Vizio M70-C3 ... Help with Diagnosis
  • R_J
    • 9535
    Re: Vizio M70-C3 ... Help with Diagnosis
    Compare the numbers on thee stickers between your original board and the two replacement boards. Your pictured board is a 674B
    • TroutCaptain
      • Jan 2022
      • 13
      To be honest when looking at replacements I wasn't looking at the white sticker. Was using the white text printed actually on the board and maybe where things went wrong.
      white sticker:
      original board - 674B
      replacement board 1 - 690B
      replacement board 2 - 664A
      They were all 0160CAP09E00
      printed white on actual board:
      All boards
      CAP06 Main BD
      1P-0149J00-6012
      2014.09.15
      REV:1.2
        • 12123
        • U.S.
        thats a no-no, the white text printed on the board is just what they start with, then they populate it acording to need.
          • 12123
          • U.S.
          what is the panel number of the tv? should be on a sticker on the chassis someplace.
            • 12123
            • U.S.
            whats the first 9 letters of the serial number on the back cover of tv?
            • TroutCaptain
              • Jan 2022
              • 13
              Serial #: LFTRSYAR3700007
              • TroutCaptain
                • Jan 2022
                • 13
                Is this the right one? See attachment
                  • 12123
                  • U.S.
                  #28
                  ok, from what I see, I think both those boards will work, look here, notice it says these boards will work too and there's an arrow to even more beside it, looks like several will work: https://www.shopjimmy.com/vizio-y838...trsyar-serial/
                  • TroutCaptain
                    • Jan 2022
                    • 13
                    OK thanks for checking on this. So sure sounds like the boards I received are compatible but unfortunately bad.
                    So now going back to the reflow method and the original picture of my board... how do I handle the plastic covering the chips? Without removing them it seems I wouldn't be able to get the flux around the actual chips and possibly not hot enough?
                    Thanks for all the help and knowledge.
                      • 12123
                      • U.S.
                      #30
                      I'll have to leave that to the guys here that are good at reflows, unfortunately I killed the last mainboard I tried to do.
                        • 12123
                        • U.S.
                        #31
                        theres a pretty good thread on it I was looking at a bit ago, I'll see if I can find it.
                          • 12123
                          • U.S.
                          #32
                          theres one, looks like Howardc64 tested a lot of methods with it: beware the popcorn effect that can happen, I think that's what happened to me, I might have overdid the heat: https://www.badcaps.net/forum/showth...ht=oven+reflow
                          • TroutCaptain
                            • Jan 2022
                            • 13
                            Sorry to hear about your reflow. I took a look at that thread and has a lot of great info. I didn't seen anything specific regarding what looks like a protective plastic cover over the two main chips. I'll post over there and see if they have any thoughts. Seems like for a successful reflow I would somehow need to remove that to get flux in there. But who knows maybe I am not understanding what I am looking at. Thanks again
                              • 12123
                              • U.S.
                              #34
                              one method there, also check the bottom of the board, some you need to take some small plyers and squeeze the little plastic keeper to release it, not hard to do tho.
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                #35
                                There is no plastic cover, that's part of the chip. The white square on the PCB denotes the edge of the chip. You should be able to see a tiny gap between it and the PCB.
                                  • 12123
                                  • U.S.
                                  #36
                                  That video is for heatsink removal, you don't want to remove that chip, just the heatsink if it has one. No picture so I was thinking you were referring to a heatsink.
                                  • TroutCaptain
                                    • Jan 2022
                                    • 13
                                    Thanks diff this is where I was getting confused. I wasn't expecting the chip to have that semi-clear look to it around the black center.
                                    So an update... I reflowed the first chip, seemed to go well, reflowed the second chip and unfortunately slightly bumped the board right at the wrong time and the chip slid of the contacts a bit. I tried to do my best to realign but either way not good. Feel like its pretty much impossible at this point without more professional tools to get the chip back on in the correct spot without any issues. I think for now I am going to completely remove that chip and clean everything and then figure out the best method to DYI this chip back on and cross fingers. Obviously at this point this TV is a loss but I appreciate this forum and all of the great support and users. I hate throwing things away if they can easily be fixed plus the learning and fun that is also is involved with it.
                                    Attached the picture for fun, so you saying there is a problem here? Haha
                                    • petehall347
                                      • Jan 2015
                                      • 4426
                                      • United Kingdom
                                      #38
                                      i believe flux and hot air should float it back into position
                                      • diif
                                        • Feb 2014
                                        • 6978
                                        • England
                                        #39
                                        It wouldn't be hard to get back into position but it's likely some of the balls are jumbled at this point.
                                        • spice_disc
                                          Vizio TV M50-C1 reboot cycle and static on screen
                                          by spice_disc
                                          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                          09-08-2024, 02:37 PM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • smic717394
                                          by smic717394
                                          07-25-2024, 10:16 AM
                                        • paqman
                                          Vizio M60-C3 black screen
                                          by paqman
                                          So our beloved M60-C3 up and died the other day. I was not there, my wife mentioned that it came on, displayed the logo, then showed the right half of the screen white and fuzzy, with the left half of the screen ok. However when I got around to looking at it, the screen would not come on at all. The indicator LED will come on, then dim a bit. After a while, the LED might blink a bunch of times. I can't get it to be consistent to do that.
                                          So I've got the back off and am checking voltages. The capacitors on the power supply board visually check out. No bulges or anything. They all show...
                                          03-02-2024, 04:37 PM
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
