Sony Bravia KDL-32L4000 vertical lines
  • Wrog
    • Oct 2009
    • 472
    Haven't opened and taken a look yet, but powered it up and saw some vertical lines. The strange thing about it is that the vertical lines don't appear right away. When first powered up, the screen is clear -- but when you open a menu or see any text display, the vertical lines "bleed" in over 5-10 seconds or so. Also, the top 1/6 of the screen doesn't seem to be affected (the lines only appear in the lower 5/6 of the screen).
    Conventional wisdom is that vertical or horizontal lines are indicative of a panel problem, but hoping that there's something that can be done to save it. Attached is a photo after about 15 seconds of being powered on. Is it worth opening and taking a look around?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Sony Bravia KDL-32L4000 vertical lines
    is it under warranty?
    sigpic
    (Insert witty quote here)
    • Wrog
      • Oct 2009
      • 472
      Thanks for the reply. As far as I could tell the warranty for this model is only 1 year, and it was purchased April 2008. Sad to see an LCD TV from a major manufacturer last only 2 years!
      • cadiman
        • Mar 2010
        • 397
        What does a video input picture look like or other input program source look like? I don`t think the pdp is bad. I would check all of youer ribbon cables connections first any patterns are board related and not always pdp related.
        • Wrog
          • Oct 2009
          • 472
          Thanks -- I plan to investigate a little more by opening it up and taking a peek soon. In the meantime, I hooked up a laptop to it via the 15 pin D connector, and here's a couple more pictures of what happens after 5 seconds and 15 seconds of being powered on.
          • blcd
            • May 2010
            I had one of those doing stuff like that to me... and "ghosting" the image.
            A new TCON board fixed it.
            • Wrog
              • Oct 2009
              • 472
              Thanks for the input, I appreciate it. From what I've read, the TCON board (on this model and serial number range) is integrated into the panel and not replaceable separately. Still hoping to find something else serviceable inside!
              • spacesnow
                • Jun 2010
                I managed to fix my Sony KDL-32S3000 by changing the tcon-board. It was simple and cost me 30€. According to Sony service the price of repair should have been 250€. The tcon board I got from online-shop was offered as tcon for KDL32S3000 and if I compared the original to the new board the long product-code doesn't even match but TV is working fine. You check the tcon board type from original and search it from online-shops. The repair board I got was definitely used part not new. And Sony doesn't sell these separately from LCD panels. Good luck!
                • Wrog
                  • Oct 2009
                  • 472
                  Thanks spacesnow (hmm.. is that "Space Snow" or "Spaces Now"?). I finally had some time to open it up last night, and found that the TCON is definitely not integrated into the panel like the Sony service manual stated. So far, the cheapest I've been able to find is about $60 shipped... but I think it's worth giving it a shot!
                  • flyman87
                    • Jun 2010
                    i have the same problem with mine, im curious did you get that tcon board and if so did that fix the problem ?
                    • Wrog
                      • Oct 2009
                      • 472
                      I have not tried it yet.. I'm trying to find a source that will allow returns just in case it doesn't work. Those who are selling on eBay aren't generally open to returns, or want to charge an exhorbitant "restock fee" (30% or more).
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        thats so folks dont waste our time exchanging boards till it plays.
                        make sure of what you need.this is why i dont usually sell parts to the public.
                        • brianfenst
                          • Aug 2010
                          My mothers KDL-32L4000 has the same problem too. Please post if the TCON solves the problem. Her serial # implies they don't make a TCON for it.
                          • Wrog
                            • Oct 2009
                            • 472
                            The TCON did not resolve the issue. Even though the serial number listing in the service manual says a TCON doesn't exist, chances are it does. Can you post a picture of what it's doing?
                            • oktane
                              • Oct 2010
                              • 3
                              Hello
                              I have a unit in with similar issues, wondering if a TCON is going to fix it. Wrog, can you try gently applying pressure to the plastic interconnect tabs coming from the small PCB above the lcd. (must remove metal bezel and support LCD panel if turned upright, otherwise it will fall out!)
                              These tabs sometimes become defective, apparently the glue fails? They get pretty hot in operation.
