Samsung BN44-00445C power supply issue
  • nicdev007
    • Apr 2022
    • 10
    • France
    Hello all and thanks for the great welcome to the forum!
    With the help of multiple community members and some of my own experience I have advanced on the repair of a Samsung PS59D530A5 TV. The power supply - PFC card number is BN44-00445C.
    At first the PFC MOSFETS where blown along with a host of other SMD components including the PFC controller IC (20 pin R2A20118). I replaced all components found in a kit form, to be sure (F801S,QP802, QP804, DP802, QP806, QP808, QP805, QP807, RP815, RP806, DP804, DP807, RP803, RP807, RP804, RP808, ICP801). Attached a picture of the components replaced.
    After this still no startup of the PFC, so the relay just clicks every 5 seconds as it tries to start the PFC but fails. I followed some advice to pull down the PS_ON line with a resistor to enable me to troubleshoot further the power supply on my bench and it allows me to measure the voltages more easily.
    What I did find was that the PFC IC (ICP801) does not actually get powered, I measure 0,5V on pin 20 (Vcc). Unfortunately the circuit diagrams I have found are not of this exact model and it is making the troubleshooting difficult.
    When following the VCC of ICP801 i found 2 zener diodes (ZDP801 and 802) in series (marking WF (Y1)) both not measuring ok, I replaced them both to continue the troubleshooting, but in fact the problem is more upstream as the line is not fed with any voltage (photo attached) and without the correct diagram it is proving slightly troublesome.
    Any help will be greatly appreciated. It would be a pity to let it go now after all my efforts. Not sure i could anyway
    Kind regards
    Nico
  • lotas
    • Jan 2016
    • 4752
    • Russia
    Re: Samsung BN44-00445C power supply issue
    Schematic
    https://www.electronica-pt.com/esque...45c-psu-50639/
      • 12276
      • U.S.
      maybe check all solder joints, touch up if needed: https://www.google.com/search?q=exam...ih=607&dpr=1.5
      • nicdev007
        • Apr 2022
        • 10
        • France
        Originally posted by lotas
        Thank you, this is the schema I have also, but it does not correspond to the board unfortunately. ICP802 in this diagram is a 16 pin PFC driver (UCC28061), but on the board it is a 20 pin R2A20118 amongst many other differences. Some parts do correspond but not the part supplying Vcc to the PFC IC.
        Regards
        Nico
        • nicdev007
          • Apr 2022
          • 10
          • France
          Thanks for the advice, I have done so, but will go through it again and check if I missed some.
          Regards
          Nico
          • dskall
            • Oct 2016
            • 2905
            • usa
            I wouldn't think it could be that hard to trace out vcc back to main power. Ic801 not powering up? Is yours controlled through a transistor?
            • R_J
              • 9588
              The source of the VCC voltage is DX801 (standby circuit) CM801 is the vcc filter, Q?802 acts like a vcc regulator and switch, The collector is the main VCC and the emitter supplies the vcc for the pfc ic, the base usually has 2 series diodes to ground, one is a regular diode, one is a zener that sets the vcc voltage (16~18v) The base is also turned on or off with a optocoupler
              Start by checking the voltage ACROSS CM801, it should be about 25~30v
              • nicdev007
                • Apr 2022
                • 10
                • France
                Thanks R_J for the valuable assistance,
                Traced it back as you suggested.
                Voltage across CM801 is a bit lower (17.5V). I removed QC802 (Vcc regulator) from the board to be sure and it measures faulty. I checked the other components in the circuit including the Zener and the rest measures ok.
                I'll see if I have an equivalent tomorrow and if it will start up correctly. From what I have found the marking on the transistor "YB" is a KTD1624 (EPITAXIAL PLANAR NPN TRANSISTOR package SOT-89 package).
                Thanks again for the help. Lost the habit to trace without a circuit diagram, coming back to me slowly ;-)
                Best regards
                Nico
                • captainKKK
                  • Sep 2018
                  • 287
                  Is CP801 intentionally shorted with foil to enable tracing?
                  • R_J
                    • 9588
                    That's Shopjimmys board picture
                    • captainKKK
                      • Sep 2018
                      • 287
                      Duh, now I see it.....I am so slow....I could not figure why no one said anything......I got to go take a nap now...
                      • nicdev007
                        • Apr 2022
                        • 10
                        • France
                        Hello all,
                        Thank you again for your inputs to assist with this unit. I changed QQ801 (marking not clear) but it is the regulator transistor for the Vcc of ICP801 (PFC controller). It seems when the PFC blew up it also blew up QQ801, and the 2 zener diodes ZDP801 and ZDP802.
