Computer will POST only after a dozen boot attemps
  • Hugo
    • Jan 2006
    • 13
    Hi! My computer has been acting strange for a few weeks now. My caps look OK but here are the symptoms.
    When I push the ON button, it powers up properly: the PSU fan starts, keyboard lights flash, the hard disk makes a sound and the internal speaker makes its normal short beep.
    Then........ nothing. The screen stays dark and absolutely nothing happens. The keyboard and the mouse aren't powered (no reaction when I press the caps lock key). No POST, no more hard drive noises. The PSU fan is still running and a few diods are on, but that's all.
    I then press the ON button for 5 seconds to turn off the computer, I try again... same thing... again... again... then, after 4 to 12 successive attempts, the computer FINALLY starts booting. Once it's booted, it's absolutely stable. It can run for days without crashing or freezing.
    I have a few suspects but I need your opinion.
    - Could it be a "bad caps" problem?
    - Is the PSU dying?
    - Is the large amount of dust killing my computer (the house is dusty because we're renovating)?
    - Or maybe the BIOS battery is dying?
    - Or it's a problem with loose internal wiring or cards?
    - Too many peripherals for my PSU? It that even possible?
    The computer is a P4 genuine Intel, 2Ghz. 512Mb memory in one bank. Motherboard is Intel too. I also have a few peripherals installed: Radeon 9200 video card, USB 2.0 4-ports extra card (with 3 devices in: scanner, fax/printer, camera), 2 CD/RW-ROM drives, 1 hard disk (80Gb Maxtor), 1 floppy drive, standard mouse, standard keyboard. I use the internal sound card and network adapter. Oh, and I have one extra case fan, pumping the air out.
    Motherboard: Intel D845WNL (Pentium 4)
    I can't find any info about the PSU, it looks very ordinary and nothing specific is written on it (no brand or model info).
  • cods69
    • Oct 2005
    • 92
    Re: Computer will POST only after a dozen boot attemps
    I'd replace the PSU (with a decent one) first, regardless.
    At least you know you have good power to the mobo and other devices then.
    • tylerlough
      • Dec 2005
      • 96
      It's likely the PSU, starting it many times warms it up and PSUs work better when warm. A good psu is important, think what your pc is with out power; it's a big a$$ paper weight.
      • Hugo
        • Jan 2006
        • 13
        Well I'm happy if the problem isn't capacitor related.
        What type of PSU is good for a Intel P4? 400 watts?
        I'll change the PSU and the BIOS battery, just in case. Just one stupid question: if I remove the BIOS battery, will the BIOS lose any information?
        I've assembled or repaired many computers, but I'm really not an expert on components and electricity.
        • tylerlough
          • Dec 2005
          • 96
          400 watts is overkill, your system only draws from 70-100 watts at full load
          look at this but you should read the whole thing too.
          http://www.silentpcreview.com/article28-page4.html
          And yes you will lose the BIOS settings but not the BIOS info; the settings just go back to default and then you change them back
          A power supply has capacitors too and they do go bad but most people just get a new one if they go bad.
          a good way to pick a psu is by weight, if it ways 10oz and is 400 watt it is not a good power supply
          a 250-350watt one would be fine
          other people hear know about what brands are good and what are not
          check this out too
          http://www.tomshardware.com/2005/07/11/stress_test/
          • Chris1992
            • Apr 2005
            • 561
            If the BIOS battery is removed, you will lose BIOS info. I have a P4 running off 250w.
            The great capacitor showdown!
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              take a look inside the psu. it may have badcaps there. badcaps on the mobo can do exactly that and badcaps in the psu can give same kind of issues. if the system is still stable the good caps on the mobo are probably filtering the bad power from the psu well.
              if you find some bulging/leaking take a pic for us.
              if it is lightweight and cheap, would be better to replace it. FSP Group (Fortron) seems to be a favourite here. Also Seasonic, PC Power & Cooling, Zippy, High Power/Chieftec.
              the spec quoted on some psus are peak and not sustained. ie you get much less actual wattage than what you paid for.
              • Newbie2
                • Sep 2005
                • 885
                No sticker is on the side of that PSU?
                Can you take it out and please if you can post pictures of the insides of the PSU.
                My gaming PC:
                AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                ASUS M4A77TD AMD 770 AM3 Motherboard
                PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                ASUS Xonar DG 5.1 Channel PCI sound card
                Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                Antec Three Hundred Mid-Tower Case
                Microsoft Windows 10 Pro 64-bit
                Microsoft Windows 7 Ultimate SP1 64-bit
                • tylerlough
                  • Dec 2005
                  • 96
                  yes it is possible to over load the 12volt rail, this is were over 75% of the power comes from on the modern system. I'm not sure if the 75% thing is true for stuff older than a P4 system. It dosen't really matter about the total watts, just look at the amp rating for the 12volt+ line it should be more than 8amps just to be safe.
                  peripherals such as fans and pci cards only draw about one or two watts each so thoses aren't big problem.
                  Likly root of your problem is a POS PSU or faltly mobo.
                  • linuxguru
                    • Apr 2005
                    • 1564
                    +5Vsb should be rated for 2A or higher for most Intel P4 boards. I've seen power-on problems similar to what you've described due to an overloaded +5Vsb rail, often due to dried-up electrolytics on the auxiliary power supply in the PSU.
                    • Hugo
                      • Jan 2006
                      • 13
                      Yayyy! I've installed a new PSU and the system boots normally now! Even better, there used to be a slight case of interference on the monitor, and now it's gone! This system has always acted kinda strange. It's 2 1/2 years old but I suspect some of the components are older. In the past months this system suffered from a dead monitor, a dead keyboard, 2 dead CD-ROM drives. A serial killer feeding on peripherals.