                              There is a thread and videos about the tab bonding issue here: http://www.avsforum.com/avs-vb/showthread.php?t=1173106
                              Unfortunately, this doesn't appear to be the issue with my set. I poked at everything trying to illicit a response to no avail. (including all chips, looking for cold joints) Problem persists with inverter unplugged, so the inverter is not causing noise issues as was suggested in a similar thread.
                              Here is the service manual btw: http://www.scribd.com/doc/21548740/C...00-KDL-37L4000
                              Cheers
                              • walker1950
                                • Nov 2010
                                I have a KDL-32L4000 Sony and it has vertical lines across the screen and I would like to replace the TCon Board myself but would like to know if you had a manual telling you how to do it or where I can get one to help me out.
                                • walker1950
                                  • Nov 2010
                                  My KDL-32L4000 Sony has vertical lines across the screen and I would like to replace the T-Con Board myself but I am wondering where I can get a manual showing how to replace the board. Anyone else tried to do this yourself?
                                  • Wrog
                                    • Oct 2009
                                    • 472
                                    Post #15 has a link to the service manual. Section 1 has disassembly instructions. If you want to post pics of what the TV is doing, I'm sure someone can chime in on if it's likely to be a TCON problem.
                                    • chrisbarnes72
                                      i have a smilar problem on a KDL-40S4100. see attaced pic
                                      • schlitz_420th
                                        I have this TV, did a bunch of research, and I hope I save the next guy from what I did:
                                        Everyone says it is likely the T-CON board, so I replaced mine, the first one I was sent was either defective (as it appeared from the silk screening) or slightly different than my own. I acquired the exact match for my T-CON board, installed it with ease, yes with ease, it was so simple it isn't even funny, it is more difficult to swap a PC power supply, all of this to no avail.
                                        The above screenshots are carbons of my problem and PAY ATTENTION!!!
                                        YOUR LCD IS RUINED AND NEEDS REPLACED! DONT WASTE YOUR MONEY ON USELESS T-CON BOARDS, ACCEPT YOU HAVE A MEDIOCRE GARAGE TV AND STOP TRYING TO FIX IT!!
                                        I have already wasted $50 on a diagnostic from a TV repair facility, and $85 on two T-CON boards that did not help at all.
                                        • visionbluedemon
                                          Help. Sony kd-65x85dj vertical lines
                                          by visionbluedemon
                                          First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                                          Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                                          tried blocking LC lines too, but same results
                                          is it lcd panel issue or tcon board issue?...
                                          07-25-2025, 04:56 AM
                                        • gpo23
                                          Sony KDL-40V3000 - Vertical lines
                                          by gpo23
                                          i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                          With the new t-con the color are good but there are vertical lines on all the screen :
                                          I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                          Is there a way to fix the vertical lines on the new t-con ?
                                          Thank you for your help
                                          gpo23...
                                          10-04-2023, 09:11 AM
                                        • Stanley1843
                                          by Stanley1843
                                          06-29-2024, 11:54 AM
                                        • thstuff
                                          SONY BRAVIA XBR-55A8H - White horizontal lines / red LED flashes four times
                                          by thstuff
                                          This "free from a friend who was going to recycle it" SONY BRAVIA XBR-55A8H arrived with the bottom center RED LED repeating a four flash pattern. It was treated with kid gloves and was reported to have "just gone dead" and the OLED panel has no dents in the metal frame or cracks.
                                          Thread https://www.badcaps.net/forum/showthread.php?p=1091829 helped in proceeding as follows:
                                          1) Unplugged, then plugged set in while holding the remote VOL- and Power to factory reset.
                                          2) Waited 30 seconds, then pressed remote Power button and "Select language"...
                                          01-30-2023, 05:01 PM
                                        • dustman1747
                                          Sony XBR-65X900H vertical lines
                                          by dustman1747
                                          I have acquired a Sony XBR-65X900H to try and fix. It probably was a complete no power situation. The main board was replaced and the TV started turning on. I now have start sounds and backlights, but no image. I've replaced the t-con with no improvement. Cables all appear to be ok and seated properly. The TV took a firmware update and hard reset but neither helped.
                                          Using the tape trick I can get both side to display combinations of colored vertical lines. There is no change in the stripes and the pattern always appears the same. If I add additional tape strips I can get the screen...
                                          09-18-2023, 09:05 PM
