Macbook a2337 820-02016 stuck on 5v fluctuating voltage
  • erickirchey
    Prem Supporter
    • Aug 2022
    • 24
    I am learning any help is appreciated I have a macbook 820-02016 that is stuck on 5v
    I tested voltage on PPBUS_AON i get 12.6v and it drops to 11.3v I removed fuse f5200 pin 1 PPVBAT_AON_CHGR_REG Becomes stable and no longer fluctuates
    Pin 1 on f5200 is .51 in diode mode
    pin 2 is .46
    Im not sure where to go from here any guidance would be appreciated!
  • CuriousDave
    • Aug 2024
    • 11
    Did you check the CD3215 and CD3217? There is still not enough information to do guess work. What is the voltage and current on the USB volt meter? Please start from there and test the always present if the input is at 20V. Otherwise hard to tell what is missing and what caused it. Is that liquid damaged or just died itself like many others with dead NAND chips?
    • erickirchey
      Prem Supporter
      • Aug 2022
      • 24
      Voltage meter before removing fuse was stuck at 5v .03a-.01a fluctuating after removing its sits at 5v .01a
      To test cd3217 I checked voltage on
      PPDCIN_AON_CHGR_R of both ports and received 5v on both
      PP3v3_UPC0_LDO 3.3
      PP1v5_UPC0_LDO_CORE 1.5v
      PP3v3_UPC1_LDO 3.3
      PP1v5_UPC1_LDO_CORE 1.5v
      • CuriousDave
        • Aug 2024
        • 11
        Please check NAND and every AON rail.AON means always on that killed many machines.
        • duwane
          MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
          by duwane
          Hi All.
          I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
          Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
          After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
          Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
          10-17-2023, 07:48 PM
        • BMCappelletti
          Macbook Air M1 A2337 Stuck At 5V
          by BMCappelletti
          Hi everyone.
          Found some topics here for the same issue, on the same board, but none with all the same values I have or same steps to correct it. And I could not get usefull information from it.
          So... M1, board 820-02016-A, stuck at 5V. Current is 0.08A and from time to time it jumps to 0.13A and back.
          I measured:
          L5230 - 5.1V
          LC320 - 0V (no short)
          LP800 - 0V (no short)
          L5840/5820/5800 - 3.8V
          F5200 - 12.29V (according to an entry on repair.wiki "If the voltage is approximately 12.28-12.35V, it may indicate a communication issue between...
          03-29-2025, 04:55 PM
        • Jonnx
          Macbook Air A2337, 820-02016-A stuck at 5V
          by Jonnx
          Hello everybody,
          I have seen a lot of posts about the A2237/A2338 about the 5V not boosting up to 20V issue, but none of them seem to have the exact problem as my board does.
          My PPBUS_AON was measuring ~9.32V and the board kept power cycling, so I removed the fuse F5200 to measure PPVBAT_AON_CHGR_REG and indeed it was still 9.32V, but the board stopped power cycling. Then I measured U5200 values and got this:
          U5200:
          PPDCIN_AON_CHGR_R = 5.144V
          AUX_DET = 1.287V
          VDD = 2.767V
          VDDP = 2.767V
          AUX_OK = 0.848V
          AMON = 0V
          BMON...
          05-25-2024, 12:00 PM
        • conghuyms
          MacBook Air A2179 stuck logo , pls help me !
          by conghuyms
          Hey everyone,
          I’ve got a MacBook Air A2179 that got some water damage through the keyboard. Now it powers on, shows the Apple logo, but just stays stuck there — no startup chime, no keyboard backlight, and no progress bar under the Apple logo.
          When I try to boot into Internet Recovery (Option + Command + R), the mouse cursor is extremely slow and laggy — like when I lift my finger off the trackpad, the cursor keeps drifting slowly for a second or two.
          I opened it up and found some corrosion around the LED driver IC area on the logic board. I cleaned...
          11-05-2025, 08:30 AM
        • modtool
          Macbook Pro A2289 EMC 3456, MLB 820-1987-A, broken U6903, stuck at 5v
          by modtool
          Dear friends,
          a close friend of mine gave me this machine, she told me that the last days the fan was going high and that it was heating up too much for the usual things, and that suddenly one morning it didn't start anymore .
          I opened it and inspected carefully with a high magnifying lens, found no oxydized spots but a short on PPBUS_G3H , then a blown U6903.
          I changed U6903 with a new one, PPBUS_G3H became 558 (measuring with red probe to gnd , and black on F7000) , PP3V3_G3H_RTC 463.
          Now when I plug the usbc cable (original Apple 61W power supply), nothing starts automatically,...
          10-25-2025, 05:09 AM
