philips 65PUS6162/05 dead no sby led
  • jimbofz
    • Apr 2013
    • 539
    hi to all,
    following on from earlier post ref:no boosted pcf voltage
    i managed to get a LD7591T pcf boost ic
    i now have 385v boosted volts.
    the psu produces 12v ok ,
    (and bear in mind the 5v and 3,3v supplies are produced by the main board not as shown on the psu board markings.)
    now, the tv has no sby led lit ,no backlight voltages
    my thaughts were that ths processor could be faulty,but i wanted to completely eliminate the psu first
    i checked all the supplies on the main board 1,5v,3,3v,5v, they are all ok,
    the psu voltages:
    dim 0v ,
    on/off 0v ,
    ps-on 3v
    i fed 3.3v from main board to:
    dim,
    on/off
    and ps-on
    but still no backlight voltage
    any ideas as to why psu wont give out b/l supply volts?
    am i correctly trying to run psu ,or am i missing something?
  • jimbofz
    • Apr 2013
    • 539
    Re: philips 65PUS6162/05 dead no sby led
    sorry here are the pics
    the cct is from 65pus 6162/12 version not 65pus6162/05
    i dont know if theres any difference
    • lotas
      • Jan 2016
      • 4904
      • Russia
      last number region designation:
      60 – Russia
      12 - Europe
      F7 - North America
      F8 - Central America
      • dskall
        • Oct 2016
        • 2905
        • usa
        PS_on is 3v in standby or power on?
          • 12322
          • U.S.
          standby seems a little low, maybe unhook cable from powerboard to mainboard, recheck standby voltage with it off, if it stays the same maybe check that cap right by the connector, D9100, D9102 and the transistor right there by it on the heatsink, can you post a picture of the whole back, as to see how everything is connected?
          • jimbofz
            • Apr 2013
            • 539
            the voltage on ps__on when mains connected (no sby lit) is 3v
            pressing the remote or toggle switch at rear of tv does not change this voltage
            because of the design of the psu ,the main board has to be fed 12v to enable any
            of the important supplies to be produced
            my attempt to force on the psu i used a link from the good 3,3v supply on the main board
            and fed it to: ps_on
            dim and
            on/off
            this produced no backlight voltage
            earlier before any posting on the forum i checked all caps with esr meter and for good measure replaced a few that were not 100% cap value
            i also confirmed the vcc1 and vcc2 voltages were good at approx 12v and that the backlight cct or LLC as philips like to call it revealed no s/c or suspect components
            perhaps ,(as philips like to be different )the ps_on has to go low to turn on psu not high as i first thaught?
              • 12322
              • U.S.
              how bout that picture of the whole back, we don't have the tv on our bench so we can't see it.
              • jimbofz
                • Apr 2013
                • 539
                ok oops sorry my mistake
                  • 12322
                  • U.S.
                  maybe start with the easy stuff, check all the diodes and resistors if you have'nt already.
                  • jimbofz
                    • Apr 2013
                    • 539
                    thanks but tried that first .
                    i have found the correct cct
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      Ps-on has to change state from standby. Whether from high to low or low to high.
                      • jimbofz
                        • Apr 2013
                        • 539
                        yes i understand ,i just need help /advice how to turn on psu and check if b/l volts are working
                        then i can replace main board
                        or repair it possibly replace micro mt5802 vgej
                        with confidence that psu is good
                        when i use the 3.3v supply to force on psu theres no sby volts as that is provided by the micro hope that makes sense thanks
                          • 12322
                          • U.S.
                          yes makes sense, if ps-on never changes and if you get nothing from on-off pin which is backlight on off, more than likely a mainboard issue, did you try heating the mainboard processor with hairdryer, or cooling the processor, then see if it works for a while.
                          • jimbofz
                            • Apr 2013
                            • 539
                            WOW you must be a mind reader .just tried that with s/station up to 200 deg for 5 mins then let it cool to room temp sadly no change
                            i know the main board is type :715g-8709-moe-b00-005n
                            theres a number for sale listed with correct model number but board number not exactly the same .are the philips boards identified by the white paper label or the printed numbers on the board perhaps they have to match the screen panel numberas well?
                            • diif
                              • Feb 2014
                              • 6978
                              • England
                              There wouldn't be any change if you let it cool down. 200c isn't hot enough to melt anything and cooled down, any expansion has gone.
                                • 12322
                                • U.S.
                                it shouldnt be too hard to powerup the powerboard stand alone, can you get a better focused picture of the map/legend of that connector or write out the description like pin 1 +5v or whatever it says?
                                • Diah
                                  • Feb 2013
                                  • 6611
                                  all yours messurments are at wrong pins lable.. you will never have PS-ON 3V if there are no STB V. you may have STB 3V not PS_ON but there are short / open on MB. so it didnt start.
                                  • jimbofz
                                    • Apr 2013
                                    • 539
                                    with regards to the legend on the psu there are no components on the board for 5v
                                    unlike most other psu designs the 5v is not produced on the psu
                                    the only dc supplies from the psu are: 12v
                                    and b/l supply which i expect to be around 30v
                                    this is why i find it tricky to force on the psu
                                    the 12v is unswitched and is always present when mains applied ,the 3 pins that are used to control the psu state are :on-off, dim, and ps-on.
                                    when the tv works normally the main board produces the above voltages
                                    now the fault i have is the 12v fed to MAIN board does produce on the test points shown in manual ,5v sby ,5v, 3,3v 1.5v these are on coils: l701, l704. l702, l803
                                      • 12322
                                      • U.S.
                                      are there any tiny fuses on the mainboard to check out?
                                      • Diah
                                        • Feb 2013
                                        • 6611
                                        are you saying now if you just plug the PSU in wall socket with out main board plugged in.. PFC boosted and you have 12V on the socket and the main cap +380V???
                                        so what will u9301 of power saving will do ?? did you checked all 3 Opto are fine no one of them are shorted?
                                        • kew1701
                                          Philips taw6205 ambilight speaker STM32 mcu dead
                                          by kew1701
                                          Resolved dead cap which burned mcu(stm32f091rct6) ,between vss and vdd on desoldered mcu is short 5.8oh,is there a way to obtain firmware from it.i have firmware,but i thing this is for wifi/bt board phorus 5 which is on top of amp board(here lies dead mcu)...my stm32 flasher is on the way....
                                          04-09-2025, 03:59 AM
                                        • Rubenlily
                                          Philips 50PUS6503 - dead panel? Picture
                                          by Rubenlily
                                          Hey,
                                          I gave up on my last TV and got a new one to try.
                                          Only vertical lines. Sound is OK. Screen is black with a few white lines until I change channel, then these colors gradually starts filling up the screen.
                                          Is this fixable in any way or should I just give up on this one too?...
                                          08-21-2023, 01:07 PM
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • Sharpa
                                          Repair attempt Philips 55OLED804/12
                                          by Sharpa
                                          I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
                                          The symptoms when bought: Philips logo appears then tv turns off
                                          Things tried so far:
                                          1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
                                          2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
                                          11-22-2025, 08:30 AM
                                        • alro7779
                                          Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                          by alro7779
                                          Hello, guys!
                                          The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                          09-14-2025, 12:25 AM
