • May 2011
                    • 144
                    Just gotta love FleaBay!
                    Yeah, you gotta watch those tricky chinese fleabayers. I bought a MoBo of of one of these clowns (probably the same guy with a different acct. wouldn't put it past). It was an Asus A8N-VM board I was interested in because I wanted a board w/more than two SATA ports to do some RAID'n on. The picture CLEARLY showed the four SATA connectors from a later revision. When the board finally arrived, I was dismayed to see it was actually an EARLY revision board with only two SATA ports!!!! Neeedless to say, I was pissed off to the highest of pisstivity, flamebasted him, then reported him to idontcarebay, who proceeded to do nothing because "he offered a PARTIAL discount, which I didn't accept"!!! Needless to say I no longer buy ANYTHING if it says the item is in Hong Kong. And these days, I really have to be hard pressed to buy anything from FleaBay at all, because of the outrageous prices they charge to sell anything on there. I also find it very peculiar that FleaBay "users" from China are EVERYWHERE on the "USA" part of FleaBay. Yet, you actually have to purposefully navigate to FleaBay.UK, FleaBay.DE, etc.
                    Moral of the story: Buy from Hong Kong and there's a 99% chance your gonna get burned like a bad cap!
                    :endrant:
                    If you voted for Obama in 2008 to prove you weren't a racist, you'd better vote for someone else in 2012 to prove you're not an idiot!
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      Looks counterfeit to me!
                      ASRock B550 PG Velocita
                      Ryzen 9 "Vermeer" 5900X
                      Arc A770 16 GB
                      eVGA Supernova G3 750W
                      Alienware AW3423DWF OLED
                      • c_hegge
                        • Sep 2009
                        • 5219
                        They look real to me.
                        • yanz
                          • Nov 2004
                          • 910
                          yups.. looks real to me too
                          days are so short when you actually do something..
                          • yyonline
                            • Jul 2009
                            • 692
                            I think the black and white MCZ have Polyethylene terephthalate sleeves and are marked with "PET". I believe the gold lettering MCZ have PVC sleeves.
                            • TCKTMB
                              • Jun 2011
                              • 56
                              Correct, PET(black/Grey) sleeves use the "option" section in part number of EFC as well. This used to be helpful when searching for MCZs if everyone was out of the PVC sometimes you would get lucky using the EFC part number. example PVC: 6.3MCZ820M8X11.5, PET: 6.3MCZ820MEFC8X11.5
                              • TCKTMB
                                • Jun 2011
                                • 56
                                Rubycon does not have a plant in Malaysia ( Nichicon does ), Rubycons only overseas Production Base is in Mukakuning,Batam, INDONESIA. Black/grey MCZs are Poly Ethylene Terephthalate for the hippies.
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Same place when you go by boat.
                                  - Dr Seuss
                                  • TCKTMB
                                    • Jun 2011
                                    • 56
                                    By that logic your Mexican and I'm Canadian lol
                                    • RJARRRPCGP
                                      • Jul 2004
                                      • 6304
                                      Those look fine, because the other Rubycon series are usually that color and the label text looks even clearer.
                                      Arc A770 16 GB
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        Judging by my neighborhood I AM in Mexico less the drug cartels.
                                        Kind'a like it that way.
                                        - Dr Seuss
                                        • cmlewis89
                                          LG 47LB5DF blown power supply board
                                          by cmlewis89
                                          Hi folks,
                                          I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                                          09-03-2024, 07:50 PM
                                        • drscoot
                                          HP X360 convertible battery blown fuse error, not charging
                                          by drscoot
                                          HP Modelnumber: 14-dh0061nb​
                                          This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                                          The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                                          I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                                          And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                                          All these 3 batteries are charging...
                                          12-15-2023, 05:54 AM
                                        • w00pz
                                          Identify blown component on HP ENVY X360 13-arxxxxx, Motherboard G1 13 AMD X360 18740-1 448.0GA03.0011
                                          by w00pz
                                          I have blown a component on HP Envy x360 with motherboard G1 13 AMD X360 18740-1 448.0GA03.0011.
                                          Unfortunately there are no schematics available and the component was so blown the marking weren't readable.
                                          I have marked it with a red circle in the attached photos - sorry for the mediocre quality I was too much in a rush.
                                          Hope someone will be able to identify the component.
                                          Many thanks for your help!
                                          Edit: High-res picture added on a normal board (not mine)...
                                          11-08-2025, 02:48 PM
                                        • swerg
                                          Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
                                          by swerg
                                          Hey everyone,
                                          I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
                                          I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
                                          I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
                                          06-06-2024, 03:39 PM
                                        • ohren
                                          What problems could this blown cap cause in a Marantz SR5400?
                                          by ohren
                                          I'm looking at a vented C513 in a Marantz SR5400 (photo included), in the FR section on page 24 in the service manual (https://audiocircuit.dk/downloads/ma...400-avr-sm.pdf).
                                          R533 right below it in the photo is charred, but measures the correct value.
                                          1. I'm not familiar with amplifier circuits (at all — don't know the difference between classes, etc.) so I was wondering what problems would manifest from a supposedly non-operational C513? I didn't hear anything odd when testing the output channel with a speaker. Is there a simple test that can be done...
                                          10-21-2025, 09:02 AM
