Samsung 4K led model UE50NU7445U no picture
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4543
    • Italy - Milan
    #81
    Re: Samsung 4K led model UE50NU7445U no picture
    " means the panel is already broken so I won't care to find new ESD diodepacks to the bufferboards."
    that's nota good idea, the next surge will destroy easier the rest of drivers without diodes..
    • PowerAmpFreak
      • 982
      • Sweden
      #82
      Problem is I have no info what diode packs this is and where to get them...
      • PowerAmpFreak
        • 982
        • Sweden
        #83
        Originally posted by PowerAmpFreak
        Anyone able to indentify the diodepacks on the above pictures?
        Markings are 4262H and 4267H
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4543
          • Italy - Milan
          #84
          in a discussion about September or earlier with me i have found it...
          • PowerAmpFreak
            • 982
            • Sweden
            #85
            With who? Not with me at least
            Could you try to find that info ?
            • Diah
              • Feb 2013
              • 6614
              i did find this pack of 10 Pins D at my scarp 1 for hisense and another for Philips. they are 3 in group like the one you showed here. if the DM on Diode mode. (-) on pin 1 will read nothings over all the rest pins from both side. only one D will read 0 (peep tom ) netween pin 1 and 10. this is the same at other TV.
              if pin 1 (+) the rest will read some Diode value 965 or doubled , but the one D of the group which i mentioned before will read 0 as above. Notice both TV was just cracked screen with full display before scrap them and took the buffer boards as parts.
              • PowerAmpFreak
                • 982
                • Sweden
                #87
                Thanks Diah, the thing is I have already removed the diodepacks since I was suspecting them at fault, before going into the clock lines troubleshooting.
                So now I need to find the partnumber of those diodepacks so I can mount them back.
                The old ones are gone.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4543
                  • Italy - Milan
                  #88
                  ok from my notes file, in Italian:
                  Per TV Samsung con guasto ai diodi tvs schede pannello provare a cercare rimpiazzo uClamp6514P (UCLAMP6514P.TNT) o forse alternativa uClamp4014P (UCLAMP4014P.TNT) di Semtech
                  these small ants can handle very few current so i think a better replacement would be full size tht tvs diodes, i don't know if there's space for them
                  • PowerAmpFreak
                    • 982
                    • Sweden
                    #89
                    You can dream, typical italians (I have family in Italy), there is absolutely no place for any THT devices inplace of the small ones...
                    But do you know what signals the diode packs protect ?
                    I mean it's only 4 diodes in each package and there are 3 packages per buffer board, so is it TX lines or CLK lines, or VGH VGL lines which is protected?
                    I could install bigger TVS across the decoupling caps if I knew more about where they are installed.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4543
                      • Italy - Milan
                      #90
                      them protects clock signals
                      • lotas
                        • Jan 2016
                        • 4899
                        • Russia
                        #91
                        Here's about TVS Diode
                        • alfatv
                          • Sep 2020
                          • 353
                          Those ESD protectors are mostly useful for external connectors like HDMI, USB.
                          I would just leave it alone.
                          Better invest in surge protector for mains and antenna (if used).
                          • PowerAmpFreak
                            • 982
                            • Sweden
                            #93
                            Thanks all for your ESD advice.
                            • PowerAmpFreak
                              • 982
                              • Sweden
                              #94
                              Hello. I mounted new ESD diode packs, but then the same symptom came back.
                              I used the IP4283CZ10.
                              When remove again set is working.
                              From what I can see, the pinout is the same on original and the new ones.
                              I wonder, what required voltage is required to drive the clock lines, perhaps the new ESD diode clamp to early?
                              Datasheet to new ESD diodes:
                              https://cdn.badcaps-static.com/pdfs/...8f794f7f84.pdf
                              • PowerAmpFreak
                                • 982
                                • Sweden
                                #95
                                Today I measured the clocksignals that the ESD diodes protect. The amplitude is about 27V peak so the suggested ESD diodes clamp way too early.
                                That's the reason for not showing a picture and reboot.
                                There must be ESD clamp diodes with higher voltage rating.
                                • lotas
                                  • Jan 2016
                                  • 4899
                                  • Russia
                                  #96
                                  Marking 4262H and 4267H is most likely 42*** - SP5003-04TTG.
                                  • TR103
                                    by TR103
                                    - it keeps rebooting
                                    01-22-2025, 04:12 PM
                                  • JJAAMM
                                    by JJAAMM
                                    Problem
                                    07-06-2023, 06:01 AM
                                  • Mgiffune
                                    by Mgiffune
                                    06-09-2024, 10:28 AM
                                  • Dodgethis
                                    Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                    by Dodgethis
                                    Hello all,
                                    This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                    09-11-2024, 07:39 AM
                                  • YellowJacket
                                    Samsung QE55Q60RAT - no picture
                                    by YellowJacket
                                    Hi friends,
                                    a friend of mine gave me this TV to fix, with common SAMSUNG TV issue - damaged panel. Turning on, sound is present, but no picture. So I went directly to standard process, connecting two pads together with a wire ( see in the picture ), and then removing flex cables. With right flex connected, there was half screen working, but still no picture ( disappearing colors and similar weird stuff ) + working sound. With left flex connected, TV is restarting + working sound. I supposed, left side is damaged, so I then blocked all 8 CLK pins ( going from 0R resistors on the second...
                                    07-30-2024, 01:31 PM
