Can you dignose from the photo ? . Toshiba 65S2650EV
  • Ancient1
    • Dec 2019
    • 275
    • Israel
    #301
    Re: Can you dignose from the photo ? . Toshiba 65S2650EV
    locally I can get 0.22 Ohm 5W .
    Checking eBay , 0.23 n/a but 0.22 are common
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4545
      • Italy - Milan
      #302
      but i need to know the a actual resistance of the wire resistor even with the prolonges, with the most precise tester you have..
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4545
        • Italy - Milan
        #303
        when measuring don't touch both terminals with fingers..
        • petehall347
          • Jan 2015
          • 4451
          • United Kingdom
          #304
          in case you didn't know already touch meter probes together first and any reading deduct from whatever the resistor reads ,
          also you could build a wheatstone bridge out of precise resistors .
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4545
            • Italy - Milan
            #305
            but thinking on there, normal meters have only 1 decimal so are not suitable for that task.. so try with the 0,22ohm but not 5w, them are unfit , to have got more room better 1w or 2w..
            • Ancient1
              • Dec 2019
              • 275
              • Israel
              #306
              My Meter has 3 places after the Decimal dot
              However, when measuring R of the Probes ( at their base, fingers not touching) : I get a fluctuating R , from 0.8 to about 3.5 , not fast but like every step is 1 second.
              I measured the Wire Resistor , isolated , in a Clamp : I did get slow fluctuation but longest time was on 0.8-0.9 .
              I can go and look for a Fluke at some shop .
              Davi.P : Perché non scrivere in italiano? Posso tradurre facilmente perché principalmente su un PC [ Why not write in Italian ? I can easily translate as I am on a PC mostly ]
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4545
                • Italy - Milan
                #307
                yes, depends which type of meter you have, if not auto range, need to know how many decimals you have in 200ohm scale, i guess you have only 1, so better to get 0,22 resistors, a fluke can cost 250euro 2nd hand to you, not for an hobbist!.. I can't talk in Italian cause the site is in English and also other users are following this thread, sorry..
                • Ancient1
                  • Dec 2019
                  • 275
                  • Israel
                  #308
                  nested problem solving : I actually have 3 DMMs. 1 old Analog, 1 cheap chinese that I can't get to work normally , and one digital 000.000 display. I'll try to fix the chinese or go sunday to a repair shop to get accurate reading.
                  translation :
                  [risoluzione dei problemi annidata: in realtà ho 3 DMM. 1 vecchio analogico, 1 cinese a buon mercato che non riesco a far funzionare normalmente e un display digitale da 000.000. Proverò a riparare il cinese o andrò domenica in un'officina per ottenere una lettura accurata.]
                  P 3 x 0.23 => 0.08 R , and 0.22 give 0.07
                  is 3 in parallel the only way to get this 0.07 R ?
                  translation
                  [P 3 x 0,23 => 0,08 R e 0,22 danno 0,07
                  è 3 in parallelo l'unico modo per ottenere questo 0,07 R? ]
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4545
                    • Italy - Milan
                    #309
                    Please don't translate, i can do it by myself, 0,22 is the best way to obtain it, if you hav 6 digits meter then is the best so why not to use it? 3x0,23 are not 0,8 , the formula is 1/(1/R1+1/R2+1/R3), if you find a better combination let me know, 3x0,22 gives 0,73, 3x0,23 gives 0,76, not precise as 0,75
                    • Ancient1
                      • Dec 2019
                      • 275
                      • Israel
                      #310
                      I used online calc.
                      My Digital Multi Meter (DMM) has 4 places. As I said , I get fluctuations.
                      I'll go to a tech shop tomorrow, ask them to measure
                      • Ancient1
                        • Dec 2019
                        • 275
                        • Israel
                        #311
                        Been to Tech Shop , Fluke , he got 0 , couldn't measure.
                        I doubt I can buy 0.22 localy (haifa), I will call tel-aviv tomorrow , see if I can get faster than aliexpress . I understand that the 5W , blocky, resistors are not good ( why) , and that I need to find 2W max
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4545
                          • Italy - Milan
                          #312
                          i don't know if you have room for 3x5w..
                          • Ancient1
                            • Dec 2019
                            • 275
                            • Israel
                            #313
                            Tel Aviv store has 0.22 2W. But they don't send by mail.
                            So its time to call my cousin ...
                            • Ancient1
                              • Dec 2019
                              • 275
                              • Israel
                              #314
                              They were bought. Now delivery.. hopefully soon
                              • Ancient1
                                • Dec 2019
                                • 275
                                • Israel
                                #315
                                Hi
                                I got 3 the resistors , measured and installed - see photo.
                                No Luck
                                I will carefully inspect the board again, maybe I missed something
                                and than probably order a new PSU , I owe it to you guys , esp. Davi.P
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4545
                                  • Italy - Milan
                                  #316
                                  you can try put back the original wire resistor, desolder r37, solder 2 wires on its pads, between those you put in series a through hole resistor same as r37, and a trimmer starting with lowest value and try increasing in many tries..
                                  • Ancient1
                                    • Dec 2019
                                    • 275
                                    • Israel
                                    #317
                                    I think have 1-1k trimmer. With R37 ( code 562 ) being 5600 Ohm, I think maybe I should use a lower value resistor , so I can get values above and below 5600 Ohm ?
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4545
                                      • Italy - Milan
                                      #318
                                      you don't have to lower the r37 but only increase, so put a 5k6 resistor in series with trimmer.
                                      • Ancient1
                                        • Dec 2019
                                        • 275
                                        • Israel
                                        #319
                                        I don't have a larger watt Resistor.. I'll rig some cooling fins .. and hope
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4545
                                          • Italy - Milan
                                          #320
                                          larger watt?? who have said that? that in pic goes well, it's a 1/4w..
                                          • rimwall
                                            Sony KD-65x7500D - double image - Tcon or Panel?
                                            by rimwall
                                            This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                            I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                            11-18-2025, 02:09 AM
                                            09-06-2024, 05:33 AM
                                            Toshiba Portege R30-C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Portege R30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the R30-C boardview and R30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                            09-06-2024, 05:30 AM
                                            Toshiba Satellite Z30t-A-10C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Z30t-A-10C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30t-A-10C boardview and Z30t-A-10C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite L50D-B-11V Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite L50D-B-11V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L50D-B-11V boardview and L50D-B-11V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
