Samsung 4K led model UE50NU7445U no picture
  • lotas
    • Jan 2016
    • 4596
    • Russia
    Re: Samsung 4K led model UE50NU7445U no picture
    ESD Protection Diode
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4326
      • Italy - Milan
      diodes are only protections, you can remove them, but to close the repair it is fundamental to replace them, so the next surge peak will not destroy panel, by your photos i see also 200 ohm and 51 ohm resistors..
      • PowerAmpFreak
        • 982
        • Sweden
        Tested without any of the diode packs. The same issue remains.
        Still 35ohm across a bunch of 0402 decoupling caps - NOTE! 35ohm across a bunch of caps on BOTH buffer boards even ribbons not connected! So buffer boards should not share supplylines at this point.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4326
          • Italy - Milan
          replace the original main board
          • PowerAmpFreak
            • 982
            • Sweden
            Done - exactly the same result
            Just thinking a bit "outside the box" - could a backlight diagnose from driver on PSU side cause this issue?
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4326
              • Italy - Milan
              #26
              I was thinking about it because in recent Samsung the symptoms are similar in both cases, but if backlight is faulty it is not the panel disconnection that stops maiin board to sense BL fault, so i'm starting to think at tcon fault, if a semi short is present at a panel supply rail output, the removing of the load can prevent the pmic to feel the overload, or in other analisys since the tcon "software" is on the panel (flash) the tcon can't communicate with cpu the fault state (in truth are same chip but it doesn't matter)... but this is also difficult since you changed main board..
              • PowerAmpFreak
                • 982
                • Sweden
                #27
                I could power the mainboard from external psu +13V but there is probably a BL OK / ERROR on PSU that I need to trick also
                There is very few connections between PSU and MB.
                Also in this set there is no separate T-CON, the panel is driven directly from MB.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4326
                  • Italy - Milan
                  #28
                  yes i know, there's no need of external power, your psb is ok, but you can trick the bl error line and nothing else..
                  • PowerAmpFreak
                    • 982
                    • Sweden
                    #29
                    See attached connector pinout
                    https://www.bildtagg.se/bild/yfq0hnnjv8lzwkupapqpdvob
                    I guess the signal "FAIL COUNT" is the one to check / trick ?
                    Should it be high or low when fault is detected ?
                    Summary:
                    1. When both panel ribbons are connected, this happens when plugging into AC:
                    - BL starts dimmed. After two seconds BL is full brightness for half a second, then
                    shuts off completely. After two seconds the operation goes through an endless loop
                    Also - standby led blinks in sequence of TWO blinks.
                    There is no start-up melody playing in audio.
                    2. When either of the panel ribbons are disconnected. BL behave correct and fades up
                    from dim to bright, also playing start-up melody in audio.
                    Standby led blinks in sequence of FOUR blinks.
                    None of the above tests give any picture information.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4326
                      • Italy - Milan
                      #30
                      Fail count like common status signals in recent Samsung must be low to be inactive so pull it low..
                      • PowerAmpFreak
                        • 982
                        • Sweden
                        #31
                        Pulling it constantly low does not change anything...
                        So - when either of the two panel ribbons are disconnected the set starts-up correct with BL dimming up from dark to bright and plays start-up melody. So is there a "protection" line going through both the ribbons that does not reach MB is either of ribbons are disconnected?
                        I try to figure out which of the buffer boards is giving a problem...
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4326
                          • Italy - Milan
                          #32
                          Wait.. one user wrote the list of the psu tensions in a similar Samsung, since Fail count was 1,57v, it makes me think about a digital serial signal, can you probe it by oscilloscope?
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4326
                            • Italy - Milan
                            #33
                            sorry it's a mistake i think...
                            try to detach only the leds, see if it boot loops, i'm suspecting bad leds
                            • PowerAmpFreak
                              • 982
                              • Sweden
                              #34
                              Sorry for late reply. I already tried running the PSU disconnected from the led connector. It was still stuck in boot loops...
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4326
                                • Italy - Milan
                                #35
                                No more time to mess with BL signals inverse engineering, open the pane and test the leds, i guess you can test each strip with a very low current about 20mA to see if only some leds doesn't light up and the rest only a bit, so the unlit ones must be changed..
                                • PowerAmpFreak
                                  • 982
                                  • Sweden
                                  #36
                                  OK. A quick advice how to do the opening of the backside of the panel would be appreciated. Never went that deep...
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4326
                                    • Italy - Milan
                                    #37
                                    i don't know that model, usually there is a metal frame around the screen with screws, better if tv is been sit on a low level, before the bezel must be detached the panel boards by its stands/locks, with or without screws, after the bezel, must lift millimeters the border of panel opposite to the boards and lifted slowly perpendicular and then removed to a safe place, now screws on the border to remove the black plastic foils holder bezel, then remove foils and keep them in order in other place, now remove the plastic pins, then remove the white foil..
                                    • PowerAmpFreak
                                      • 982
                                      • Sweden
                                      #38
                                      Thanks. I appreciate it.
                                      Does the PSU only monitor the led strips current in order to diagnose ?
                                      IF that is the case I could simply use dummy loads to simulate a proper backlight and check if still boot loops ?
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4326
                                        • Italy - Milan
                                        #39
                                        you have to watch the table serigraph on the PSB, for example 180v 2Amax you have to put 180/2=90ohm/360w load, but i'm not sure about this because this is the max output but tv has probably a % of the maximum setting.. you are safe if the controller only stops at the over maximum or under minimum..
                                        • PowerAmpFreak
                                          • 982
                                          • Sweden
                                          #40
                                          Made some measurements on the led supply on PSU. There are 4 outputs and obviously they are 2 and 2 in series.
                                          They all measure the same in terms of voltage and currents.
                                          So does not indicate a problem with the leds.
                                          I would assume there would be a unbalance if one of the led strips were bad, right ?
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • JJAAMM
                                            by JJAAMM
                                            Problem
                                            07-06-2023, 06:01 AM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Dodgethis
                                            Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                            by Dodgethis
                                            Hello all,
                                            This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                            09-11-2024, 07:39 AM
                                          • YellowJacket
                                            Samsung QE55Q60RAT - no picture
                                            by YellowJacket
                                            Hi friends,
                                            a friend of mine gave me this TV to fix, with common SAMSUNG TV issue - damaged panel. Turning on, sound is present, but no picture. So I went directly to standard process, connecting two pads together with a wire ( see in the picture ), and then removing flex cables. With right flex connected, there was half screen working, but still no picture ( disappearing colors and similar weird stuff ) + working sound. With left flex connected, TV is restarting + working sound. I supposed, left side is damaged, so I then blocked all 8 CLK pins ( going from 0R resistors on the second...
                                            07-30-2024, 01:31 PM
