JVC lt-42em73 Flashing Backlights
  • JunkmanJimbo
    • Mar 2017
    • 192
    First I replaced the backlights. Then I found three bulging capacitors, one leaking, on the power supply board. Now, when I turn on the tv, the picture flashes with an image and then the picture goes away. I can unplug the tv and plug it back in, turn it on and the same thing happens. Please help. Thanks!
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: JVC lt-42em73 Flashing Backlights
    Do you still have backlights?
    • JunkmanJimbo
      • Mar 2017
      • 192
      After the backlights are on and flashing for a short time, they go out. I can unplug the power cord and plug it back in and it will do the same thing.
      • comptek
        • Aug 2013
        • 606
        • uk
        Check your soldering work on the psu,
        If it’s a vestel base unit check where the back lights plug in they’re called fingers just wet them with a tiny amount of solder and plug the strips back in hope this makes sense
        • nomoresonys
          • 12145
          • U.S.
          Did you test the new backlights before installation?
          • JunkmanJimbo
            • Mar 2017
            • 192
            I checked the solder at the backlight plugs and they are fine. I disassembled the tv again and checked the backlights again. Removed everything down to the backlights, plugged in the tv and the backlights will flash once and go out. I tried another set of good backlights and they wouldn't even come on at all. So at this point I believe the problem is the power supply board. As I mentioned earlier, I replaced some bulging caps but apparently there's something else wrong with it. Sorry for the delay in responding but I haven't had the time to mess with the tv. Any ideas? Thanks in advance!
            • diif
              • Feb 2014
              • 6978
              • England
              You only replaced the visibly bulging caps ? There's a good chance more have failed and need replacing.
              • JunkmanJimbo
                • Mar 2017
                • 192
                You're probably right. This board has vent capacitors with no value listed on them. How can I determine the value of these capacitors?
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  How did you identify the bulging caps previously ?
                  • JunkmanJimbo
                    • Mar 2017
                    • 192
                    The capacitors I replaced had the value printed on them. Only the vent caps don't have a value.
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      Have you removed one and had a look all the way around ?
                      • nomoresonys
                        • 12145
                        • U.S.
                        get out the hairdryer and heat all those caps, then see if the tv stays on longer, if it does you can narrow down the culprit with more selective heating.
                        • JunkmanJimbo
                          • Mar 2017
                          • 192
                          Will do. Thank you. I will let you know what happens.
                          • JunkmanJimbo
                            • Mar 2017
                            • 192
                            I actually found a power supply board at a good price. I received the board yesterday and that fixed the problem. Thank you to all of you for the help!
                            • nomoresonys
                              • 12145
                              • U.S.
                              glad to hear it,
                              • DXseekerMO
                                TCL 55US57 backlights, no picture.
                                by DXseekerMO
                                So here we go with another screen short TCL. For this exercise left and right will be reference looking at the screen.
                                The person I got this TV from said the color was bad in a vertical fashion about 1/4 of the way over the left side of the screen. Shortly after the symptoms below started.
                                Power Supply, main and T-CON board are working.
                                Symptoms: The TV has backlights but no picture with both FFC's attached to the T-CON and does not respond to the remote or buttons, and the TV appears to continuously re-boot.
                                Unhook FFC from left side...
                                09-18-2021, 03:56 PM
                              • STKR123
                                Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                by STKR123
                                As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                I wonder if re-flashing the BIOS might be of any use here.
                                As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                11-03-2024, 06:58 AM
                              • sordids999
                                SAMSUNG UE43AU7020K BACKLIGHTS BUT NO PICTURE
                                by sordids999
                                Hi
                                Really stuck on this TV
                                I'm thinking it's a bad screen ?
                                Voltages all seems good
                                Tcon 12v ok
                                Remove one tcon cable at a time no half image on the screen just backlight and no picture
                                even tried the tape trick still no luck
                                Thanks...
                                05-12-2025, 10:36 AM
                              • rddube
                                LG 50lb6100 flashing backlights unsusual fix!
                                by rddube
                                Thought I'd share this find for the repair of an LG tv which had started to turn on but would only get flashing backlights. Backlights would flash at a few second intervals, and when I opened it, noticed that only the 3 bottom rows were flashing, the 2 top rows were completely dead. Replaced a few burnt leds (tested with my led tester), put everything back together, tested all led strips and they were all good, but again the 3 bottom rows would go into this flashing cycle.
                                Read all the discussions on the web and on Badcaps (wonderful forum!!) and...
                                03-16-2022, 05:46 AM
                              • stinger
                                Samsung UN70TU6980FXZA no sound no picture but does have backlights
                                by stinger
                                When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
                                04-17-2024, 03:06 PM
