philips 65PUS6162/05 dead no sby led
  • jimbofz
    • Apr 2013
    • 539
    Re: philips 65PUS6162/05 dead no sby led
    are there any tiny fuses on the mainboard to check out?
    yep checked those
    • jimbofz
      • Apr 2013
      • 539
      Originally posted by Diah
      are you saying now if you just plug the PSU in wall socket with out main board plugged in.. PFC boosted and you have 12V on the socket and the main cap +380V???
      so what will u9301 of power saving will do ?? did you checked all 3 Opto are fine no one of them are shorted?
      no.
      if now just plug the PSU in wall without main board
      we get 12v ok
      and no pcf boost volts just 330v.
      when main board connected the boost voltage returns to 380v
      i have checked the 3 opto and their components
      as you can see in this jpg
      there are no components fitted for 5v supply on psu so u9301 does not exist on this version of the psu
      • Diah
        • Feb 2013
        • 6614
        one things more from my side... yours Tv not Android system.. if it was Android then 12V should be active to start as hot start. also i am afraid the owner exchange PSU with wrong model. as i know Native Linux we do have eeprom which need STB. so i suggest you follow the wires of 5V on the mainboards sockets are they connected to circuit or not !!
        • Diah
          • Feb 2013
          • 6614
          EDIT: or you can feed the MB as stand alone ( no PSU ) with 3.5-5V 1A at the 5V pins on the sockets, check front STB LED come on... and put the DM on wires PS_ON ref to - external power if there 3.5V after you press power.. if this was successful mean our judgment on PSU was correct.
          • jimbofz
            • Apr 2013
            • 539
            is there any way to check if main board is the wrong one from the white paper label on the board?
            as there are no part numbers in the service manual?
            i will try to follow the cct on mainboard and get back to you thanks
            • jimbofz
              • Apr 2013
              • 539
              #26
              ive had a good close look at main board and the 2 pins for 5v are not connected to anywhere
              just as the same 2 pins on the psu not connected.
              ive had a word with the original owner who says nobody tried to repair tv due to its size he couldnt even get a repair man to call out to look at it .he says it worked fine then just went dead
              also i entered the tv model number in google to find a psu ,
              so i could look at it to compare
              there is one exactly the same with picture of it i can now confirm it is the same
              your suggestion to run the MB with external 3,5-5v wont work because the MB
              pins are not connected to anything
              • jimbofz
                • Apr 2013
                • 539
                #27
                from what i can see there are only 3 things that can control the psu state:
                dim
                ps/on
                on/off
                the remote reciever small pcb has 3.3v feed ok .
                on one of the pins when remote button is pressed the voltage drops to 2.9v
                this tells me that the remote reciever is ok
                • jimbofz
                  • Apr 2013
                  • 539
                  #28
                  Originally posted by diif
                  There wouldn't be any change if you let it cool down. 200c isn't hot enough to melt anything and cooled down, any expansion has gone.
                  what temp would you recommend when attempting a reflow ?
                  and for how long approx?
                    • 12323
                    • U.S.
                    #29
                    it's a mystery, guess one option is to get a powerboard from someone with a generous return policy, if it don't work then you probably won't be out much if you need to return it, maybe just a small fee plus shipping? I might try it with some of my crap, or might just switch to fishing.
                      • 12323
                      • U.S.
                      #30
                      powerboards can be a real bich, have failed on my last 2 board repair attempts.
                      • jimbofz
                        • Apr 2013
                        • 539
                        #31
                        hope you have better luck fishing than i do with repairs
                        • Diah
                          • Feb 2013
                          • 6614
                          dim
                          ps/on
                          on/off
                          from yours confirmation above... and you have PS_on. then could be MB at half boot... did you messure any USB post had 5V? did the optical audio port lit red?
                          if one above are correct... i would suggust you to start with firmware downgrade
                          with upgrade_loader 17.june.2019
                          • jimbofz
                            • Apr 2013
                            • 539
                            #33
                            interesting .ive never heard of half boot
                            the opto port is not lit but does have 5v on it
                            usb1(blue)has 3.3v on it
                            usb2 has no voltage on it
                            the first cct i found was tmp17,7 e ly which is similar
                            .but i later found the correct cct tmp 17.9 cct
                            (in my post number 10)
                            is the loader you kindly posted the same for 17.9?
                            • diif
                              • Feb 2014
                              • 6978
                              • England
                              #34
                              Your words suggested just getting some heat in to see if there was a BGA issue, 200c is about right but you turn on whilst it's still hot, the heat causing expansion, hopefully making a temporary connection with any cracked joints.
                              • Diah
                                • Feb 2013
                                • 6614
                                PUS6162 are 2017 serie with chassis TPM177E , the firmware i lnked for you are for this chassis for downgrade thanks to Toengel Philips archive firmware.
                                • jimbofz
                                  • Apr 2013
                                  • 539
                                  #36
                                  ok i now understand thanks for reply
                                  • jimbofz
                                    • Apr 2013
                                    • 539
                                    #37
                                    PUS6162 are 2017 serie with chassis TPM177E , the firm ware i lnked for you are for this chassis for downgrade thanks to Toengel Philips archive firmware.
                                    thanks Diah
                                    i will try downgrade as suggested
                                      • 12323
                                      • U.S.
                                      #38
                                      try heating that bga again, its the easiest test, then go with the firmware if no change.
                                      • jimbofz
                                        • Apr 2013
                                        • 539
                                        #39
                                        i downloaded thr file ,extracted and loaded to clean usb stick plugged into blue usb1 skt then applied mains waited 25 mins .
                                        i have no was of seeing if upgrade has taken place
                                        switched off waited then removed usb stick .then applied mains
                                        sadly no change
                                        • Diah
                                          • Feb 2013
                                          • 6614
                                          sadly no change
                                          at this case need more test on MB. you wrote USB1 was 3.3V which are low... however Audio OPTIC had 5V normal.. i would do the following and consider on the optic if lit or USB 1 become high 5V
                                          a- panel complete disconnect from T-CON ( by disconnect ribbon )
                                          b- messure 12V on T-CON
                                          c- remove WIFI module from TV. or bluetooth . check if USB1 come high 5V
                                          d- check after warm parts after you turn on the tv on MB..
                                          • kew1701
                                            Philips taw6205 ambilight speaker STM32 mcu dead
                                            by kew1701
                                            Resolved dead cap which burned mcu(stm32f091rct6) ,between vss and vdd on desoldered mcu is short 5.8oh,is there a way to obtain firmware from it.i have firmware,but i thing this is for wifi/bt board phorus 5 which is on top of amp board(here lies dead mcu)...my stm32 flasher is on the way....
                                            04-09-2025, 03:59 AM
                                          • Rubenlily
                                            Philips 50PUS6503 - dead panel? Picture
                                            by Rubenlily
                                            Hey,
                                            I gave up on my last TV and got a new one to try.
                                            Only vertical lines. Sound is OK. Screen is black with a few white lines until I change channel, then these colors gradually starts filling up the screen.
                                            Is this fixable in any way or should I just give up on this one too?...
                                            08-21-2023, 01:07 PM
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                          • Sharpa
                                            Repair attempt Philips 55OLED804/12
                                            by Sharpa
                                            I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
                                            The symptoms when bought: Philips logo appears then tv turns off
                                            Things tried so far:
                                            1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
                                            2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
                                            11-22-2025, 08:30 AM
                                          • alro7779
                                            Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                            by alro7779
                                            Hello, guys!
                                            The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                            09-14-2025, 12:25 AM
