Vizio 42" M420SL works then goes blank
  • pdsterns
    • Oct 2022
    • 28
    Good Morning TV'ers
    Vizio usually starts and works fine for a few minutes then goes blank. Checking voltages when shutdown it reads 5v on the standby pins on the PS and 12v on the 12v pina, backlights are out now. What can I conclude or where to next.
    Thanks in advance
    burns
  • nomoresonys
    • 12328
    • U.S.
    Re: Vizio 42" M420SL works then goes blank
    check the big capacitor on powerboard, carefully VERY HIGH VOLTAGE THERE, meter set to dcv probe on each leg, see what voltage you get with tv powered on, see If its around 400 or so, see what the voltage is while its working and after it shuts down.
    • pdsterns
      • Oct 2022
      • 28
      This time the TV did not power up. Nothing there, zero on 200 vdc scale. Checked the 12v and its still there
      burns
      • nomoresonys
        • 12328
        • U.S.
        did you set the meter to above 200, whats next 400? try that if you didnt.
        • pdsterns
          • Oct 2022
          • 28
          Yup, meter on 600vdc, nothing there
          • nomoresonys
            • 12328
            • U.S.
            saw a similar board, maybe try UNHOOK cable from powerboard to mainboard, use 3 around 1K resistors to jump from pwr-on to stby, bl-on to stby, c-dimming to stby, plug power cord in and see if you get proper voltages and backlights come on and stay on.
            • pdsterns
              • Oct 2022
              • 28
              How can I get into those pins with that tiny connector? and if all were ok does it indicate a PS problem or a MB problem? I'm willing to buy a board I just don't know which one, maybe even Tcon
              Update: The TV came up, with no jumpers, and I measueed across the big cap and it has 380vdc
              • nomoresonys
                • 12328
                • U.S.
                thats what the test in post 6 can determine, if backlights come on and stay on with that test, then your powerboard and backlights are prolly ok.
                • nomoresonys
                  • 12328
                  • U.S.
                  what I have seen mostly when tv works for a few minutes before going blank is bad cap/s or backlight issue, try heating the capacitors on the powerboard with a hairdryer, start with the ones closest to the connector, heat them for a couple minutes then try the tv, see if theres any difference, DON'T wait til it cools to try it, do it while its hot, also check all the solder joints, examples of bad joints there: https://www.google.com/search?q=bad+...ih=607&dpr=1.5
                  • nomoresonys
                    • 12328
                    • U.S.
                    also you can try turning down the backlights or brightness, turn them way down if you can in the short time it remains on, then see if the tv stays on for a longer period than it did before.
                    • pdsterns
                      • Oct 2022
                      • 28
                      Heating the caps near the connector yielded a steady ON and I was able to turn it off and on repeatidly. So does it come down to just needing a PS board or replacing the caps, there are 2 small ones and 2 larger ones.?
                      • pdsterns
                        • Oct 2022
                        • 28
                        WOW, heated about 10 times now, 100% success rate
                        • nomoresonys
                          • 12328
                          • U.S.
                          cool, yep just replace those caps, should be good to go then, sure, replace all 4 with good quality low esr 105 caps, they might not all 4 be bad but who wants to keep going back in just for the cost of a few caps.
                          • pdsterns
                            • Oct 2022
                            • 28
                            Well there are 3 different size caps there and 9 overall and since I don't have any and don't even know if the is conformal coating on the back of the board making it difficult I think I will opt for a replacement board unless you suggest the larger or smaller ones etc. Just thinking of the easier option here. Thoughts?
                            • nomoresonys
                              • 12328
                              • U.S.
                              your call, the thing about a replacement board is the caps are probably also 10 years old, they're not too hard to change, but if not soldering often maybe practice on a scrap board, suppose you could isolate which one/s need changing by isolating which ones let the tv turn on when heated, like only heat one or two at a time to isolate the bad one/s, its not a huge tv so if you had to change another cap down the road, no big deal.
                              • pdsterns
                                • Oct 2022
                                • 28
                                Well I was going to try and isolate to a particular cap or two and replace them hoping it was the larger ones but now the TV works normally after heating the caps with the hair dryer. Just a temporary situation, I am sure, so I think I will take the easy way out and just buy a board. Guys thanks for your help, I have an LG to fix next, lol, picture, no sound 55LB6300
                                • nomoresonys
                                  • 12328
                                  • U.S.
                                  for sound issue try, turn off tv, unplug any accessories, cable box, dvd, etc. unplug tv from power, press and hold power button for 30 seconds, plug tv power back in and try it.
                                  • nomoresonys
                                    • 12328
                                    • U.S.
                                    can also go into your sound settings, look around in there, make sure internal speakers are selected, might also be a reset sound and maybe a sound test in those settings somewhere.
                                    • nomoresonys
                                      • 12328
                                      • U.S.
                                      this is strange, did you let it sit off overnight, then let it run a few hours?
                                      • nomoresonys
                                        • 12328
                                        • U.S.
                                        there is a "dirty" test for those caps, set your meter to 20k ohm setting, put a probe on each leg, the meter should read a steady rise or fall, switch probes and watch should be steady rise or fall, just switch probes back and forth and see what you get, the one/s that seem to act different than the rest are prolly the culprit.
                                        • RetroComputingGrotto
                                          Hanns.G Hi221 Monitor - Works For A Second & Then Blank Display
                                          by RetroComputingGrotto
                                          I've got a Hanns.G Hi221 Monitor that works for a moment and then the display goes off but the power LED indicator remains on. If you power it off and back on again it does the same thing, it comes on and then the display goes blank. From a cold start it takes 10 seconds or so before the display goes blank but if you turn it off and then back on again after it already being on it goes blank a lot quicker so I'm assuming something is getting hot which is causing the display to go off.
                                          I've uploaded a video of it happening on YouTube:
                                          I've taken the monitor...
                                          01-11-2024, 05:37 AM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • bobbyskillz
                                          Vizio E241i-a1 - works, but OSD stuck and no buttons work
                                          by bobbyskillz
                                          Hello, experts! I have a weird issue I've never seen before. I know some of you have definitely seen this. I think some have seen in. I'd greatly appreciate any advice you can give me.
                                          I bought a E241i-a1 to use as a monitor. It powers on, displays the image, and has sound. I just can't get the OSD to go away. The TV doesn't respond to any input from the remote contol or buttons except for the power button. Is this a firmware issue? I can't access settings to reset it. A quick search for the firmware has no results. I'm lost. Please throw some ideas at me.
                                          Thanks for...
                                          07-02-2025, 03:43 PM
                                        • mecha1166
                                          Vizio V585-J11 & V585-H11 Blank or tie-die image on screen
                                          by mecha1166
                                          Hello, we have 4-6 of these sets now. All have blank screens, or slow-moving colors (looks like tie-die shirt). Some have narrow white lines and color around it.
                                          We have tried a new main and several tcons (2 exact and 2 similar). Same thing. Probably a panel - has anyone had this issue? These are fairly new sets, all but one came from rental.I own one, it was junked out. I tried searching for this model in forums but the search showed no threads for this model number. Thanks for any input!
                                          07-14-2023, 07:23 AM
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