                        The set now starts up, I have to still do a full test later to see if all functions are working, but that is great progress.
                        For future readers and information seekers, I replaced the following to repair the PFC circuit:
                        F801S,QP802, QP804, DP802, QP806, QP808, QP805, QP807, RP815, RP806, DP804, DP807, RP803, RP807, RP804, RP808, ICP801 -> Repair Kit
                        and
                        ZDP801, ZDP802 and QQ801 in the standby powersupply circuit.
                        One more question for information: What RTV glue do you use to replace the white RTV put on the MOSFETS? Brand or reference could be helpful ? I had an old tube that is no longer manufactured so I wanted your opinion on a good product to use.
                        Regards
                        Nico
                        • nicdev007
                          • Apr 2022
                          • 10
                          • France
                          Correct, it is in better state than the board I repaired, so I used it but just for clarity ;-)
                          • nicdev007
                            • Apr 2022
                            • 10
                            • France
                            Hello all,
                            a quick update. The set restarted yesterday and I could check the screen which had quite a good picture, but during testing different parts, after switching it off, I could not switch it back on again.
                            When switching it on with the remote or front panel button, I just hear a quick relay click and it stays in standby. I am busy checking the standby power supply voltages to continue the troubleshooting but any ideas from your experience is greatly appreciated.
                            Does anybody know what the VCC voltage on the PFC ICP801 should be? I know R_J said 16-18V but wanted to be sure
                            I'm wondering if the transistor I used to replace QQ801 is adapted to the task?
                            Thank you in advance
                            Nico
                            • dskall
                              • Oct 2016
                              • 2905
                              • usa
                              What is part# of ICP801?
                              • nicdev007
                                • Apr 2022
                                • 10
                                • France
                                From memory it is R2A20118 and the technical specification I found says VCC 24V, I suppose that is a maximum value.
                                Very strange behaviour as the set starts up again for no reason.
                                When it starts the relay sometimes clicks a few times (4 times) or it just starts up without any issue. When it does the set works perfectly. I measure VS at 217V and VA at 55V and the VCC for ICP801 at 17V. The PFC around 388V.
                                I think I either have a bad capacitor in one of the standby PSU circuits, or a dry solder joint that I missed (I have repaired quite a few).
                                Regards
                                Nico
                                • dskall
                                  • Oct 2016
                                  • 2905
                                  • usa
                                  Sounds like bad solder joint. Maybe try tapping around board and see what happens.
                                  • nicdev007
                                    • Apr 2022
                                    • 10
                                    • France
                                    I did quite a bit of that, no luck. I did however go over the board again to check for bad joints. While doing some measurement I stumbled upon a strange behaviour.
                                    When I put my multimeter on point 1 in the screenshot (VCC line on the standby powersupply) the set starts every time without fail. I remove the multimeter probe and it clicks a while before starting. Almost like I'm adding some impedance to the line.
                                    Tomorrow i'll start checking some DC caps to see if I find something.
                                      • 12276
                                      • U.S.
                                      yep, check the electrolytic caps and components right by that jumper.
                                      • R_J
                                        • 9588
                                        Replace them, they will likely check ok but are bad.
                                        • Cookybaby
                                          Samsung UN60ES6500FXZA Power Supply Issue
                                          by Cookybaby
                                          Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                                          I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                                          Make: Samsung
                                          Model: UN60ES6500FXZA
                                          Power Supply P/N: BN44-00525A
                                          Symptoms: The TV was...
                                          08-20-2023, 12:26 PM
                                        • lp20th
                                          Samsung Plasma TV Power Supply Issue
                                          by lp20th
                                          I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                                          11-28-2023, 10:28 AM
                                        • Kjell
                                          Samsung Series 9 - BIOS issue
                                          by Kjell
                                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                          08-01-2025, 09:15 AM
                                        • captainKKK
                                          Samsung Bn4400612b Power Supply issue on Samsung UN50F6300
                                          by captainKKK
                                          Samsung Bn4400612b Power Supply issue takes out a new 5A fuse on my Samsung UN50F6300, without any the BL or main board cables connected. Please advise if this board has known issues and fixes. There are no evident fried components and the caps look ok. Nothing unusal on the bottom side of the board under magnification. Is the ICM801CS under that heat sink a known issue? SJ (https://www.shopjimmy.com/samsung-bn...-1473373576096) out of stock, so component level repair may be my best shot. Thanks.
                                          02-17-2022, 08:59 PM
                                          09-07-2024, 05:50 AM
