Philips 55PUS6754 with lines after few seconds
  • marekk
    • Mar 2013
    • 36
    I have tried to replace TCON but it didn't help.
    The strange is that it shows Philips logo before the lines. Tried to cover some of the lines with tape on the ribbons to the screen but had no success.
    screen: tpt550u2-eqya3.g
    tcon: 6870C-0769A
    I will appreciate any help
    Many thanks
    Marek
    • 12307
    • U.S.
    Re: Philips 55PUS6754 with lines after few seconds
    are you saying you replaced tcon and have the exact same display?
    • marekk
      • Mar 2013
      • 36
      Yes, I have replaced tcon and I got very similar lines after a few seconds
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4518
        • Italy - Milan
        replace original tcon, first, then make clear photos of main board, frc board eventually, no flash, direct sun light..
        • kca
          by kca
          Hello all ~
          08-31-2025, 06:38 AM
        • rtstorm
          Philips 55PUS7303 LCD lines
          by rtstorm
          Hello, I have this 55" Philips TV that suddenly has these vertical lines on the LCD panel. I have checked the T-con board and I noticed some caps have 40Ohm I don't know if this is normal. These caps have 1.2V on them. I mark them on the photo with a silver pen. The T-con board has 1.2V, 12V, 25V, etc. Does anyone have any idea what could it be?
          i try to disconect one ribon cable and the problem is the same, one side is white other side have the lines (the same is in other way)
          T-con model: 55T32-C0L
          Main Board: 715G8579-M0F-B01-005T
          03-28-2024, 02:55 PM
        • alpersen
          Philips 40 PUK6809/12 Backlight turns off after 10-20 seconds
          by alpersen
          Hello
          Mother called and said TV turns off after switching on. So after turning on Philips logo shows and probably 10-20 seconds image disappears, sat receiver is connected and sound is heard from source. So I turned on my phones light and I can see the image it seems backlight was off after some time. I dis assembled the cover hoping to see a distinc cap blown or leakage. Here are photos I took (I was after 22:00 pm and maybe some of them are dark). Should I order and change caps on the power circuit or what would you recommend? Thanks...
          07-25-2024, 12:50 AM
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • netgearnetgear
          TCL 43S423 TCON OR PANEL FAULTY???
          by netgearnetgear
          Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
          08-20-2025, 06:04 PM
