Need specs for Sacon FZ3A
  • daemon123
    • Jun 2010
    • 50
    Hi guys,
    I cant seem to find specs for this capacitor
    Sacon 470uf 16v FZ31 (105c)
    they are on my old 6600 card, and its making whistle noise, so i though these are the culprits.
    also will these be good enough as there replacement ?
    Lelon REA (85c) H549(M) 470uf 16v
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Need specs for Sacon FZ3A
    https://www.badcaps.net/forum/showpo...88&postcount=2
    You didn't specify physical size. The 8mm and 10mm have different specs.
    Don't use Lelon unless you want to do this again later.
    Mann-Made Global Warming.
    - Dr Seuss
    • daemon123
      • Jun 2010
      • 50
      those were the only ones i could find in that range and size, btw i went away and put them on lets see what happens, and i dont have problem replacing them after a month or so
      as i am going to get new card by then
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        If you are running it using caps with inadequate Ripple handling capability it might not last a month or so.
        Can't say for sure either way but it's not a good thing to do.
        - Dr Seuss
        • daemon123
          • Jun 2010
          • 50
          you were right, they didnt lasted even a day, the gpu didn power up, now have put some kzg on it now dont tell me that those might turn out bad as well, its like when you have to choose from the worst then this is the best one i got
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Oh No...
            Yes KZG are bad. They also fail without bloating.
            BUT: They are rated well enough to handle the ripple.
            Those might last a month.
            - Dr Seuss
            • goodpsusearch
              • Oct 2009
              • 2850
              • Greece
              They could last more if kept cool.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Yes but he's getting a new card in a month so that's all he wants.
                - Dr Seuss
