ONN 100012588 Has fluctuating Voltage on PSU 12v
  • triplefour
    • May 2014
    • 1747
    Re: ONN 100012588 Has fluctuating Voltage on PSU 12v
    Originally posted by R_J
    Did you replace R355 with a 2.2Ω? or just leave the one that checked 20.1k
    i havent replaced that resistor. i guess thats the next logical step. i guess i was thinking to look around for other bad components. but oh well its just a 2.2ohm resistor...if i lose one no big deal. can i just replace it with any regular resistor or do i have to use a surface mount?
    Don't fear the repair...
    • R_J
      • Jun 2012
      • 9627
      Yes you can replace it with a regular resistor, anything from 1~10Ω should be fine, That is why the circuit is not working. The transformer aux winding supplies the high freq. a/c to D107 anode, it provides about 25vdc to charge EC103 to keep the circuit operating.
      • triplefour
        • May 2014
        • 1747
        Dang I replaced that resistor with another 2.2ohm. Still have the fluctuating voltage on ec103. Between 14 and 20v...what else could it be?
        • R_J
          • Jun 2012
          • 9627
          If it made no difference, then check the resistance of the aux winding and check the diode D107, also check D109 and D109.
          Alre you still getting a voltage on the secondary side of the power supply?
          • triplefour
            • May 2014
            • 1747
            So I remembered that when I got the replacement board, I tested it's voltages before hooking up to the mainboard and they were fluctuating. I thought oh no the guy sent me a broken power supply with the same issue. But just to be sure I went ahead and plugged it into the main board and tried it again. The TV came on and the voltages were stable. TV ran for a couple weeks then did the same thing. When I got there, voltages were unstable with or without mainboard. Anyway I just did the same with the repaired power supply and plugged it into the main and plugged the power button into the main. The power supply voltages are stable now and the main seems to respond to button board and powers on and off appropriately. Seems we have identified two things here. A common failure on these power supplies, and also an established baseline that when not connected to a main board, we should EXPECT to see a fluctuating voltage on the psu. Seems strange to me but that's what it is. Anyone have any insight here? Seen other psu that are like this when unloaded?
            But whats really got me worried is if there isn't something else that's causing the power supply to eventually blow this resistor again and I'll be back at dudes house in two weeks.....is there anything else I can do or check before plugging this board back into dudes TV and crossing my fingers?
            • R_J
              • Jun 2012
              • 9627
              It is possible that the VCC voltage will fluctuate when the power supply is in a standby state, They put the main ic in burst mode so it only supplies a burst of pulses to the transformer in standby because the tv does not require much current in that state.
              It is odd for R355 to open, It might be that it's wattage is not high enough and after a couple years running it started to go high in resistance. The vcc line to the ic does not draw that much current.
              • triplefour
                • May 2014
                • 1747
                Personally I've never seen a power supply that did this before but we're always learning so I'm happy to add this to my list of anomalies!
                I also had that thought about why the resistor burnt out and thought to myself I hope I put a resistor in there that at least has a higher wattage rating than the one before it. So I looked up what the wattage ratings on SMD resistors are and it seems like the biggest ones have a rating of about a quarter of a watt. The resistor I replaced this one with has a rating of a half Watt. So hopefully it should be fine right??
                • triplefour
                  • May 2014
                  • 1747
                  ok well i went and installed the power supply in the guys tv and everything works as expected. hopefully it lasts a bit longer than two weeks! will be back here if it blows again to ask more questions why!
                  • nomoresonys
                    • 12332
                    • U.S.
                    #69
                    so the fix was replace that 2.2 ohm resistor, that's all that was wrong?
                    • triplefour
                      • May 2014
                      • 1747
                      Yep that's all I changed
                      • Dr350s
                        • Feb 2025
                        Same problem here, 6 MΩ for R355 ! Replace with 2.2 Ω and now no fluctuation on 12V. Tv is now working ! Thanks a lot !
                        • erickirchey
                          Macbook a2337 820-02016 stuck on 5v fluctuating voltage
                          by erickirchey
                          I am learning any help is appreciated I have a macbook 820-02016 that is stuck on 5v
                          I tested voltage on PPBUS_AON i get 12.6v and it drops to 11.3v I removed fuse f5200 pin 1 PPVBAT_AON_CHGR_REG Becomes stable and no longer fluctuates
                          Pin 1 on f5200 is .51 in diode mode
                          pin 2 is .46
                          Im not sure where to go from here any guidance would be appreciated!...
                          08-26-2024, 02:04 PM
                        • Fernon@Repair
                          Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                          by Fernon@Repair
                          i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                          VCCIO voltage ok
                          VCCSA Voltage OK
                          VCCPLL Voltage OK
                          Ram Voltage ok
                          RamVTT OK
                          VPP 2.5 OK
                          But No Core Voltage
                          and i want to this vrm ic datasheet or pinout (ISL69269)
                          anyone have this ic pinout voltages?...
                          06-25-2025, 07:19 AM
                          Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                          I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                          The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                          Now...
                          06-09-2024, 10:57 AM
                        • electron_jj
                          Panasonic TH-L42D25A checking the PSU output voltage
                          by electron_jj
                          Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                          I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                          08-29-2021, 08:13 AM
                          ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                          3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                          Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                          core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                          configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                          serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                          Based on Intersil's Robust Ripple Regulator...
                          11-05-2024, 03:24 PM