                      My new PSU is a 350W Enermax with a lot of cool options. It's got a dual fan, is adjustable, not noisy at all, and has a 3 years warranty. At 70$ it's a very good value.
                      Now, for the old PSU, I have some more news. I've found the sticker on the back of the unit. It's a "L&C Computer Co., Ltd", model is "DR-A300ATX". YOU SHOULD NEVER BUY ANYTHING COMING FROM THIS CRAPPY COMPANY. This PSU is most certainly the cause for all my problems, from fried peripherals to the latest boot problems.
                      I've opened the PSU and I've found the ugly part. FIVE CAPACITORS ARE DAMAGED. Three medium size caps are swelled, and discharged from the top. Two huge caps seem to have leaked from the bottom.
                      Unfortunately I don't have my digital camera right now, but I'll keep the old PSU and post a few photos when I have the time.
                      Here is the dead capacitors info:
                      Fuhjyyu 1650uF16V; top bulged and leaked
                      Fuhjyyu 1000uF10V (2x); top bulged and leaked
                      CapXon 330uF200V (2x); massive leak suspected from the bottom*
                      (*or it might be a sealant or an isolation foam, I'm not competent enough to tell the difference)
                      Thanks all, now my system runs smoothly. Replacing the PSU cost only 70$, an hour trip downtown and 15 minutes of easy work. I'm a happy camper.
                      • Rainbow
                        • Aug 2005
                        • 1371
                        L&C and DEER are known crap PSU manufacturers.
                        There's a lot of bad Fuhjyyu caps recently.
                        The substance around the bottom of the big caps is most likely some kind of glue - it's present in most PSUs.
                        • Newbie2
                          • Sep 2005
                          • 885
                          Are you going to recap this L&C (Deer) power supply?
                          It can be a temporary backup, but chances of the Enermax failing are really, really low. But, I keep any PSU that still works, even these crappy L&C power supplies.
                          My gaming PC:
                          • kc8adu
                            • Nov 2003
                            • 8829
                            • U.S.A!
                            i doubt i would bother with recapping that one.
                            i see far too many catastophic failures with deer units.as i say non passive end of life.
                            • Hugo
                              • Jan 2006
                              • 13
                              This PSU is probably worth 15$-17$, I wouldn't bother recapping just for the fun of it. At least I know what failed -- the capacitors. But I'd say this PSU was producing low quality voltage from day one; it just doesn't filter right.
                              I've just realized how computer shops can come up with "fantastic offers" by using some cheap components where the customers won't look (PSU, USB cards, generic components such as CD-RW players). If you choose an excellent motherboard with the best CPU around, it's almost criminal to install it in a cheap case with a disastrous PSU.
                              • kc8adu
                                • Nov 2003
                                • 8829
                                • U.S.A!
                                a store i work with found out the hard way about these crap psu's
                                echo star,a-power,powmax,mge,deer they had them all.in a good box with extra fans the apower and mge last 2 months before they get dirty enough to cause the system to become unstable.
                                like i said earlier 500w my ass.
                                weighs less than a pound.
                                psu orders go thru me now.everyone got tired of these things coming back like a boomerang.
                                gotta take a pic of the heap o junk before they get sent back to evertek.there is at least a dozen from the last month.
                                • Hugo
                                  • Jan 2006
                                  • 13
                                  Was Enermax a good choice, then?
                                  The only other option in the hardware shop was a 160$ PSU with a front panel display of the temperature and a knob. Nice, but too expensive for me.
                                  I live in a not-so-big town so the choices are sometimes limited.
                                  But I wouldn't trade the landscape for more computer shops!
                                  • Hugo
                                    • Jan 2006
                                    • 13
                                    There it is:
                                    http://www.enermax.com.tw/english/pr...y1.asp?PrID=29
                                    It's about the least expensive of their products, but it's got the same quality as the more expensive ones.
                                    Nice little thing. Saved my computer's life.
                                    And it was a pleasure to install.
                                    • Hugo
                                      • Jan 2006
                                      • 13
                                      For the record, here's a tentative picture of the 3 caps. Unfortunately, the goo over the 2 caps on the left had dried, and it partly went away when I cleaned up the board with a vacuum cleaner.
                                      • tylerlough
                                        • Dec 2005
                                        • 96
                                        i have a soon to be replaced L&C and I replaced thoses same three caps that were bad and now it is doing ok.
                                        Enermax is a good brand but i've seen some reveiws of them going up like the 4th of July or in your case canada day(I think). That was for the 600watt, people said good things about the 350watt.
                                        • privato89
                                          Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                          by privato89
                                          I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                          Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                          Let's begin:
                                          Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                          03-26-2024, 06:37 AM
                                        • hinisa
                                          Xiaomi router freezes at boot after re-capping
                                          by hinisa
                                          I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                                          When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                                          After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                                          Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                                          07-08-2023, 05:58 AM
                                        • Luke Anders
                                          Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                                          by Luke Anders
                                          A few details about the laptop itself:
                                          Name: Lenovo Legion 5
                                          Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                                          BIOS Version: GKCN60WW
                                          EC Version: GKEC65WW
                                          Serial Number: PF39AQ7Z
                                          Board Model: NM-D562 Rev 3.0
                                          RAM: 16GB Installed, DDR4 (brand new)
                                          NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                                          I bought this laptop recently from eBay as a faulty device....
                                          10-12-2024, 05:13 AM
                                        • NolesFan
                                          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                          by NolesFan
                                          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                          10-24-2024, 06:36 PM
                                        • torchzack
                                          Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                          by torchzack
                                          Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                          I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                          Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                          08-28-2023, 07:42 AM
