Re: Vizio 42" M420SL works then goes blank
check the big capacitor on powerboard, carefully VERY HIGH VOLTAGE THERE, meter set to dcv probe on each leg, see what voltage you get with tv powered on, see If its around 400 or so, see what the voltage is while its working and after it shuts down.
Good Morning TV'ers
Vizio usually starts and works fine for a few minutes then goes blank. Checking voltages when shutdown it reads 5v on the standby pins on the PS and 12v on the 12v pina, backlights are out now. What can I conclude or where to next.
Thanks in advance
burnsTags: None
I've got a Hanns.G Hi221 Monitor that works for a moment and then the display goes off but the power LED indicator remains on. If you power it off and back on again it does the same thing, it comes on and then the display goes blank. From a cold start it takes 10 seconds or so before the display goes blank but if you turn it off and then back on again after it already being on it goes blank a lot quicker so I'm assuming something is getting hot which is causing the display to go off.
I've uploaded a video of it happening on YouTube:
I've taken the monitor...-
Assuming...7 Photos -
by bobbyskillzHello, experts! I have a weird issue I've never seen before. I know some of you have definitely seen this. I think some have seen in. I'd greatly appreciate any advice you can give me.
I bought a E241i-a1 to use as a monitor. It powers on, displays the image, and has sound. I just can't get the OSD to go away. The TV doesn't respond to any input from the remote contol or buttons except for the power button. Is this a firmware issue? I can't access settings to reset it. A quick search for the firmware has no results. I'm lost. Please throw some ideas at me.
Thanks for... -
by mecha1166Hello, we have 4-6 of these sets now. All have blank screens, or slow-moving colors (looks like tie-die shirt). Some have narrow white lines and color around it.
We have tried a new main and several tcons (2 exact and 2 similar). Same thing. Probably a panel - has anyone had this issue? These are fairly new sets, all but one came from rental.I own one, it was junked out. I tried searching for this model in forums but the search showed no threads for this model number. Thanks for any input! -
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... - Loading...
