Sony KDL-55W755C - Dead
  • lotas
    • Jan 2016
    • 4573
    • Russia
    Re: Sony KDL-55W755C - Dead
    Sony 1-893-880-11 eMMC pinout.
    • CapLeaker
      Leaking Member
      • 8133
      Originally posted by diif
      Your previous post you say it takes time to find where to attach the wires. My way would be quicker and if it's faulty it has to come off anyway.
      There's more than one way to do things, it depends on the tools and skills on hand and time.
      I do agree somewhat. That is assuming you have everything you need, including the low melt solder. For someone doing this stuff occasionally, probably not.
      • diif
        • Feb 2014
        • 6978
        • England
        What's the low melt solder for ?
        • CapLeaker
          Leaking Member
          • 8133
          So you get the EMMC back on without blasting it too long with high heat and risk going bad because of it. EMMC’s don’t like that very much.
          • diif
            • Feb 2014
            • 6978
            • England
            There's never any need for high heat or blasting very few components like it, that's just poor hot air control.
            I've not heard of eMMCs being more delicate to heat than other components and I used hot air as i usually do on the couple I've replaced.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4313
              • Italy - Milan
              #26
              for emmc soldering must use under placed heating plate to preheat board, then you can speed up hot air job..
              • mrsith
                • Mar 2021
                • 146
                • Wielka Brytania
                #27
                I do have a preheater, microscope and a low melt soldering paste, did some tiny cap replacements on iPhones etc so I feel pretty confident with that stuff. Still hate BGAs though. With the pinocut available in #21 I'll try reading/dumping first.
                • ppeti84
                  • Feb 2016
                  • hungary
                  #28
                  Managed to do it?
                  I am looking for a save for this motherboard.
                  • dkneyle
                    Sony KDL-46HX850 Can't upgrade/update firmware
                    by dkneyle
                    Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                    Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                    09-25-2024, 10:44 PM
                  • joby91
                    SONY KD-55AF9 OLED MAIN-BM3-1-983-356-11 EMMC Firmware
                    by joby91
                    I have SONY KD-55AF9. Mainboard MAIN-BM3-1-983-356-11 with defekt EMMC.
                    I wanted to buy new EMMC and Flash the firmaware on it. Does anyone have the firmware for this TV. I would be really grateful.
                    I found one chat about firmware on ************** forum but i cannot read the comments.
                    https://**************/forum/108-114100-1#880537
                    09-04-2024, 01:34 PM
                  • jason123
                    Sony Firmware for XBR-70X850B
                    by jason123
                    Hello
                    Help is much appreciated. I have a Sony XBR-70X850B with bad main board. I got a mainboard for it, but as you know I have to update the firmware on this TV for the main board to work.
                    I went to the Sony website, and I can't seem to find the Firmware file. Sony is no longer making this available.
                    Does any of you have firmware / software files for this TV that I can put on USB for update to make this main board work?
                    Much appreciated.
                    05-17-2022, 12:42 PM
                  • Andreasbest
                    Dell Latitude 7410 dead and amber light as long power button is pressed.
                    by Andreasbest
                    Hello.
                    I received a bios locked 7410 with 25Q256JVEQ ,i dump the bios, unlocked it and flash it back, since then the laptop has no life signs at all except amber led on for as long the power button is pressed, nothing else.
                    Fact #1 i was unaware that 25Q256JVEQ is 3.3v and i used a 5v CH341A to program it, not sure if the chip got damaged but since then i can read it and write it normally, doesn't seem dead.
                    Fact #2 i modded the CH341A to 3.3v, same results with programming though, nothing changed.
                    Fact #3 i tried hard reset with cmos/main battery disconnected and power...
                    12-21-2024, 02:02 PM
                  • AlexWhat
                    SONY KDL-65w850c need latest firmware 6.827
                    by AlexWhat
                    In 2022 SONY did "Termination of TV Software Update" for this model.
                    I did find older firmware but it can't be installed over newer one (rolled back)
                    Yes, got boot loop during android load so if that will not work then EMMC has to be replaced, I think.
                    12-15-2024, 11:32 PM
