philips 65PUS6162/05 dead no sby led
  • jimbofz
    replied
    Re: philips 65PUS6162/05 dead no sby led
    ok oops sorry my mistake
    replied
    how bout that picture of the whole back, we don't have the tv on our bench so we can't see it.
  • jimbofz
    replied
    the voltage on ps__on when mains connected (no sby lit) is 3v
    pressing the remote or toggle switch at rear of tv does not change this voltage
    because of the design of the psu ,the main board has to be fed 12v to enable any
    of the important supplies to be produced
    my attempt to force on the psu i used a link from the good 3,3v supply on the main board
    and fed it to: ps_on
    dim and
    on/off
    this produced no backlight voltage
    earlier before any posting on the forum i checked all caps with esr meter and for good measure replaced a few that were not 100% cap value
    i also confirmed the vcc1 and vcc2 voltages were good at approx 12v and that the backlight cct or LLC as philips like to call it revealed no s/c or suspect components
    perhaps ,(as philips like to be different )the ps_on has to go low to turn on psu not high as i first thaught?
    replied
    standby seems a little low, maybe unhook cable from powerboard to mainboard, recheck standby voltage with it off, if it stays the same maybe check that cap right by the connector, D9100, D9102 and the transistor right there by it on the heatsink, can you post a picture of the whole back, as to see how everything is connected?
  • dskall
    replied
    PS_on is 3v in standby or power on?
  • lotas
    replied
    last number region designation:
    60 – Russia
    12 - Europe
    F7 - North America
    F8 - Central America
  • jimbofz
    replied
    sorry here are the pics
    the cct is from 65pus 6162/12 version not 65pus6162/05
    i dont know if theres any difference
  • jimbofz
    started a topic philips 65PUS6162/05 dead no sby led
    hi to all,
    following on from earlier post ref:no boosted pcf voltage
    i managed to get a LD7591T pcf boost ic
    i now have 385v boosted volts.
    the psu produces 12v ok ,
    (and bear in mind the 5v and 3,3v supplies are produced by the main board not as shown on the psu board markings.)
    now, the tv has no sby led lit ,no backlight voltages
    my thaughts were that ths processor could be faulty,but i wanted to completely eliminate the psu first
    i checked all the supplies on the main board 1,5v,3,3v,5v, they are all ok,
    the psu voltages:
    dim 0v ,
    on/off 0v ,
    ps-on 3v
    i fed 3.3v from main board to:
    dim,
    on/off
    and ps-on
    but still no backlight voltage
    any ideas as to why psu wont give out b/l supply volts?
    am i correctly trying to run psu ,or am i missing something?
  • kew1701
    Philips taw6205 ambilight speaker STM32 mcu dead
    by kew1701
    Resolved dead cap which burned mcu(stm32f091rct6) ,between vss and vdd on desoldered mcu is short 5.8oh,is there a way to obtain firmware from it.i have firmware,but i thing this is for wifi/bt board phorus 5 which is on top of amp board(here lies dead mcu)...my stm32 flasher is on the way....
    04-09-2025, 03:59 AM
  • Rubenlily
    Philips 50PUS6503 - dead panel? Picture
    by Rubenlily
    Hey,
    I gave up on my last TV and got a new one to try.
    Only vertical lines. Sound is OK. Screen is black with a few white lines until I change channel, then these colors gradually starts filling up the screen.
    Is this fixable in any way or should I just give up on this one too?...
    08-21-2023, 01:07 PM
  • double_DD
    How can I be sure that my EC chip is dead?
    by double_DD
    As the title suggests, how can I be sure that my EC chip is really dead?
    I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
    Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
    03-12-2025, 07:47 AM
  • G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
    by G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
    It does power up when pressing the power button.
    I already try the power button while plugin the plug with no result.
    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
    Could this be an PSU or eMMC issue ?
    07-19-2025, 03:43 AM
  • vikivng
    PHILIPS 40PFL7007 TV DEAD. D501 testing SHORT on DMM
    by vikivng
    Hi guys pls can someone help with this set..
    Tv doesnt not power on.
    No standby light.
    There is a burn mark by the leg of D501 diode.
    The diode tests short in both directions.
    I have been reading this usually means the diode is faulty? As normally would be open.
    I have not yet taken voltages since this is obviously short I would like to replace it.
    Can someone help me with a substitute for this diode since it seems not to be the standard type?...
    08-22-2022, 10:51 AM
