Philips 43PFS5803
  • Sraros
    • Jan 2017
    • 223
    • Greece
    Philips 43PFS5803
    I received this 43' TV. It has no standby voltage and the owner had it on when it banged and shut off.
    With a quick look I found one resistor burnt on top side
    R9101 0.24Ω
    and at the back smd resistor R9142 22Ω
    Both were reading with MM in MΩ
    The schematic is attached to this post.
    I investigated nearby components and found N-Mosfet Q9101 is K8A65D1 instead of STF24NM65N as per schematic. The resistance between drain and source is 4.4Ω. Should I consider it shorted and the culprit of the failure or is this normal?
    The photos uploaded are after resoldering new resistors
  • Sraros
    • Jan 2017
    • 223
    • Greece
    Re: Philips 43PFS5803
    Correction R9104 not R9142.
    Also R9106 and R9103 are also burnt reading over 10kΩ
    IC U9101 seems ok
    • dskall
      • Oct 2016
      • 2905
      • usa
      Had the mosfet been changed before? I think one was 8A and called for 24A.
      • R_J
        • 9588
        If Q9101 shorted and R9101 is open, U9101 is damaged as it would have seen about +300vdc on pin 4(CS)
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4462
          • Italy - Milan
          Replace mosfet first.. if it is shorted between drain-gate check components between gate and ic, get also a new ic this case..
          • Sraros
            • Jan 2017
            • 223
            • Greece
            I found a repair kit that includes IC U9101, mosfet, blue film capacitor and the resistors (even though R9104 is not included but already replaced) so I will change them all.
            Better safe than sorry, specially when my only other option is to buy separately and wait 2 months from China..
            It seems this can be a common problem in this board since there’s a specific repair kit for it.
            I will come back in 15 days when they arrive.
            • Sraros
              • Jan 2017
              • 223
              • Greece
              No for sure not, maybe it's another version of the original board to cut down the cost. The repair kit has the same Mosfet I removed and not the one in schematic
              • Sraros
                • Jan 2017
                • 223
                • Greece
                Update on this. The repair kit did it's job. TV works again.
                IC U9101 was indeed shorted (compared grounds to new one)
                Q9101: K8A65D1 shorted
                The SMD resistors passing through blown.
                All the 0 resistors ok. Fuse and caps ok
                • alro7779
                  Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                  by alro7779
                  Hello, guys!
                  The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                  09-14-2025, 12:25 AM
                • G33RT
                  Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                  by G33RT
                  Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                  It does power up when pressing the power button.
                  I already try the power button while plugin the plug with no result.
                  Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                  Could this be an PSU or eMMC issue ?
                  07-19-2025, 03:43 AM
                • double_DD
                  Philips curling iron - is this a common AC cable?
                  by double_DD
                  Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                  As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                  Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                  08-18-2025, 10:04 AM
                • janos6662000
                  Philips 47PFS7509/12 LCD TV problem
                  by janos6662000
                  Hi
                  I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                  When i applied cable signal to check image, i had normal picture, but TV was restarting.
                  I downloaded original firmware and applied the update, but the problem remained.
                  From a colleague i received a "factory package software" which is a lot bigger.
                  I made another firmware update, but still did not solve the problem.
                  Somewhere on the way the error got worse, because at the moment the...
                  08-12-2025, 12:54 PM
                • aidanmo
                  Philips 43PUS7506/12 - Loud blown out sound
                  by aidanmo
                  I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                  I thought maybe the speakers got damaged, so I replaced them - no dice.
                  • Using the internal speakers, it always happens.
                  • Using the headphone jack, it never happens.
                  • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                  02-28-2025, 03:13 PM
