Vizio E241i-a1 - works, but OSD stuck and no buttons work
  • bobbyskillz
    • Dec 2010
    • 76
    Hello, experts! I have a weird issue I've never seen before. I know some of you have definitely seen this. I think some have seen in. I'd greatly appreciate any advice you can give me.
    I bought a E241i-a1 to use as a monitor. It powers on, displays the image, and has sound. I just can't get the OSD to go away. The TV doesn't respond to any input from the remote contol or buttons except for the power button. Is this a firmware issue? I can't access settings to reset it. A quick search for the firmware has no results. I'm lost. Please throw some ideas at me.
    Thanks for your time!
  • Diah
    • Feb 2013
    • 6614
    we need more info about how you use it as monitor ! did you use it via HDMI Port or PC/VGA port,? if you used it at HDMI which yours TV had only one port, this port used ARC & CEC which related the client PC / or DVD or any others will have the access to control the TV.
    • Aliencomputres
      • Aug 2019
      • 220
      • România
      Helo,
      Check all the buttons, maybe one of them is stuck.
      • DynaxSC
        GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
        by DynaxSC
        I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
        General test conditions:
        - Tested with Core i5 6500 and Core I7 6700K - no difference
        - Default BIOS settings, but tried also altering several memory setting - does not change anything
        What is wrong:
        With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
        When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
        03-21-2025, 06:23 PM
      • kotel studios
        ASUS M5A78L-M LX - PWR button works sometimes, CPU stuck in reset
        by kotel studios
        Firstly I'd like to apologize if this was posted in the wrong forum (I'm new here )
        Recently I got an ASUS M5A78L-M LX board in a scrap lot. Saw one broken cap which I've replaced. No broken traces and missing components. While soldering a new cap a bit of solder got onto components bellow SB (opposite of the two lythic caps). Didn't see it and powered the board on.
        I was greeted with it not starting. Came back to it a day later and shorted the PS_ON with GND to force it on. It sprung to life but with CPU stuck in reset (it was an FX 4600 I believe). Thats when I saw the...
        12-14-2024, 10:48 AM
      • x_orange90_x
        Vizio V555-G1 stuck on wallpaper; now stuck on V logo
        by x_orange90_x
        I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
        12-28-2023, 06:26 AM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • Stunt
        Hp Laptop Stuck on Hp protected by hp sure start screen
        by Stunt
        Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
        I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
        I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
        Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
        screen that's it and stuck there. I left it until the following day and i still...
        09-02-2025, 01:51 PM
