Can you dignose from the photo ? . Toshiba 65S2650EV
  • Ancient1
    • Dec 2019
    • 275
    • Israel
    #341
    Re: Can you dignose from the photo ? . Toshiba 65S2650EV
    lotas : I have "Transistor like", TO-92, AZ431. I got the PDF now.
    Davi.P
    1. I can replace , as I bought 2. But Vcc is now fine, last time I checked.
    2. What do you want me to do with U2
    3. " I see QF1/2 , it's not clear," = you made a mistake ? or .. where are they
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4498
      • Italy - Milan
      #342
      1. can you answer about plastic bag?
      2.to replace it, but i would put attention first on the ic2
      3. I mean the 2 mosfets on the large heatsink on the left on the previous photo top/bottom view, towards the ac input..
      • Ancient1
        • Dec 2019
        • 275
        • Israel
        #343
        I received new 2xIC2 in anon plastic bag.
        I attach a previous Photo of QF1 QF2 as a reminder: you saw correctly
        OK. So this is the plan :
        Measure V : IC2 and U2 and AZ431
        Measure Hz : QF1 QF2 Gate . and AZ431 too ( Cathode Anode Vref )?
        I will post results before I replace U2 and IC2 ( with the 2nd one I got )
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4498
          • Italy - Milan
          #344
          No,some corrections:
          1-Measure V on ic2 / u2 is not useful, you have already seen V on ic2 is ok, on u2 you can apply 1,2v on the secondary side and watch if primary side conducts between 2 pins
          2-Measure hz on AZ431 has no sense
          3-replacing ic2 from the same lot has no sense, i suspect both are fake, better to buy from your country from big supplier, in my country there are 4-5 big ones like farnell, RS, Distrelec, Mouser..
          • Ancient1
            • Dec 2019
            • 275
            • Israel
            #345
            Its isn't simple to buy from Mouser here, the importer require minimum of ~$15. I will try and find..
            Do you think there is a way to test IC2 if it is OK ?
            OK. The store I got the 3x 0.22 Ohm doesn't have. I see 5x on eBay for $6. But I'll replace first, thats why I bought 2 in the first place.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4498
              • Italy - Milan
              #346
              I have no information of that chip, and how to test it..
              • Ancient1
                • Dec 2019
                • 275
                • Israel
                #347
                If this helps ...
                I asked the eBay seller ( chinese ) if he sells like in the photo he put - blister pack. waiting for the reply
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4498
                  • Italy - Milan
                  #348
                  i don't think that waiting others months helps much the repair, it's like cold pizza..
                  • Ancient1
                    • Dec 2019
                    • 275
                    • Israel
                    #349
                    Hi
                    So I measured :
                    Both QF1 QF2 measure ~3Khz
                    All the AZ431 pins fluctuate V.
                    U2 Opto : Cold side 11.4V and 1.5mV , Hot side Conducts.
                    3rd IC2 measures are in the photo .
                    I replaced IC2 and still no High V.
                    I also measured IC3 pins but ...
                    I'm done. Finito.
                    Why shouldn't I use a good PSU board instead ? I need 24V to the BL , and 12V. I'll check price of new one now
                    P.S found good series in youtube "Howto repair switch mode power supplies".
                    • Storyteller12
                      • Jun 2020
                      • 625
                      Thank you
                        • 12306
                        • U.S.
                        #351
                        Todah Rabah.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4498
                          • Italy - Milan
                          #352
                          was it sealed?
                          • Ancient1
                            • Dec 2019
                            • 275
                            • Israel
                            #353
                            Davi.P : "sealed" ?? you mean IC2 ? no, I used the 2nd one I bought.
                            I got no reply from the eBay seller who put a blister pack photo.
                            See Item 1005002778572497 in Aliexpress. Beside a regular resistor in place of the wire one, it looks identical.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4498
                              • Italy - Milan
                              #354
                              you say 3rd, so it is 2nd.. for a board that cheap get it immediately.. for the ic2 i already said it is probably fake, no useful to mount another from same lot.
                              • Ancient1
                                • Dec 2019
                                • 275
                                • Israel
                                #355
                                Ordered.
                                Expected delivery date : May 12.
                                I will try using the new to see where the difference to the old is. I'll keep you posted
                                • Ancient1
                                  • Dec 2019
                                  • 275
                                  • Israel
                                  #356
                                  WOW
                                  First try ! I was prepared for a completely messed up image !!
                                  Few anomalies :
                                  1. the "no Input" box insides split insides
                                  2. Few Horizontal lines showing
                                  But the Menu looks totally normal
                                  I will connect a laptop now, see how this go...
                                  • Ancient1
                                    • Dec 2019
                                    • 275
                                    • Israel
                                    #357
                                    Not Good
                                    1. Horizontal lines
                                    2. Horizontal Areas
                                    3. Middle Vertical area seems darker
                                    The last image (Van Gogh) painting is the original.
                                    I'll try a video to see how it actually looks = usable.
                                    What a saga
                                    by the way. the new board has a 4 Ohm metal film axial Resistor, not wire resistor
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4498
                                      • Italy - Milan
                                      #358
                                      Sorry, the patient gone... Not good new because i have a tv with similar image
                                      for the 4 ohm resistor this can explain maybe the bad experiments around the pfc area..
                                      • Ancient1
                                        • Dec 2019
                                        • 275
                                        • Israel
                                        #359
                                        I tried a youtube video too, but clearly , the image is very bad
                                        I offered a guy to give him the TV, but its not worth the effort. Clearly unusable
                                        I flipped the TV image vs the Laptop, for better appreciation.
                                        The white strip is in fact where we ripped the Tab off.
                                        The new board R was 4 Ohm and the Wire one ~2 .
                                        I'll take out what I can and put for sale. I doubt I'll get back what money I spent on it - ~$80.
                                        Oh well. Was very interesting ! Thank you so much !!
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4498
                                          • Italy - Milan
                                          #360
                                          this is interesting... indeed i was in doubt if ripping off all or only that tab on the side, but seeing this the tab must be removed all , those maybe interferes with others side, stupid me..
                                          the image on the ripped band appears ok..
                                            09-06-2024, 05:33 AM
                                            Toshiba Portege R30-C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Portege R30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the R30-C boardview and R30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                            09-06-2024, 05:30 AM
                                            Toshiba Satellite Z30t-A-10C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Z30t-A-10C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30t-A-10C boardview and Z30t-A-10C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite L50D-B-11V Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite L50D-B-11V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L50D-B-11V boardview and L50D-B-11V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          • nikokin
                                            NEED help with clear ME image for toshiba A40-G fuz2sy1 a4607a
                                            by nikokin
                                            So i have 2 laptops, both had no image, all voltages are present except for igpu that comes after intel xe drivers installation i flash bios, one of 2 worked but had slow boot, that probably has something to do with management engine, also boot guard is active level 4
                                            on all bios i tried, i attach both original bios, and also the one i flash and worked with slow boot
                                            can someone clean any of them so i can try them
                                            thank you
                                            i tried to do it myself but none of them works
                                            if anyone knows, when i clean the image do i leave bootgaurd on level 4 or put it on level 0...
                                            01-30-2025, 03:02 AM
