Samsung 4K led model UE50NU7445U no picture
  • PowerAmpFreak
    • 982
    • Sweden
    I've got an Samsung UE50NU7445U 4k led screen which was stuck in some kind of "boot-loop".
    I replaced the mainboard as a first try which did not help.
    PSU seems fully OK, both backlight voltages and the mainboard supply is OK.
    Now it boils down to the panel itself.
    So I started up the set without the two flatcables disconnected between MB and panel. Then no boot-loop anymore.
    So I guess the diagnostics detect an abnormality on the panel.
    I removed the cover which hide all the panelconnection to the two "buffer" boards (could call it)
    There are not very much on these board except for some decoupling caps and what it seems a flash memory.
    Any advice?
  • Storyteller12
    • Jun 2020
    • 625
    Re: Samsung 4K led model UE50NU7445U no picture
    These “NU” series tv’s suffer from bad panels and backlights. This was just a bad year for Samsung TVs unfortunately. Sounds like yours maybe a panel issue. Have to check all those caps on the buffet boards or try the tape method to see if you get any results.
    Good luck and keep us posted
    • PowerAmpFreak
      • 982
      • Sweden
      Thanks, what does the tape method mean ?
      • Storyteller12
        • Jun 2020
        • 625
        YouTube tv tape method.
        It’s covering the traces from the flat cables going to the lcd panel to try and bypass the bad signals.
        • brad2157
          • Nov 2021
          • 29
          • U.S
          There are better videos out there, but this is just one I found.
          https://youtu.be/pfrRhw7-ZII
          • dskall
            • Oct 2016
            • 2905
            • usa
            I would be checking for shorts first.
            • PowerAmpFreak
              • 982
              • Sweden
              Independtly what I find in terms of shorts (if not caused by a shorted ceramic decoupling cap) there will not be possible to fix it since the fault is inside the panel?
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4542
                • Italy - Milan
                Check shorts on the bigger caps and eventually on diodes/diode packs + big resistors. Often are fixable
                • PowerAmpFreak
                  • 982
                  • Sweden
                  Please see the pic in the link below:
                  https://www.bildtagg.se/bild/b6npwso9b7epr2wky96iqlmq
                  There is 35ohms across a set of caps on both left and right buffer board.
                  MB disconnected so they have no connection through.
                  All the "big" caps measures no shorts (just a diode drop) but as mentioned the "small" in the same repeating pattern across both boards show only 35 ohms which seems faulty.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4542
                    • Italy - Milan
                    that's a normal value i guess. Sorry, i meant short on diodes / open on resistors..
                    • PowerAmpFreak
                      • 982
                      • Sweden
                      35ohms cannot be normal, right ?
                      • PowerAmpFreak
                        • 982
                        • Sweden
                        See picture:
                        https://www.bildtagg.se/bild/i7z3e4oghexkhx06790k05z7
                        There is not even half picture if I disconnect one of the ribbons.
                        Does not matter left or right.
                        The only difference is:
                        If one ribbon is disconnected (does not matter which) the set will stay on, backlight on.
                        If both connected - as soon as BL turns on, two seconds later the set will restart, flashing two times on the standby led.
                        Anyone having access to service manual for this chassis and could tell what 2 blinks mean ?
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4542
                          • Italy - Milan
                          35 ohm is normal, that cap is for the 3,3v prob., 3,3v/35ohm=95mA that is normal for the cof supply... what about the rest??
                          • PowerAmpFreak
                            • 982
                            • Sweden
                            The rest are hi-Z so no problem.
                            But there are not any 3V3 across the "35ohm" line. I suspect the MB shuts it off due to abnormal detection.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4542
                              • Italy - Milan
                              usually tcon disables supply output with a short, hi-z what? i told also resistors.. are there diode packs? can you photograph outers of the panel boards?
                              • PowerAmpFreak
                                • 982
                                • Sweden
                                Hi-z means hi impedance so not a problem.
                                Still I suspect the 35ohm reading across one bank of caps is not normal.
                                It indicates a faulty COF in my opinion.
                                There should not be a resistive load of 35ohm across the supply lines.
                                Diodes packs measures fine.
                                Post pictures tomorrow when I see the patient again
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4542
                                  • Italy - Milan
                                  the faults are common on the boosted lines.. Avdd,Vgh
                                  • PowerAmpFreak
                                    • 982
                                    • Sweden
                                    Pics on buffer boards:
                                    https://www.bildtagg.se/bild/3msuyww1tbu5eqhvqlvvaie
                                    https://www.bildtagg.se/bild/o147wdppblsc0u7xiiaom0e
                                    Diode packs visible on board edges
                                    Is it one COF on each ribbon between buffer and panel ?
                                    Do they all share the same supply lines ?
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4542
                                      • Italy - Milan
                                      Source cofs have probably 3,3v supply, but gate cof/cog can have 1,8v as supply, each source cof receive signals from the pcb.
                                      You must check every big resistor, one of them can be open or higher ohms, that is connected to one diode pack, i suggest you to search to the forum to previous months, this summer some useful info on how to test and source those diodes.. it's a very common fault..
                                      • PowerAmpFreak
                                        • 982
                                        • Sweden
                                        Thanks.
                                        The "bigger" resistors are 100R each measures OK.
                                        BUT - when both bufferboards are connected to MB there is only 74R across one of them.
                                        Indicate some short somewhere.
                                        I have to figure out how to see the pinout of the diode packs.
                                        Is it safe to remove the diode packs and run without them for a short while ?
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Dodgethis
                                          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                          by Dodgethis
                                          Hello all,
                                          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                          09-11-2024, 07:39 AM
                                        • YellowJacket
                                          Samsung QE55Q60RAT - no picture
                                          by YellowJacket
                                          Hi friends,
                                          a friend of mine gave me this TV to fix, with common SAMSUNG TV issue - damaged panel. Turning on, sound is present, but no picture. So I went directly to standard process, connecting two pads together with a wire ( see in the picture ), and then removing flex cables. With right flex connected, there was half screen working, but still no picture ( disappearing colors and similar weird stuff ) + working sound. With left flex connected, TV is restarting + working sound. I supposed, left side is damaged, so I then blocked all 8 CLK pins ( going from 0R resistors on the second...
                                          07-30-2024, 01:31 PM
