I picked up this TV for free as it was going to be thrown away and I figured I may be able to bring it back to life. My initial thought is faulty LED backlights but want to get some input before I buy parts. I have replaced LED backlights in numerous LG tvs. The TV powers on like normal the backlight flashes and then it goes black, with a flashlight you can still see the picture and the backlight will intermittently flash. I have not torn this TV apart yet just got it tonight and wanted some input before I started tearing it apart and ordering parts but my gut tells me order LED strips and I should be good from there. Thanks in advance
LG 55LB5900 backlight flashing
Re: LG 55LB5900 backlight flashing
seems like backlights, backlight testers are pretty handy, around 20 bucks on ebay or amazon. -
I've had a number of these LG LB models that flash. Generally I try to replace the LEDs that are open or short or with the highest forward voltage. However, if it's more than four or five LEDs to replace, then I order the strips.
It's also a crap shoot getting the LED diffusers back in the right spot. Most of the time I win, but sometimes I lose!Comment
Both LB and LF series flash with backlight issues. https://techhometravel.com/lg-ln-ser...ed-backlights/Comment
use a little painters tape on those diffusers when you take them out, to keep them in order, maybe take pictures to remember how they fit back in.Comment
by learnmoreHello Community!
CASE DETAILS
Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
Tried inserting firmware on USB and left it in for a few hours, but no change
YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
I also changed the screen because the PC fell and the screen was broken.
I changed the battery with a new and original battery.
I also had corrosion/oxidation on the... -
by STKR123As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
I wonder if re-flashing the BIOS might be of any use here.
As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,... -
by rddubeHello everyone,
Thought I'd share this find for the repair of an LG tv which had started to turn on but would only get flashing backlights. Backlights would flash at a few second intervals, and when I opened it, noticed that only the 3 bottom rows were flashing, the 2 top rows were completely dead. Replaced a few burnt leds (tested with my led tester), put everything back together, tested all led strips and they were all good, but again the 3 bottom rows would go into this flashing cycle.
Read all the discussions on the web and on Badcaps (wonderful forum!!) and... -
by DanPokaI bought this p2210f dell monitor to fix. Schematic is the same as p2210.
This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...-
- Loading...
