Vizio V585-J11 & V585-H11 Blank or tie-die image on screen
  • mecha1166
    • 37
    Hello, we have 4-6 of these sets now. All have blank screens, or slow-moving colors (looks like tie-die shirt). Some have narrow white lines and color around it.
    We have tried a new main and several tcons (2 exact and 2 similar). Same thing. Probably a panel - has anyone had this issue? These are fairly new sets, all but one came from rental.I own one, it was junked out. I tried searching for this model in forums but the search showed no threads for this model number. Thanks for any input!
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: Vizio V585-J11 & V585-H11 Blank or tie-die image on screen
    I would take an oscilloscope and look at the LVDS pairs on the main board and make the OSD come on and off. If you see a change on the oscilloscope screen, your good in that department. After that I’d look at the board with the tab bonds. Maybe someone had “washed” the TV, or something else is amiss there. Hard to tell what happened without seeing this thing.
    • mecha1166
      • 37
      Thanks for the info. I'll check the lvds info and the tabs. Probably shorted chips on the panel circuit board strip. All 6 were in different homes. I've seen the damage that maids in hotels can do when they are "washing" the flat screen tvs!
      • dicky96
        HP Elitebook Screen blank - backlights but no image
        by dicky96
        Hi guys
        I'm trying to fix this laptop screen
        Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
        OK so I have the original screen which works but has lines across the bottom quarter of the screen
        I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
        04-28-2021, 07:30 AM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • Chrissygizmo
        Panasonic TX-48CX350B backlights but white screen , blank screen
        by Chrissygizmo
        Hi all, I’ve got a problem I hope someone can help me fixi.
        I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
        01-11-2025, 03:18 PM
      • x_orange90_x
        TCL 50S535 bad tcon or panel issue?
        by x_orange90_x
        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
        03-29-2025, 11:02 PM
      • kotel studios
        Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
        by kotel studios
        Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
        State I got it in:
        Squealing from the PSU
        After logo I get a blank screen
        After 10 seconds of having a blank display w/ backlight the TV dies
        Give it 7-10ish seconds again and it starts to bootloop.
        What I did so far:
        Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
        Checked all voltage rails:
        5VSB - 4.8V
        AMP+13V - 14.4V
        13V - 12.98V (in manual 12V)...
        09-21-2025, 02:00 AM
