Philips 43PFS5803
  • Sraros
    • Jan 2017
    • 223
    • Greece
    Philips 43PFS5803
    I received this 43' TV. It has no standby voltage and the owner had it on when it banged and shut off.
    With a quick look I found one resistor burnt on top side
    R9101 0.24Ω
    and at the back smd resistor R9142 22Ω
    Both were reading with MM in MΩ
    The schematic is attached to this post.
    I investigated nearby components and found N-Mosfet Q9101 is K8A65D1 instead of STF24NM65N as per schematic. The resistance between drain and source is 4.4Ω. Should I consider it shorted and the culprit of the failure or is this normal?
    The photos uploaded are after resoldering new resistors
  • Sraros
    • Jan 2017
    • 223
    • Greece
    Re: Philips 43PFS5803
    Correction R9104 not R9142.
    Also R9106 and R9103 are also burnt reading over 10kΩ
    IC U9101 seems ok
    • dskall
      • Oct 2016
      • 2905
      • usa
      Had the mosfet been changed before? I think one was 8A and called for 24A.
      • R_J
        • 9514
        If Q9101 shorted and R9101 is open, U9101 is damaged as it would have seen about +300vdc on pin 4(CS)
        • Davi.p
          Hobbist
          • Sep 2009
          • 4264
          • Italy - Milan
          Replace mosfet first.. if it is shorted between drain-gate check components between gate and ic, get also a new ic this case..
          • Sraros
            • Jan 2017
            • 223
            • Greece
            I found a repair kit that includes IC U9101, mosfet, blue film capacitor and the resistors (even though R9104 is not included but already replaced) so I will change them all.
            Better safe than sorry, specially when my only other option is to buy separately and wait 2 months from China..
            It seems this can be a common problem in this board since there’s a specific repair kit for it.
            I will come back in 15 days when they arrive.
            • Sraros
              • Jan 2017
              • 223
              • Greece
              No for sure not, maybe it's another version of the original board to cut down the cost. The repair kit has the same Mosfet I removed and not the one in schematic
              • Sraros
                • Jan 2017
                • 223
                • Greece
                Update on this. The repair kit did it's job. TV works again.
                IC U9101 was indeed shorted (compared grounds to new one)
                Q9101: K8A65D1 shorted
                The SMD resistors passing through blown.
                All the 0 resistors ok. Fuse and caps ok
                • aidanmo
                  Philips 43PUS7506/12 - Loud blown out sound
                  by aidanmo
                  I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                  I thought maybe the speakers got damaged, so I replaced them - no dice.
                  • Using the internal speakers, it always happens.
                  • Using the headphone jack, it never happens.
                  • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                  02-28-2025, 03:13 PM
                • Cornito
                  Philips 50PUH6400 bad color and gosting / slow motion on one side
                  by Cornito
                  Hello Team,
                  New issue on LCD panel where I need to find out the cause and the potential solution.
                  This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
                  I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
                  When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
                  I've checked voltages, no issue found comparing right and left side of the panel driver.
                  VHG VGL CKV... are the sames on...
                  03-08-2024, 06:41 AM
                • spantor
                  Activate power board Philips 40PFH40009/88 tv
                  by spantor
                  Hello partners.
                  Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
                  The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
                  02-11-2024, 05:07 PM
                • lanada
                  philips 55pus7909/12
                  by lanada
                  i have a philips for repair 55pus7909/12
                  fault is no display but the white logo philips lit below of the screen
                  No display
                  No backlight
                  no sound
                  power supply the standby voltages are ok
                  Any Help regarding this problem?
                  11-07-2023, 02:31 AM
                • betmen
                  TV Philips 40PFT4101/12 - power on loop
                  by betmen
                  TV is Philips 40PFT4101/12, power supply 715G6934-P01-000-002M, motherboard 715G6947-M002-000-004Y (703TQGPL068).
                  The problem is that when it is plugged in, the TV turns on by itself, the Philips sign appears, the backlight turns on and off a couple of times, and the TV turns off, and so it repeats itself in a circle. It does not respond to the remote and nothing is written on the screen, the red light does not blink.
                  A few weeks ago, it used to turn on by itself about once a week, but after that it worked, now it doesn't work.
                  I checked the power supply, voltages are fine,...
                  11-05-2023, 05:45 AM
