Philips 47pfl6008s wont turn on
  • JorKsX
    • Aug 2021
    • 13
    • Finland
    Re: Philips 47pfl6008s wont turn on
    I know what you mean, I usually charge in and do a lot of different things, then you don't know what it was, in some cases if you only do one thing at a time you might find out what fixed it but I sure don't want to tear it down, do one thing put it all back just to find out you have to do it all again. Kind of like changing a timing belt and not doing the water pump and tensioner.
    I know this feeling
    I usually do one thing at the time and test.
    I've learned my lesson with "do alot and 1/20 things fixed it"
    But anyway cannot close this thread because Im here back with blinky blinky fault light....
    the LED pins that were 59v before are now 51v. after 10 secconds they drop to around 48v and then back to 51v
    CPU on the motherboard gets "warm"
    And the 51v on the LED backlight pins drop to 0v when the front panel light starts blinking twice.
      • 12097
      • U.S.
      D you have steady voltage on the led pins when the led cable is unhooked?
      • JorKsX
        • Aug 2021
        • 13
        • Finland
        Mobo cable unhooked and the voltage starts dropping from 51v to 0v sloooooowlyyy.
        After maybe 3-4minutes there is 0v.
        As soon as I plug the cable back. It goes straight to 51v
        When mobo cable is attached. I can find 51v and 1.2v
        LED cable unhooked, there is still same 51v that goes between 48 and 51v.
        No effect on the two LED cables
        • JorKsX
          • Aug 2021
          • 13
          • Finland
          I started measuring backlight LED's
          There is two LED's in one "chip"
          I measured every single of them. Most of the chips, both LED's turn on and meter shows 2.3v
          Some of them turn on half way. Like one is super dim and other is bright and meter shows 1.3v
          Found also that some do not turn on at.
          The chips that do not turn on at all, my fluke is showing 0.8v for most of them. But also there are leds that do not turn on and meter is showing 2.3v
          Tried both ways.
          So the backlight might be the issue?
            • 12097
            • U.S.
            Yes indeed, best to replace them all.
            • JorKsX
              • Aug 2021
              • 13
              • Finland
              #26
              There is only one row or backlight strips.
              20€ from germany new row. not bad
                • 12097
                • U.S.
                #27
                yep, ultra slim tv, with edge lit backlighting.
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  #28
                  A single row but it's possibly two strips.
                  • pajdek
                    Lenovo Y700-17ISK turn on and off
                    by pajdek
                    Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                    09-20-2023, 02:49 AM
                  • ovrax
                    Philips 55PUS6804/12 turn on & off (probably backlight issue)
                    by ovrax
                    First of all, please excuse me as I'm quite new to this field.
                    I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
                    I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
                    The Ambilight works perfectly and stays on.
                    No sounds.
                    Thanks in advance.
                    08-25-2024, 04:33 AM
                  • RdeveLabs
                    MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                    by RdeveLabs
                    To all the members here...
                    Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                    So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                    05-05-2025, 04:59 AM
                  • robante15
                    Acer Aspire 4520 won't turn on after reboot
                    by robante15
                    Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                    It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                    The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                    If I remove the...
                    04-06-2024, 06:50 PM
                  • masoksian
                    Dell latitude e7470 not turn on .power buton on off and Run Power problem
                    by masoksian
                    I am dealing with the problem of turning on and off my Dell e7470 notebook.
                    The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                    The system does not turn on, there is no post.
                    I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                    The problem continues in the same way.
                    I tried to turn on the Fn key, nothing came to the screen....
                    02-15-2025, 12:08 PM
