philips 65PUS6162/05 dead no sby led
  • dskall
    • Oct 2016
    • 2905
    • usa
    #61
    Re: philips 65PUS6162/05 dead no sby led
    https://alltransistors.com/
    • lotas
      • Jan 2016
      • 4753
      • Russia
      #62
      https://www.transistorfet.com/transi...N127KN3-0-T1-G
      • jimbofz
        • Apr 2013
        • 539
        • uk
        #63
        Originally posted by dskall
        sadly this links to ali ex out of stock thanks for trying
        • jimbofz
          • Apr 2013
          • 539
          • uk
          #64
          thanks will order today
          • jimbofz
            • Apr 2013
            • 539
            • uk
            #65
            update :finally mosfet MTN127 KN3 arrived fitted replacement and sadly no change in symptoms dooh!!!
            ive been trying to buy correct main board that matches the screen numbers:
            :715g-8709 MOE B00 005N
            SCREEN PANEL TPT650UA-QVN06U
            none available so i thaught i would replace the scaler ic MT5802-VGET
            but this ic is not listed anywhere
            can anyone advise where i can buy this MT ic?
            these chinese made boards have many versions,its so frustrating .
            like a needle in a haystack.
            after a lot of thaught
            just wondered if theres a way of doing a hard reset to the scaler ic ,
            as theres a 3 pin plug on main board
            this reset may bring the micro back to life ? any ideas please
            • Diah
              • Feb 2013
              • 6438
              if you do boot log capture we can tell how to reset with command... but if there are no log its wasting time.
              • jimbofz
                • Apr 2013
                • 539
                • uk
                #67
                i will have to learn how to do boot capture
                once i have this i will reply,
                i tried to research regarding your earlier post on:
                "stuck on half boot"
                but could not find much information on this,
                every day is a learning day
                • Maalobs
                  • Jun 2016
                  • 120
                  • Sweden
                  #68
                  To capture the serial-output of the boot log you need a serial-adapter tool like this:
                  https://thepihut.com/products/usb-to...r-raspberry-pi
                  When you plug in this device into your computer, it shows up as a new serial-port and you can then connect to the serial-port in the computer with a terminal-emulator like Tera Term or Putty.
                  You then hook up the headers of the serial-adapter to the correct pins on the device under test.
                  USB GND - to - DUT GND, obviously. (black)
                  USB RX - to - DUT TX, this is how you receive data from the DUT to your terminal window. (white)
                  USB TX - to - DUT RX, this allows you to transmit typed commands into the DUT. (green)
                  The red header you can ignore, it's for powering IoT devices.
                  This product with the blue case appears to be the real deal from Adafruit so it should have a brand controller in it which means the Windows driver will work with it.
                  If you find some alternative that's cheaper than this one, then it's probably built on a pirated controller chip and the Windows driver will detect that and refuse to work.
                  The pirated versions still work fine in Linux, though.
                  You will still have to mess around a bit with the speed setting in the terminal software, if you get garbage characters or just a single garbage character then you are probably set to the wrong speed and you should try some other speeds.
                  115200 and 57600 are a couple of likely choices, and keep the other settings at "8N1", meaning "8-bit, no parity, 1 stop bit", you will find this all under "port settings" or similar in the terminal software.
                  Just passively catching the boot log only requires hooking up the black and the white headers (GND and RX), but it sounds from Diah that you need to type some command, that means that you need to hook up the green header too (TX).
                  • jimbofz
                    • Apr 2013
                    • 539
                    • uk
                    #69
                    great info
                    i will order one and give it a try
                    • Maalobs
                      • Jun 2016
                      • 120
                      • Sweden
                      #70
                      How did it go?
                      • jimbofz
                        • Apr 2013
                        • 539
                        • uk
                        #71
                        still trying to find a replacement main board ,before i try to follow your advice
                        there are so many variants of this main board ,
                        and of course the screen panel type must match also.
