bn44-00264c - CCFL emulation
  • cruiser_
    • Nov 2019
    • 124
    • Ireland
    hi there,
    I am fixing a SAMSUNG le40b530p7w. It has 2/3 lamps which are acting up. This leads to the inverter (bn44-00264c) shutting off entire backlight after several minutes. I ruled out inverter issue - the PFC_OUT voltage is stable 390V, so are 13V & 5.3V. ICs are getting the power etc. When the backlight is shut off, these voltages stay.
    I do not want to disable protect feature completely, but rather 'emulate' these fussy CCFLs.
    I tried to replace the CCFLs with capacitors - tried 22pf, 47pf, 47*2pf.
    unfortunately the backlight goes after a second or two.
    How could that be achieved?
    BD9893 datasheet: http://dalincom.ru/datasheet/BD9893F.pdf
    BN44-00264c: https://archive.org/details/Samsung_BN44-00264C
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8329
    Re: bn44-00264c - CCFL emulation
    Not that I recommend doing this, but disabling the protection circuit on the inverter will do the trick.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4476
      • Italy - Milan
      Capacitors are not suitable, the best way is to trick the single lamp current control, to avoid current consumption, but leaving circuit as is, lamp must be replaced with resistor, must read panel datasheet and seen current/voltage of lamp, not at startup but normal use..
      • petehall347
        • Jan 2015
        • 4440
        i used to sub in known good tubes for testing
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4476
          • Italy - Milan
          he don't want to test..
          • cruiser_
            • Nov 2019
            • 124
            • Ireland
            Thanks for the responses guys.
            I know it is the faulty bulbs since when removed, backlight goes after a second and with the redish/flickering ones in, it might go on for hours. And I do not have any good bulbs for replacement, hence the quest
            I tried to change the sensing circuitry and unfortunately failed.
            The over/under voltage protections do not seem to be kicking in (PR_1 / VS / OVP).
            It seems what's left is the current feedback based on fb_1 and fb_2 lines but I do not understand how could it measure current if this feedback is only based on Z7/Z8 lamps?
            (the faulty bulbs are not on this pair).
            What's worse is when I had a number of cables hooked up to measure the voltages during operation, one of them shorted and fried BS9893 chip...doh
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4476
              • Italy - Milan
              why don't asked my advice?
              • cruiser_
                • Nov 2019
                • 124
                • Ireland
                I do this in parallel
                I ordered 100k 20W resistors, along with BS9893.
                Still, for my own educational benefit, I would like to understand which part of protection kicks in.
                • R_J
                  • Jun 2012
                  • 9591
                  With no ccfl connected the voltage will be high, so it is likely the over voltage protection is shutting down the drive.
                  You may be able to disconnect one of the diodes ie: DI806 ~ DI812 for the bad lamp.
                  If the bad ccfl is connected to TI802s pins 3, then it could be fault with the FB line tripping the circuit.
                  • cruiser_
                    • Nov 2019
                    • 124
                    • Ireland
                    thanks R_J,
                    i made sure the bad CCFL was not on that circuit that provides feedback.
                    What is the purpose of DI806-812 diodes? I thought they only provided some sort of 'back current' protection?
                    • caseyjay_48
                      Sony KDL-46BX450 Inverter Troubleshoot Logic
                      by caseyjay_48
                      I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                      I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                      09-23-2022, 08:08 PM
                    • ttmi100x
                      HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                      by ttmi100x
                      Greetings everyone,
                      I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                      The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                      Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                      Upon closer inspection...
                      07-31-2024, 06:36 PM
                    • x_orange90_x
                      Vizio E55-E1 bad backlights or bad inverter?
                      by x_orange90_x
                      I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                      I don't know how exactly to test the inverter itself. Is it...
                      01-29-2025, 09:24 PM
                    • Gentian
                      APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                      by Gentian
                      I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                      It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                      03-06-2023, 07:07 AM
                    • valvashon
                      Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                      by valvashon
                      For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                      History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                      01-04-2024, 01:44 PM
