LG 55UK6950PLB backlight but no picture
  • lotas
    • Jan 2016
    • 4575
    • Russia
    Re: LG 55UK6950PLB backlight but no picture
    Originally posted by viewerau
    Hi lotas.
    I am sorry, I do not understand your reply...my apology.
    These signals go to these contacts (on the left and right strips of the panel), if you know on which side the CLK signals are defective, then isolate that side with tape.
    • viewerau
      • May 2020
      • 305
      Thank you very much lotas.
      Signature:Seemingly hopeless tv fixer
      • Chrissygizmo
        • Mar 2021
        • 108
        • United Kingdom
        Originally posted by William1967
        The panel has a problem, it's a common fault with these models and several other models from LG. The AVDD must be around 17v and is only present on one side when you disconnect one of the LVDS cables.
        Hi , Sorry for just jumping into this thread, but I have exactly the same problem, I'm going to post my own thread, but I am curious, did you mean that the panel is cattled if the AVDD is 17v on one side only ?
        When I have the left side LVDS connected I have 17v on the left side and 3.9v on the right side but I get 0v on both sides when both LVDS connected or just the right side LVDS.
        • notallbad
          • Oct 2012
          • 1190
          Originally posted by Monty74
          Hi notallbad, did you have to trash the screen to get to the burnt out tab bond? I have one of these screens and wanted to attempt a repair as I too have backlight but no picture. Is this a ribbon cable of some kind that has burnt out? I cant really see as the picture is not so clear as mentioned. I just want to know if its repairable on a micro soldering scale? Regards Craig
          No, was able to get to the panel tab bond ribbon without damaging the screen but the panel will need to be removed.
          • zwarder
            • Oct 2013
            • 45
            • United Kingdom
            Had this issue with one of these.
            TV ran for 5 minutes then cut out, yellow led on PSU blinks 8 times.
            Anyone got a service manual
            • zwarder
              • Oct 2013
              • 45
              • United Kingdom
              #26
              12v supply from psu has dropped to 10v I will investigate
              • Tr0ll
                by Tr0ll
                Original T-con:
                First replacement T-con:
                10-07-2023, 07:48 PM
              • triplefour
                by triplefour
                09-13-2023, 10:43 PM
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
              • Ierwin
                by Ierwin
                05-13-2025, 03:31 PM
              • groomit
                Philips 50PUS7363/12 Backlight but no picture
                by groomit
                I'm having trouble with above mentioned TV. Bought it defect.
                Picture was heavily compressed around the horizontal axis. Fiddeled and tried different things (mask clock lines, swap T-Con). But no difference.
                Then I identified a heating capacitor on the left hand Signal-PCB (?) below the display. Replaced it by hand soldering. Checked for shorts afterwards. But now the screen stays black.
                I can see backlight, but screen stays black.
                What I've tried:
                - Disconnect right side cable from T-Con -> same (backlight but no pic)
                - Disconnect left side...
                11-22-2024, 02:43 PM