                        cant even find a source of the main processor ic or scaler ic MT5802-VGET
                        i will update as soon as i can thanks
                        • jimbofz
                          • Apr 2013
                          • 539
                          • uk
                          #72
                          hello ,as i cant find correct main board replacement ,i decided to try again to fix
                          I started with simple cold resistance checks to chassis
                          on the supplies from the main ,
                          all appear normal EXCEPT o/p of U706 VCCK it measures 112ohm to chassis and when connected up only has 1volt o/p
                          this (,on page 49 of manual) is CORE POWER
                          this seems low volts to me?
                          if someone could take a look at post 2 or 10 manual page 47 and 48
                          perhaps the MT5802 scaler ic needs only 1v ,but i dont think so ?
                          cant find data sheet for this processor
                          any ideas please ?
                          • lotas
                            • Jan 2016
                            • 4753
                            • Russia
                            #73
                            1v to power the processor core is normal (they have low voltage, but high current), the resistance of this bus is also very low, so 112 ohms is a normal resistance, sometimes even lower.
                            • jimbofz
                              • Apr 2013
                              • 539
                              • uk
                              #74
                              wow thanks for quick reply and clear explanation
                              good man
                              • lotas
                                • Jan 2016
                                • 4753
                                • Russia
                                #75
                                Have you tried flashing EEPROM 24c128?
                                • nomoresonys
                                  • 12276
                                  • U.S.
                                  #76
                                  Are you sure none of these boards will work?: https://www.ebay.co.uk/sch/i.html?_n...=10001&_sop=15
                                  • jimbofz
                                    • Apr 2013
                                    • 539
                                    • uk
                                    #77
                                    if this involves flashing with usb stick ,then it wont work because the supply to the usb skt is not enabled
                                    is there any other method of flashing eeprom?
                                    • lotas
                                      • Jan 2016
                                      • 4753
                                      • Russia
                                      #78
                                      With the help of a programmer.
                                      • jimbofz
                                        • Apr 2013
                                        • 539
                                        • uk
                                        #79
                                        first theres the board number:715G 8709 MOE B00 OO5N
                                        then theres the paper label:HA02 B90T
                                        then the second paper label:706TQHPL327 (3289)
                                        AND THE SCREEN NUMBER tpt650ua-qvn06u
                                        i have looked at many boards
                                        from the pus6162 series chassis type:TMP17.7E AA,
                                        using the smaller screen sizes
                                        and have been tempted to buy as maybee its possible in service menu to alter the screen size ? but at the moment cant find which labels have to match completely .philips technical no help at all
                                        • jimbofz
                                          • Apr 2013
                                          • 539
                                          • uk
                                          #80
                                          i have bought a CH341A ,i can remove the eeprom and should be able to learn how to read it ..how would i know if the data is corrupt ?
                                          or should i buy a replacement eeprom
                                          • kew1701
                                            Philips taw6205 ambilight speaker STM32 mcu dead
                                            by kew1701
                                            Resolved dead cap which burned mcu(stm32f091rct6) ,between vss and vdd on desoldered mcu is short 5.8oh,is there a way to obtain firmware from it.i have firmware,but i thing this is for wifi/bt board phorus 5 which is on top of amp board(here lies dead mcu)...my stm32 flasher is on the way....
                                            04-09-2025, 03:59 AM
                                          • Rubenlily
                                            Philips 50PUS6503 - dead panel? Picture
                                            by Rubenlily
                                            Hey,
                                            I gave up on my last TV and got a new one to try.
                                            Only vertical lines. Sound is OK. Screen is black with a few white lines until I change channel, then these colors gradually starts filling up the screen.
                                            Is this fixable in any way or should I just give up on this one too?...
                                            08-21-2023, 01:07 PM
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                          • alro7779
                                            Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                            by alro7779
                                            Hello, guys!
                                            The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                            09-14-2025, 12:25 AM
                                          • G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                            by G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                            It does power up when pressing the power button.
                                            I already try the power button while plugin the plug with no result.
                                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                            Could this be an PSU or eMMC issue ?
                                            07-19-2025, 03:43 AM
