UE40D5500 restarting
  • domix
    • Jan 2014
    • 171
    • Slovenia
    I have this tv and when turn it on it work 10 sec then restart and come back and restart again and again.
    Is this common issue and can be fixed?
    I unplug all hdmi and other sources and didn help
    I will open it tomorrow. Is there any common issues on which have to pay attention.
  • lotas
    • Jan 2016
    • 4905
    • Russia
    Re: UE40D5500 restarting
    The problem of this chassis is BN41-01660 nand flash firmware K9GAG08UOE.
    https://www.youtube.com/watch?v=zXIIT4cQYeY
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4541
      • Italy - Milan
      someone reported succes by entering service menu and rapidly do reset.
      • yokoono
        • Apr 2010
        • 515
        Cool the nand memory with freeze spray, reset to factory settings and update to the latest software from the manufacturer.
        If this does not work, turn on the TV and cool down while the TV is running.
        • domix
          • Jan 2014
          • 171
          • Slovenia
          Okey, i will try but i think i cant do this in3-5 sec whic is the time after restarts.
          How can i enter service menu?
          Can i spray over over the chip when tv is turned on? How much spray should i use?
          Which is the nand memory chip?
          • yokoono
            • Apr 2010
            • 515
            As long as the ice remains on the nand.
            SM: With TV in stby type on the remote control: INFO, MENU, MUTE, POWER
            • ducky29
              • Dec 2015
              • 369
              • Europe
              Replacing the nand with a newly programmed chip is the way to go. Its a guaranteed way that the tv will live longer. I only did one by freezing and the set bounced back after a week.
              • domix
                • Jan 2014
                • 171
                • Slovenia
                That will i do
                This one is okey?
                https://www.ebay.de/itm/113706841524
                • ducky29
                  • Dec 2015
                  • 369
                  • Europe
                  That will i do
                  This one is okey?
                  I order from aliexpress and reprogram them myself. But it looks great from the reviews and I would give it a go!
                  • domix
                    • Jan 2014
                    • 171
                    • Slovenia
                    If i buy this from ebay, and replace it. It will work or i have to program it?
                    Or will worked that i just instal firmware with usb?
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4541
                      • Italy - Milan
                      This tv model is very mysterious, it is been fixed in many ways by various technicians, i remember one of them that solved by resoldering the nand flash, i think there is a common soldering problem by factory that trough time it corrupts the nand writings therefore the filesystem... so you can try resolder it, enter srv menu, reset, then update software..
                      Settings reset can be made sometimes by unplugging power, jumper with screwdriver pins 5,6 of settings eeprom, plugging power, wait 5 sec. then release jumper, in other way erasing it by programner..
                      • mhxanikos
                        • Jan 2019
                        • Greece
                        The only way to fix rebooting the D5500 TV series of samsung is buy replacing the nand ic and only buy a perfect tested and without any bad blocks nand, it needs a special procedure to eliminate bad blocks inside a new nand chip to be replaced and always with the right firmware. There are some Slovenian sellers to buy 100% working nands from ebay that also can make updates and have a perfect smart hub working.
                        • DangoCapacitor
                          • Dec 2023
                          • Poland
                          Hello. I'm new in that types of repairings. How to reprogram flash? Is the software from broken one is good for install on the new one flash? Or did you get it from the samsung website?
                          What type of programmer i have to buy?
                          • lotas
                            • Jan 2016
                            • 4905
                            • Russia
                            UFPI Programmer
                            https://mslw.com/shop/
                            • shouri
                              Dell latitude e5490 auto restart
                              by shouri
                              Hi guys, can someone help me?
                              I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
                              Board model is dm70 la-f401p rev:1.0 2017-09-20.
                              At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
                              After a few days test, is seems ok.
                              Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
                              12-10-2024, 09:27 PM
                            • davidebeatrici
                              Asus X541UV Windows update KB5063060 deleting BootOrder EFI environment variable? bios fix
                              by davidebeatrici
                              I had 3 people contact me in a week because Windows suddenly didn't boot:
                              As you can see, all 3 are ASUS computers, but I believe the common factor is the BIOS being American Megatrends (AMIBIOS/APTIO).
                              The first two recovered just fine after a restart, but the third one didn't and was brought to me. The model is F541UV (X541UV).
                              Setup allows to add a boot option manually and the operating system boots just fine from both bootx64.efi and bootmgr.efi. However, there is no way whatsoever to save the option(s): upon a reboot the machine goes straight...
                              06-17-2025, 12:59 PM
                            • fulepost@outlook.com
                              Samsung "QE" series QE55Q70RATXXC Intermittant restart in "home mode".
                              by fulepost@outlook.com
                              Dear all.
                              I'm a less knowledgable member who would appreciate some guidence.
                              I have a Samsung QE55Q70RATXXC that works perfectly in "shop mode" but in home mode it restarts, Intermittantly.
                              With intermittant I mean the TV can work perfectly for a week and suddenly start to restart. Before the restart it may reach different stages. Sometimes it restarts when the "QLED" start screen shows up and some thimes it restarts after hours, and everything in between.
                              When the restart occurs, the screen blacks out leaving a light area alomng the edges fading...
                              11-09-2025, 07:10 AM
                            • Neddsme
                              Bios partially corrupted somehow and now warm boot doesn't work which is critical
                              by Neddsme
                              Hie.
                              I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
                              Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
                              I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
                              I managed to run Windows troubleshooting and...
                              02-04-2022, 05:57 AM
                            • sigmeyer
                              UE40D5500 Keeps restarting software problem!
                              by sigmeyer
                              Samsung TV has issue with nand flash , keeps restarting. All voltages present and OK. I disconnected the PWM pin from motherboard connecter and it still keeps restarting. So its not psu issue , disconnecting the Tcon board changes nothing either.
                              My question is , will reprogramming the nand chip fix the problem? it has a nand chip and i think its called EEMC chip for storing memory. I was thinking to use RT809H programmer to reprogram the chip and hopefully fix the issue or maybe if someone has some boot/flash files i can do it thru USB.
                              Thanks alot in advance.
                              12-31-2020, 09:25 AM
