Samsung UE50TU7000K backlights on, no picture or sound
  • notallbad
    • Oct 2012
    • 1190
    Plug in and backlights with Smart Tv powered by Tizen logo shows on screen
    then nothing, no stby led or response to remote, no sound from hdmi input.
    This has only 1 board, a 3in1_kant_su2.
    Try a usb stick with update firmware from Samsung and usb stick just flashes a couple of times, recognises usb, but thats it.
    Remove ribbon to panel, same results.
    I believe the leds are in an array of 3 x 12 @3v/led, going by what led sets are being sold for this tv on ebay and aliexpress.
    1 string of 12 leds, power supply in 84v, out 54v, voltage drop 30v
    1 string of 24 leds, power supply in 185v, out 84v, voltage drop 100v
    which the string of 24 leds doesnt seem right!
    Though still not ruling out bad panel or board.
  • notallbad
    • Oct 2012
    • 1190
    Re: Samsung UE50TU7000K backlights on, no picture or sound
    Any thoughts on where to start with this one please.
      • 12167
      • U.S.
      maybe try the easier things first, test the diodes and resistors on top of the board if you have not already.
      • notallbad
        • Oct 2012
        • 1190
        Ok. yh diodes and resistors seem fine.
          • 12167
          • U.S.
          maybe test QP811? on the heatsink, can't see the last number there, see if any of the legs test short to the other 2, may have to penetrate the glue with the probes to get a reading, see if any of the little mlcc ceramic caps are shorted or have very low ohms, test any voltage regulators, maybe check the pins on the connector of the panel driver board, thinking there should be 12 volts on one when working properly. Can test the panel driver board test points VGL etc.
          • diif
            • Feb 2014
            • 6978
            • England
            No, if you think about that is happening, the TV shows a picture, it's not power components or the panel.
            Maybe LEDs, that voltage doesn't seem right.
            • notallbad
              • Oct 2012
              • 1190
              ok this is what someone is selling on ebay for exact same tv, I believe.
              The red connector goes to power/main 3in1 kant board, then there are 3 led connectors, 2 of which have shortish leads between them so guessing they connect to the full array set of leds, all 36 leds (3 strips of 12/strip), which makes sense according to the voltage reading of 100v drop which would be enough for all 36 leds, 36 x 2.7v= 97.2v, but the 3rd led connector has a very long lead so must go elsewhere, edgelit too perhaps? puzzled here!
              only way to know for sure is expose the leds but really only want to do that as a last resort for obvious reasons.
              • notallbad
                • Oct 2012
                • 1190
                I cant see any obvious signs/presence of edgelit from the rear panel, only see where there are 3 led strips so my best guess is that this panel has more leds than 36.
                • vinceroger69
                  • Mar 2012
                  • 6714
                    • 12167
                    • U.S.
                    well its not an old tv but anything can be wrong from a bad/weak cap to backlights, I would tear it down and check, seems more time consuming but I usually get it done faster than I can test everything else, with panels about 55 or less that is, still need to treat those panels like a newborn, they are all easy to break.
                    • notallbad
                      • Oct 2012
                      • 1190
                      ok thanks for help but not going to waste anymore time on this so going to trash it.
                      Too expensive to buy a 2ndhand board only to find its the panel afterall, which I think it is to be honest.
                      • Storyteller12
                        • Jun 2020
                        • 624
                        It’s most likely the panel. A lot of the nu, tu and ru series have panel issues. You can try the tape method since it’s free and wont cost anything.
                        • notallbad
                          • Oct 2012
                          • 1190
                          Attempted the cut-off method but no luck getting any kind of image on the screen. Possibly not getting the correct pins blanked off.
                          Removed the panel to look at the backlights, all appear to be working, however the connector between 2 of the strips was not getting a good connection so linked them across to give a good connection before reassembly.
                          Still no difference! except the Smart tv powered by tizen logo on powerup is much brighter and clearer.
                          The led connector at psu/main board has 4 wires, 2 wires go to the bottom strip (12 leds) and 2 wires go to the top and middle strips (24leds).
                          With the led connector removed there is 244v going to the top/middle strips but nothing on the other supply pin.
                          Plugged back in theres 167v in 95v out on the 24leds and 95v in 65v out on the 12leds.
                          The 95v output voltage from the 24leds is fed back into the 12leds from the 3in1 board.
                          This is for info really I suppose but still hoping something comes to light and can get it working again.
                          I am still of the opinion that there is a fault on the 3in1 board. It powers up as soon as its plugged in, no picture other than the startup splash logo and no audio.
                          There is response from the remote, well the led flashes when the remote is operated vol up/down etc.. think it probably was all along, just that I never noticed it as its underneath the panel and not easy to see.
                            • 12167
                            • U.S.
                            well test all the components, can also test the panel driver board ala post #5.
                            • notallbad
                              • Oct 2012
                              • 1190
                              Voltages around the main board all seem present and ok from what I can see.
                              On the panel boards there are 2 banks of 6 M35 transistors which have a voltage switching between -11v and +30v, is this normal?
                              Theres a -11v on the main that stays constant, VOFF_-11V_PW.
                              • Rajnhl
                                • Oct 2018
                                • 94
                                • India
                                its normal
                                no sound and pic check for firmware
                                • notallbad
                                  • Oct 2012
                                  • 1190
                                  If I hold power button on remote tv does restart.
                                  If i press info menu mute power it restarts but dont seem able to do a reset. even though doing it 'blind".
                                  • notallbad
                                    • Oct 2012
                                    • 1190
                                    Log on usb stick when attempting upgrade from samsung website
                                    SES path not found, exit
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      https://us.community.samsung.com/t5/...b/td-p/1700823
                                      • notallbad
                                        • Oct 2012
                                        • 1190
                                        Found ver2400.9 but still the same, ses path not found.
                                        • stinger
                                          Samsung UN70TU6980FXZA no sound no picture but does have backlights
                                          by stinger
                                          When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
                                          04-17-2024, 03:06 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
